Old 02-13-2013, 04:36 AM
granlund granlund is offline
Mein Auto: -02 530 & -92 325is
On the same topic, does high-octane fuel offers more mileage?
The question is $ spent per mile.
Let's say octane 87 is $3.50/gallon.
Let's say octane 91 is $3.90/gallon.
With an 18-G fill-up, the price difference is $7.20.
But if octane 91 gives us more "energy density", i.e., more Joules per kg of fuel, then itmakes more sense to use 91.
Does anyone have any data on $ spent/mile on different octanes.
Higher octane/AKI gasoline actually has slightly less energy density, believe it or not. The difference is the engine's ability to extract energy density from the fuel. An engine designed for higher AKI can extract a net higher energy density from higher AKT than lower AKI.
At some point I should use my live monitoring OBD2 and check ignition advance on the highway with both 87 and 91.
Old 02-13-2013, 06:38 AM
Studawg's Avatar
Studawg Studawg is offline
Mein Auto: 2003 540iT M Sport
Originally Posted by franka View Post
and more energy per gallon than gas.
This nonsense was posted on the first page of this thread, and then that poster went on to make many more comments. This is false, and the opposite is, in fact, true. This information is so patently false that it would seem someone with a particular agenda had to start this for it to be out there. I mean, how does information that is this utterly WRONG get out there and then picked up? I know that this post was a couple years ago, but I thought everybody knew this 5+ years ago.
The difficult part about quantifying 87 vs. 89 vs. 91 etc...is the problem that is ethanol. To get any sort of real world information, you have to have a control. If one doesnt have access to pure gasoline, (which everyone used to) they are only guessing at the percentage of ethanol in the fuel. There have been recorded ethanol contents in fuel samples ranging from 5% to 20%. (It has been proven that E15 will do damage to modern, as in new engines, even before phase separation.) So you have to test it, and there are ethanol test kits that you can purchase. The higher the ethanol content in the fuel, the lower MPGs you are going to get, you can bank on that. Ethanol will raise the octane of gasoline, so what happens is, distributors start by adding ethanol to 85 octane gas to get 87, then add even more to get 90, 91 or "premium" and charge more for it. This is why pumps say "gasoline contains up to 10% ethanol.
Then, at a certain time, the ethanol begins to phase separate and you are left with 85 octane gasoline (if you put in 87) in your tank, 100% ethanol and water, with the water and ethanol mixture sitting below the gas, then sometimes a layer of pure water at the bottom. The longer the ethanol blended fuel is in your tank, the worse this problem is. The problem is also exacerbated when the vehicle in question is stored outside, compared to being stored in a garage, due to temperature and humidity.
When it comes to MPG, trying to quantify which octane rating to put in your gas will be hard due to variations in ethanol content.
For my car, its nothing but 91+ octane pure gasoline.
Old 02-13-2013, 02:25 PM
THAT, would be very useful because otherwise, we're all just guessing (including me).
Old 02-13-2013, 02:27 PM
Higher octane/AKI gasoline actually has slightly less energy density, believe it or not..
I understand the sentiment (remember, they inject water, I'm told, to prevent pinging in race engines,and, we all know high-octane jet fuel is basically very clean kerosene fuel oil) ... but still ... I have to go back to the octane FAQ, which clearly says:
"Antiknock ability is _not_ substantially related to 1. The energy content of fuel."
Old 02-13-2013, 04:44 PM
professorman professorman is offline
Mein Auto: 2000 525i
Old 02-14-2013, 09:45 AM
Severe550i's Avatar
Severe550i Severe550i is offline
Registered Loser
Mein Auto: 2011 F10 550iX M-Sport
Not sure if this is BS or not, but my cousin works for state government and said when his agency tests octane ratings at the pump, they only test for the minimum. Therefore, the actual octane rating (for example 87) is generally higher. He's convinced 87 octane is almost always closer to 89-91, depending on where the fuel came from.
Anyone else ever hear this?
"'Tis nothing good or bad, only thinking makes it so."
-William Shakespeare
Old 02-14-2013, 12:18 PM
aa240sx's Avatar
aa240sx aa240sx is offline
Mein Auto: 2001 BMW 530I
Very timely conversation. If I had the time to do a scientific study to really determine mpg using 87 vs 91, I would too, but like most of us I don't. What I do take away from this thread though is that you can use 87 without ill effect as long as you don't have a lead foot.
Given that gas is now over $4.00/gallon for 87 at least in the SoCal area, I think I will now switch from mid-grade usage. I have a feeling a lot of people are going to start doing this.
- 2008 R350 Mercedes Wagon
- 2003 M3 Coupe - Alpine SMG
- 2001 530i - 5 speed, Anthracite Metallic, Sport Package
Old 02-14-2013, 10:57 PM
It looks like the exact study we'd want was already done:
- CRC PROGRAM FOR QUANTIFYING PERFORMANCE OF KNOCK-SENSOR- EQUIPPED VEHICLES WITH VARYING OCTANE LEVEL
Originally Posted by abstract
A pilot study was conducted under the auspices of the Coordinating Research Council, Inc. (CRC) to assess the potential effects of gasoline octane quality on acceleration performance, fuel economy and driveability in vehicles equipped with electronic spark control systems (knock sensors). Fourteen vehicles were tested by five participating laboratories on CRC un- leaded reference fuels of varying octane quality (78 to 104 RON). The test vehicles included nine naturally-aspirated and five turbocharged models. The results showed that acceleration performance was the parameter most sensitive to octane quality changes, particularly in the turbocharged models. No significant improvements in fuel economy were found with increasing octane. Driveability was not affected by fuel octane within the commercial fuel range, but three vehicles showed degraded driveability with sub-commercial octane fuels. Additional testing is planned within CRC to further quantify the effects of octane quality on acceleration performance in a wider variety of vehicles.
NOTE: 87 RON is probably something like 83AKI or 84 AKI (if you have a better RON-to-AKI conversion, let me know) - but the key point is that 87 RON is an impossibly low octane rating (for American pumps anyway).
In addition, read what BMW apparently has to say about putting 87 AKI fuel in our 91AKI engines:
- Running On Regular: Do Premium Vehicles Really Need Premium Gasoline?, From Stan Baldwin
BMW explains using lower Octane gasoline
Straight from the BMW spokesperson, we get the final verdict regarding using 89 or 87 octane gas in our 91 preferred cars.
From Stan Baldwin online
Long before gasoline rocketed through $4 a gallon many people were dismayed to see a significant percentage of their income disappearing into the tank of their car. Today, a wobbly economic outlook, increases in the cost of most other forms of energy, as well as the cost of life's staples, have prompted folks to look for every possible way to cut back on spending. "Can I save money by running my car on Regular?" "Will it hurt the engine?" my friends ask. More than one person driving a car the manufacturer has spec'd for Premium has told me "I use Regular and my car runs fine." Are there consequences of "down grading" your fuel? It is definitely a timely question, so we sent e-mail inquiries off to a half dozen manufacturers asking about their technology and their policy on the matter.
While waiting for their reply let's review some internal combustion engine characteristics. Fuel does not truly explode in a cylinder, at least it isn't supposed to. It burns smoothly, albeit very rapidly, across the cylinder. The octane rating is a measure of the propensity a given fuel has to burning, rather than exploding. Gasoline "exploding" in the cylinder is frequently called "detonation" or more colloquially, "knocking" or "pinging". These explosions, because they happen as the piston is rising during the compression stroke and try to shove the piston back down the bore, can do damage over time. In the case of severely stressed motors, such as in race cars, a few seconds of serious detonation can destroy the engine. Two of the mechanical considerations affecting how smoothly a fuel burns are compression and cylinder head configuration. Two variable considerations of great importance are the temperature in the cylinder and the ignition timing. Every manufacturer designs and builds their engines to operate most efficiently for the application intended with a gasoline of a particular octane rating.
Not all that long ago, before the advent of engine management systems, the result of tanking up a high compression vehicle with standard grade fuel was immediately obvious. Providing the stereo wasn't cranked up past 100 decibels, the pinging or knocking from the engine compartment let you know something was not right. Driving up a hill, towing a load or simply accelerating quickly produced an unnerving rattle from under the hood. It sounded very much like your carbureted V-8 had morphed into a diesel. Until the age of microprocessors enabled the creation of engine management systems, the consequence of a steady diet of low octane fuel could be fatal for a high performance engine.
General Motors, Honda, Toyota and BMW responded to our inquiry. Honda's public relations representative declined to comment on the issue. Toyota noted that essentially all their current models are designed to run on 87 octane. I asked about using 85 octane, available in some markets, and Bill Kwong of Toyota corporate PR told me they would run fine, with maybe only a slight 2-3 percent decline in horsepower and fuel mileage. But 85 octane is usually only offered in markets at altitude (i.e. Denver, Colorado) where the reduced oxygen doesn't allow an engine to reach full designed power in any event. If you drive a modern Toyota, the octane rating of your fuel isn't much of an issue. But what about a brand aimed squarely at the performance market? What about BMW?
Thomas Plucinsky, BMW Product and Technology Communications Manager told us all BMW engines are designed to run on 91 octane. All performance testing, including EPA emissions and fuel mileage, is done with 91 octane. However, though BMW is all about performance, their motors will run on 89 or 87 octane without damage. The knock sensors pull the ignition timing back and eliminate detonation. There will be a loss of power and a decrease in fuel mileage, but the size of the horsepower loss and the increase in fuel consumption depends upon many factors, such as ambient temperature, exact formulation of the fuel and driving technique, so BMW does not offer any estimates for operation on lower grade fuels. One not so obvious concern, Mr. Plucinsky noted, is the type and quality of additives the gasoline companies include in the fuel. Premium gasolines may have better additive packages which are more effective keeping fuel systems (particularly injectors) clean and working efficiently, than those in regular grade fuels or off-brand products. Using lower octane or off-brand fuel could be degrading the fuel system over time, setting you up for a repair bill down the line.
Dave Muscaro, Director of Engine Development/Calibration for GM power trains explained GM has "three flavors" of fuel specification for their offerings: Regular (87 octane) Recommended, Premium (91) Recommended, and Premium Required. Again, we are more concerned with the last two categories where regular could be substituted for the specified Premium. All the engines have a knock sensing ability that retards the spark when detonation occurs. For the premium recommended vehicles the spark advance will be pulled back enough to eliminate the detected knocking. The typical driver will not notice a performance decrease, except under load, and mileage will decline slightly. The engines intended for performance, such as the LS7 or the supercharged small block V-8, are Premium Required powertrains. The customers clearly were not primarily concerned with economy when they chose a performance vehicle and GM optimizes the engine management system to deliver the highest possible power output at all times. To this end the detonation control system does not retard the spark to the point required to prevent all knocking. It would seem a determined deranged drag racer could run Regular in his Corvette and, over time, he might manage to melt a piston or two.
If burning 87 octane in your car, when 91 octane is specified, will not harm the engine, and the performance degradation is not noticeable in typical driving, how much money can you save? The Energy Information Administration, U.S. Government Department of Energy, offers some figures for US gasoline retail prices (these are averages, all areas, all formulations). A year ago Regular was going for $2.982 a gallon and Premium was commanding $3.196 a gallon. The 21.4 cent difference delivered a 6.7 percent saving over Premium. This June 23, 2008, Regular extracted $4.079 from your wallet while Premium sucked up $4.312 for every gallon. The differential (23.3 cents) has grown slightly since 2007 but buying Regular is now only 5.4 percent cheaper than Premium. Since 5 percent is roughly the typical percentage of mileage decrease to be expected with the 87 octane fuel in a 91 octane engine, is there any savings at all?
Bottom Line: Most modern engines are fuel injected and controlled by sophisticated engine management systems which can rapidly and accurately compensate for lower octane fuel by retarding the ignition. Running these cars on 87 octane will not hurt them. However, the immediate savings at the pump may be wiped out by the subsequent drop in fuel mileage and performance
, not to mention the possibility of damage over time.
EDIT:
In addition, these may be useful:
Changes in Gasoline IV - The Auto Technician's Guide to Spark Ignition Engine Fuel Quality
Road & Track - Premium Fuel Futures - A primer on high-test gasoline: Is it for you?
Old 02-16-2013, 02:19 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
I was traveling the exact same route every day and 95% of it was highway. I am anal about watching my gas mileage. I use my cruise control constantly to maximize gas mileage as it modulates the gas pedal the least. The whole deal with my 540 automatic is a wash so I use the premium. We get 93 octane here in Indiana. Premium is had for 30 cents over 87 octane regular which car runs "ok" on. So, 18 gallons times 30 cent savings is $5.40 a tank savings buying 87 octane.
My gas mileage suffers real close to 2.0 MPG using regular, so with an 18 gallon fill, The 2 miles per gallon equals 36 miles per tank. This is roughly 1.5 gallons of gas to get that 36 miles back. 1.5 gallons times $4 a gallon equals $6. Savings on buy side was $5.40 vs $6 so running premium costs nothing and is better for my 4.4L engine.
Old 11-18-2013, 12:13 PM
For the record, this gasoline grade question was asked today:
> E39 (1997 - 2003) > Gasoline grade question.
Originally Posted by Hobel.587 View Post
I bought the 1999 528i. The previous owner maintained and serviced everything well. With records.
However. He has been putting low grade gasoline in it for 11 years, but says it's been fine.
I would like to start using premium. Will switching right now have any adverse effects? And is it worth it?
Thanks,
Jake
Old 11-18-2013, 08:59 PM
Just to be more complete, the cost differential question was discussed there also:
Originally Posted by Burning2nd View Post
almost no one knows that it takes 2.5 to 3 full tanks of fuel for the trim to change...
so running 91 then 87 then 91 does nothing but confuse your car..
you want to test it for real?
you run it for a month or 6 month period... not tank by tank.
lol you kids are funny..
Originally Posted by edjack View Post
It's easy in my 'hood: The per-gallon price spread between 87 and 91 octane is only 20 cents.
Originally Posted by itsjustmb View Post
I can feel the difference in power when I use regular V premium. On 91 octane, the car just seems to run smoother and get going a lot faster. I also noticed the car liking 76 or Shell gasoline. Might be my mind trying to justify the Premium $4+ a gallon here in CA lol
Old 11-18-2013, 09:38 PM
BTW, did we ever figure out if there is an easy way to determine if the knock sensors are activating?
Yup. The AKI (which is the average of two different rather loose measurement methods), is a measure of how well the fuel "resists detonation" (under heat and pressure) as compared to a test mixture of 2,2,4-trimethylpentane (aka "iso octane") and normal hexane of the same ratio as the octane rating.
Higher AKI numbers match higher tri-methyl-pentane percentages, hence, higher octane rated fuels resist detonation better than lower octane rated fuels.
Hence, if your engine wasn't knocking to start with, then it's impossible to get any appreciably better performance or gas mileage (at least appreciably more than the error in your measurements) with either fuel, since nothing is, in effect, changing.
Now, IF (and this is the big if), if your engine was knocking, well then, going to a higher-octane rated fuel should noticeably change things, for the better. Of course, the ubiquitous presence of piezoelectric knock sensors makes that assessment difficult, in the rough.
I wonder ... is there any way for us to tell if the knock sensors have detecting knocking in, say, the past FTP?
Old 11-19-2013, 07:16 PM
This related post happened today so I bring it here for cross reference:
Originally Posted by plmadding01e39 View Post
Actually my car costs more than $95.68. Where I am 91 octane is 23 cents more than 87 octane. I usually fill 16 gallons every other week. That works out to $3.68 more for 16 gallons of 91 octane. Filling up 26 times (every other week for a year) this adds up to $95.68. Really not much of a difference and most certainly not the cost of my car.
We worked out many scenarios in the aforementioned thread:
- What is the cost differential between 87 & 91 octane AKI (1)
If you run that math for, oh, say your entire 50 years of driving time, that savings would only be $4,784. If your significant other did the same, the combined household savings would be $9,568.
So, in a lifetime, using the lower-octane-rated fuel, would save you about $10,000 for your household (assuming no loss in MPG - but see the detailed thread for those calculations).
You decide if that's much of a difference, or not.
Old 06-23-2014, 10:03 AM
Over on the E46 forum, a few folks read this thread, and had this to say today:
> 3 Series / 4 Series > E46 (1999 - 2006) > Gas saving chips
Originally Posted by crowz View Post
Well lets look at your study there bluebee. It claims no significant mpg increase from octane increase yet it also states the test didnt include situations where spark knock could occur.
Thats like saying that the fire extenguisher served no useful purpose in our test but we didnt light anything on fire. Duh.
This should explain for anyone why higher octane CAN increase mpg.
Octane raises how far a motors timing can be advanced without spark knock occuring. On modern cars this means how far the computer will advanced timing before it "hears" spark knock thru the knock sensor.
The further you can advanced the timing the more power you get from the same amount of gas. Thus the LESS gas you need to achieve the desired effect.
So in stop and go traffic or climbing hills for example you need to apply less pedal with higher octane fuel to get the same results.
So yes octane CAN increase mpg. Its kinda simple actually.
I think where most get confused on it is they look for octane to raise fuel economy using test where the timing never is pressed into service. Level long stretches. If you never load the engine octane does NOT raise mpg at all. The problem is thats not real world testing. In the real world you hit the point where spark knock can occur quite often. Outside temp, humidity, altitude and engine load all come in to play in the real world applications.
I agree with crowz` evaluation....hemi engines (like ours) by design offer a high level of volumetric efficiency , which in layman`s terms means that they squeeze the most out of every drop of fuel (both power-wise, and economy-wise), and better quality fuel will raise those performance levels.
If you were doing a cross-country run on the interstate, at basically one constant speed and one constant throttle opening, then you could get away with running lower octane fuel with no detrimental effects, you`re just burning it straight through, with very little load being placed on the engine.
Under virtually every other condition, however, the quality of the fuel does have a verifiable effect. Trying to "save money" by running 87 octane fuel is false economy....
To which, I had responded, in part, that the failing here is that NOBODY seems to be able to tell us WHAT our TIMING is at any particular time (due to the knock sensors changing it on the fly).
So, we're all just guessing (with a whole bunch of "if"s)...
I ask anew:
Q: Does anyone know how to tell what the timing is at any particular time on the E39?
Old 07-14-2014, 03:23 PM
In the Techron thread, it was noted that Costco is now "top tier" ...
> E39 (1997 - 2003) > Techron Concentrate Plus is fixing my fuel gauge
Originally Posted by chiefwej View Post
FYI: Costco gas is now Top Tier certified.
I just noticed that myself, where the sign above the pump apparently advertises 5 times the required EPA amount of detergents.
Old 10-24-2014, 07:47 AM
This related thread was updated today...
> E39 (1997 - 2003) > 89 or 91 octane?
Originally Posted by H-Zilla View Post
Hey guys,
For those of you who drive the 540i, what do you put in the tank? Mid-Grade or Premium? Reading in the manual it says that the car requires at least mid-grade, but that you may get increased performance & mileage with premium.
So, with that being said -- does it pay to use premium, or is there any measurable difference between premium & mid-grade?
Thanks in advance for the answer!
See also:
- How to better understand the piezoelectric knock sensor operation (1) & how long does it take the BMW knock sensors to adjust the fuel trim based on the gasoline octane rating of the fuel used (1) & what gasoline octane should we use (1) & how do they measure octane ratings around the world (1) & where is "The Gasoline FAQ" & what are the top-tier gas stations (1) & how large is the fuel tank and reserve in the E39 (1) & how much gas should be left to cool the fuel pump (1) & how can we siphon the fuel out of the tank (1) & what is the cost differential between 87 & 91 octane AKI anyway (1) & whats all this about techron (1) & what are the religious dogmatic camps when it comes to BMW fuel choice (1) & how accurate are our mpg calculations (1) & compendium of BMW E39 emission smog test results (1) & what states make it illegal to sell a car "as is" that won't pass smog or that have an SES/CEL light lit at the time of sale (1)
Old 10-31-2014, 05:44 PM
For the record, there is good octane/ethanol information in this E46 thread today ...
> E46 (1999 - 2006) > Octane boosters?
Originally Posted by John Davis View Post
I live in California where premium gas is only 91 octane, and I wish I could have 93 octane gas.
I'm thinking of buying a bottle of octane booster to add to a tank of 91 octane gas to fix that.
Will this cause any problems?
Will I notice any improvement?
Can anyone recommend a good brand?
See also:
Research into how our Myers-Briggs personality profile affects what BMW motor oil, coolant, and gasoline religious dogma decisions we should recommend when people ask which fluid to use (1) & how to better understand the piezoelectric knock sensor operation (1) & how long does it take the BMW knock sensors to adjust the fuel trim based on the gasoline octane rating of the fuel used (1) & what gasoline octane should we use (1) & how do they measure octane ratings around the world (1) & where is "The Gasoline FAQ" & what are the top-tier gas stations (1) & how large is the fuel tank and reserve (1) & how much gas should be left to cool the fuel pump (1) & how can we siphon the fuel out of the tank (1) & what is the cost differential between 87 & 91 octane AKI anyway (1) & whats all this about techron (1) & what are the religious dogmatic camps when it comes to BMW fuel choice (1) & how accurate are our mpg calculations (1) & compendium of BMW emission smog test results (1) & what states make it illegal to sell a car "as is" that won't pass smog or that have an SES/CEL light lit at the time of sale (1)
Old 04-18-2015, 06:09 PM
An interesting experiment was apparently run today on the E46 M54 engine...
> E46 (1999 - 2006) > My plot to get 93 octane gas in California
California gas stations sell only 91 octane gas, not 93, but there are a few stations that sell ethanol-free 100 octane racing gas. My tank holds 16.6 gallons--round that down to 16 gallons to be safe.
According to my arithmetic, if I put in 3.5 gallons of 100 octane gas and 12.5 gallons of 91 octane gas, I'll end up with 92.9 octane gas, or thereabouts.
Is there any flaw in this plan? Any reason not to do it?
Originally Posted by tristero View Post
Only place I've seen 100 octane gas was at Sonoma raceway, and it was like $8/gal.
Yeah, it's about $8 a gallon. I can get it at a 76 station in Fullerton, near where I work.
If anyone else is interested in trying this, here's a list of gas stations that sell ethanol-free racing gas:
http://pure-gas.org/
The M54`s management system has a certain amount of elasticity built in to compensate for changes in fuel quality, and will take advantage of higher octane (I believe up to about 94 RON) if all systems are operating at max efficiency (i.e., minimal carbon deposits, and a fresh set of plugs). Before your scheduled "Event", I would take the car out on an open highway, where you could safely run it for a few miles at 4500 to 5000 RPMs, to de-carbon everything.
Remember, this engine is a high-compression Hemi that enjoys high volumetric efficiency, especially when properly fed....
RESULTS OF MY EXPERIMENT:
It didn't make any noticeable difference.
I added 3.5 gallons of 100 octane gas to 13 gallons of 91 octane to get the equivalent of 93 octane gas. I'll have to try real 93 octane on a road trip in another state sometime just to see if that does much. It did seem like my engine sounded slightly louder, but that was probably my imagination, since I noticed no other effect.
Maybe I'd notice a difference if I did more to get rid of carbon deposits and put in new spark plugs, as FB suggests. I'm due for new plugs pretty soon.
Old 04-30-2015, 09:54 PM
There is a really good discussion of how to get the most performance out of the fuel at any octane rating over here today ...
91+ should keep you fine on the octane side of things. I prefer 93 personally and that's what I run.
As mentioned the higher the better since a vehicle designed to run 91 octane will end up registering spark knock to some extent on very hot days or hard driving. But your splitting hairs over 91 octane.
There are 2 modes to the knock system on most vehicles. Theres normally a high octane and low octane timing table plus a variable amount the computer will draw out in knock situations that are not enough to push you into the lower octane table. The high octane timing table is where you want to stay. Its basically (doing this to keep it simple) x rpm x timing advance. The high octane table has the most aggressive timing and the computer stays in that as long as the knock sensor counts stay below a certain threshold. If the knock counts are above that threshold the computer switches to the low octane table with has a set of timing numbers that are much more conservative. If it makes it to the low octane table then power drops, mpg drops but the motor is protected. This is why some people claim their car runs just fine on 87 octane or whatever. But in reality its not making racket because its running granny tunes
I simplified it a good bit to try to make more sense.
Originally Posted by sridario View Post
It would really be nice to know what the "allowable window" that Fast Bob referred to is for a stock M54 engine, although 91 - 94 is a good guess and probably correct. I wouldn't say "the higher the better" however, because at some point the octane rating will be too high for the ECU to adapt to and would lead to unburnt fuel - reducing performance, mileage and bad for the cats. I would be wary of running 100, for example, in a stock M54. Modded and tuned race cars are a different matter.
Old 05-01-2015, 02:20 PM
seemyad's Avatar
seemyad seemyad is offline
BMW ****ie
Mein Auto: 530i Sport Package
This is a duplicate post. I will try to delete it if I can.
Old 05-01-2015, 02:21 PM
seemyad's Avatar
BMW ****ie
HIGH OCTANE DOES OFFER BETTER MPG (in some instances) AND LESS STRESS ON YOUR ENGINE
In a nutshell, BMWs have high compression ratio engines (much higher than your average street legal sedan). Our cars have "high performance engines". Low octane gasoline is less stable than high octane. That lower stability will cause the pressure in the BMW engine to ignite the fuel/air mixture more readily and less predictably than higher octane gasoline. Simply put, the pressure produced by BMWs high compression cylinders causes low octane gasoline to ignite prematurely. Basically, low octane gasoline will periodically ignite in cylinder "A" prior to the cam being at the optimum position to transfer that energy. The pressure from the cylinder compresses low-octane gas beyond its flash-point causing it to fire. When this occurs far enough outside of the optimum firing point of a cylinder, drivers will hear a knock. In reality, premature ignition of low octane gasoline occurs far more often than the driver realizes, but it occurs close enough to the optimum firing point that the driver cannot distinguish the off-frequency of the sound. Your engine's CPU tries to adjust for these premature ignitions via the fuel/air ratio which can cause an engine to run slightly less efficiently AND introduces ultra-high frequency vibrations that are not detectable inside the cabin of the vehicle. These vibrations, over time, may add wear and tear on the engine. In addition, the valves may not be in their idea position during premature ignitions.
High octane gasoline is more stable and does not ignite solely by the pressure of BMW high compression engines. It takes both pressure AND the energy release from the spark plug to properly ignite a fuel/air mixture containing high octane fuel. Thereby ensuring the cylinder is at its optimum elevation to receive and transfer the energy of the combustion. This is one reason why people who experience knocking in regular compression vehicles are (were) recommended to use high-octane gas in their car.
Racing cars require even higher octane due to their extremely high compression ratios. The pressure in a race car's cylinder would cause 91 octane fuel to fire long before the cylinder is ready to receive and transfer that energy causing the engine to sputter and misfire.
Old 05-01-2015, 03:57 PM
Originally Posted by seemyad View Post
This is one reason why people who experience knocking in regular compression vehicles are recommended to use high-octane gas in their car.
I doubt any serious mechanic would "recommend" higher octane fuel as a matter of course, for a "regular compression" engine, at least not as a "real" solution.
Only a backyard mechanic would recommend that as a "solution".
If a regular compression engine knocked, the LAST thing I would consider is to raise the octane rating of the fuel consumed.
The FIRST thing I would consider is WHY would a normal engine knock? Something must be wrong.
That something could be the EGR system malfunctioning or the cooling system malfunctioning (hence a hotter combustion chamber); or it could be an immense amount of carbon deposits on the piston head (hence a higher compression ratio); etc.
I really wonder where people come up with these "recommendations", since changing the octane rating of the fuel consumed is never a real "fix" for a broken engine.
Old 05-01-2015, 04:14 PM
FiveDriver's Avatar
FiveDriver FiveDriver is offline
Mein Auto: 1999 528i Blue/Tan
Just to continue this on-going discussion, I would ask -- what effect the ambient temperature might have on engine knock ?? Would colder weather lessen the need for higher octane ?? Is an engine less likely to knock on lower octane fuel in winter or summer ??
Of course, this is a rhetorical question. I just filled up with 93 octane this afternoon and paid $2.69 and $42 for the tankful (I think there's less tax on gas in South Carolina). The mid-grade was 20 cents cheaper and I'm certainly not going to try and save $3 a fillup.
Just for my own information.
VANOS + DISA + 4 KONI YELLOWS + 6 BKR6E's = Damn Nice Car
Old 05-01-2015, 06:05 PM
seemyad's Avatar
BMW ****ie
Agreed. I am referring to a time before CPU controlled engines. I will insert the term "were" into that statement.
Old 05-01-2015, 09:49 PM
Originally Posted by FiveDriver View Post
what effect the ambient temperature might have on engine knock?
Anything that increases combustion chamber temperature or compression can have an effect on knocking (i.e., detonation).
I think that would include a variety of factors, such as...
  1. Too-lean fuel mixture
  2. Malfunctioning EGR
  3. Too high compression (e.g., carbon deposits)
  4. Improper cam timing
  5. Malfunctioning knock sensors
  6. Too much spark advance
  7. Incorrect spark plug heat range
  8. Overheated engine (e.g., bad cooling system)
  9. Overheated intake air (although I'm not sure how that can happen)
  10. Lugging the engine (e.g., being in the wrong gear)
