BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#101
You can buy the FSC Tools program, and try and reverse Engineer it...but as I recall it is about 4000€: http://fsc-tools.com/en/pages/20.htm
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#102
#103
If you are having problems pulling your 1B File, the code can be generated off VIN only.
#104
#105
If you have Navigation working now, and it is a factory Head Unit with FSC Codes and not a retrofit using a CAN Filter, then your VIN is all you need to have your FSC Code Generated.
#106
I remember seeing in another thread that the only difference in fsc codes from year to year is the last 2 letters. Is this true, and if so, would someone be willing to share the last 2 letters of their 2013 code?
#107
That is entirely not true. The whole FSC code is different.
#108
To generate fsc code for map update.It need region code and year code to calculate.
Every car has difference fsc code. |
#109
Nav map 2013
I've got the North American 2013 Map update which requires FSC code base on VIN. There doesn't seem to be a "How-to", so can anyone tell me how I generate the code myself?
#110
You can't without a special software program, and the version that can generate based on VIN only rather than pulling a 1B File is very expensive. You can buy just your FSC Code for $50 though.
#111
Very few guys got the algorithm to generate the FSC code but it not worth scratching the head than buying them for $50 bucks.
#112
Hi all! Can someone help me to get fsc code for NBT 2013 map?
#113
PM sent.
#114
how to pay the activate code.and how to used it
#115
Guys no commercial postings... Please kindly refrain yourself from commercial postings.
One has to be a sponsored member to do so. Thanks for the understanding. Last edited by DreamCar; 04-07-2013 at 08:09 PM. |
#116
I found very usefull your information. I have the 001B FSC file of my car, and I would like to know if you can generate de FSC code for MAP 2013-2 Europe. Best regards |
#117
I have PM'd you a reliable source.
#118
I receieved the code for my new 2013 f10, they had to wait a few days after delivery to give me the code to activate it. Will this code work for 2014 updates and forward.. is it the same for every release? Thanks...
#119
And since you have NBT Head Unit, expect to pay 3x the cost for a CIC update code.
#120
That's a suck... Thank you for the help as usual...
#121
Hello sorry to bring this thread up again but kindly I need some advice
I have a F30 with navigation professional, when i press navigation it ask me to enter activation code via I drive letter circle. The dealer is being very lazy in activating this for us owners, it has been 7 months and they still say wait I would like to make it work if the cost is not too high. By the way I am in Egypt and would need the Egypt map. Any ideas where to start? Thanks Osoliman |
#122
#123
It's HU CIC. You just helped me install BMW apps man thanks for all your help
#124
See if you can pull your 1B File from CIC with SWID Reader, and let me know.
#125
![]() I used E-sys to get the FSC ststus check in case that helps till I manage to do the VM thingy --> Read the state from "2" ECU(s) <-- EPS[DiagAddress=48] RootCertStatus not available SigSCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 131 UpgradeIndex 1 SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available HU_CIC[DiagAddress=99] DAB3F55030J058603 RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 23 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 25 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 27 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 111 UpgradeIndex 1 SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 156 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 155 UpgradeIndex 1 SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 40 UpgradeIndex 4 SWTType SWTshort FSCStatus not available FSCCertStatus not available Last edited by Osoliman; 06-15-2013 at 12:55 PM. |
| Tags |
| activation code, maps |
