Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 02-13-2013, 06:18 AM
pcy pcy is offline
Secondary air pump/injection system on N52
Hi,
On all the cars I've owned, typically, there is a secondary air pump and valve(s) to control the secondary air injection - to speed up the warm up process during first minute of cold start.
I am not able to locate secondary air pump or or related hoses on N52B30 ('06 530i). Do any of you know where the secondary air pump is? I already went thru RealOem site and I looked thru TIS, none of them show secondary air pump.
Old 02-13-2013, 06:34 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
They dropped the secondary air pump on the N62 for the X5 also. There is none on the E60 N52. My guess is the combination of the charcoal filter above the intake muffler and an advanced fuel preparation system.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 02-13-2013, 07:54 AM
pcy pcy is offline
Thanks for confirming that.
I am not sure how the charcoal filter (inside the air filter box) helps warm up faster. What fuel preparation are you referring to? (just trying to understand)
Old 02-13-2013, 08:24 AM
boramkiv's Avatar
Propellers Up Front
Well that was a guess because the secondary air pump injects fresh air into the the exhaust stream for better emissions. Turns out I just learned the exact reason why the N52 doesn't have a pump. I'm living in the past because we have catalytic converters now (which I knew but didn't think about).
A good read here on page 26:
http://www.e90post.com/forums/attach...6&d=1331856881
Old 02-13-2013, 09:06 AM
pcy pcy is offline
Excellent document. Thanks for sharing that link.
