740IL stock engine swap - Bimmerfest - BMW Forums
Old 02-03-2013, 04:23 PM
9740il 9740il is offline
Mein Auto: 750il
so i wrecked my 740 and found another. my body is wrecked but engine is fine. the one i found is fine but the motor is wrecked. so i wana drop my engine in and ride away.
Real question is
how long of a process is a remove and replace?
also
can i use a cherry picker? plus if going this rout- what els id need......
mahalo
Old 02-12-2013, 09:38 PM
Dakota89 Dakota89 is offline
Mein Auto: 99 740il
99 740il Engine Swap
First off, hello! Im new to the forums but i have been meaning to do some writeups on what ive done. Sadly on these wonderfully quirky cars everything has already been done. I have a link to a engine removal video with obnoxious music but i used it as a guide because most seem to include removing the transmission which im not keen on doing in my driveway.
I did the engine swap start to finish in my gravel driveway with help from a poorly used (and now somewhat damaged) trailer hitch mounted load lift and gobs of cardboard to avoid the old rock in the back. As you know a jack stand tends to sink into gravel and dirt leaving less room to work by the end of the job but luckily i managed to finish it up before being crushed.
Doing the job in my driveway with a spare car to run out for tools or parts it took me about 4 of these short winter days. If i had proper tools, a real engine lift, and a garage (concrete would be nice) im sure i could have killed it in 2 days. Its not any more troublesome than any other engine job as long as you have bandaids and rubber gloves handy. Also you will need a lift load leveler, e-torx socket set, and alot of patience. For all the rubber gaskets and coolant seals i used a thick coat of sil-glide from napa (that might not be how its spelled. I feel like it helps protect these expensive seals from exposure to oil and other chemicals. When you find yourself disconnecting hoses down the road you will be happy they arent hardened on.
Thats all i got for now. Let me know how your job went if you did it already.
Old 02-13-2013, 12:22 AM
BMWFatherFigure's Avatar
Old School
I was going to guess 3 days with all the right gear (I have it all and then some). Take lots of pictures and make loads of notes. Take the best of all the fixtures and clips so your end result is the best you could get.
Current:
E38 Parts Car
Previous:
Old 02-22-2013, 01:16 PM
homestead homestead is offline
Mein Auto: 2000 740il
Did this on my 2000 740il, took a weekend with a cherrypicker. Hardest part was driver side exhaust man. You can do. Did not remove trans..
Old 02-22-2013, 03:48 PM
Mein Auto: 99 740il
Engine Removal
Note that with a load leveler you can remove the engine with the exhaust attached, you just have to tilt the front of the engine up around 45 degrees. Dont make the mistake i did. It slipped my mind when i was swapping stuff to the new engine and i dropped it in with the exhaust off. It then took me several hours of struggling to squeeze the exhaust in through the bottom. Be prepared to struggle for hours to get the manifolds on or off with the engine in place. The drivers side was alot worse though.
Old 09-08-2015, 02:22 PM
yoboss yoboss is offline
Mein Auto: bmw
Hi all
I have a question about swapping a engine on a BMW 740i
do I need to worry about the new engine to be program or is just a swap and u r good to go?
Old 09-08-2015, 05:21 PM
Trevor7008 Trevor7008 is offline
Mein Auto: 01 749i sporty S62
Originally Posted by yoboss View Post
Hi all
As long as it's the same engine going in as coming out, No, Just leave the original DME in place.
Old 09-09-2015, 12:12 PM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
@ Trevor, your ride is so sweet and you've been registered here for over 2 years...only 15 posts?
@ yoboss, what Trevor said! There were changes to the V8 throughout the E38 740i run (4.0, 4.4, VANOS), as long as it is the same the only pain will be from the scraped knuckles.
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG (hello X7, and lottery!)
1999 BMW 740i - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 BMW 330xi - fXtXeX/son project time - a couple more stupid items and it will be April's car
2008 BMW 335xi - makes me wish we always had snow
2002 BMW 530i/5 - 2.5 years searching...and it is John's car
Old 09-09-2015, 12:32 PM
I always forget to check this forum.
Old 09-09-2015, 04:25 PM
Mein Auto: bmw
Thanks all. I m not afraid of scraped knuckles if i can get my baby back on road
Old 09-09-2015, 04:56 PM
More active on BF? Or somewhere else? This one is fairly new and moves pretty slow for E38's.
IIRC, there is a post from about 5 years ago that says there was only one E38 S62 and it doesn't get driven (a Seattle7 post?)...so when did you do yours and how many miles have you put on it since?
