Old 02-11-2013, 01:01 PM
nitrydr1600 nitrydr1600 is offline
Mein Auto: 1997 z3, 1982 corvette
97 z3 power seats in- op
97 z3 powerseats move back and forth but no up and down angle movement. seems like something froze up and just keeps clicking. any ideas?
Old 02-12-2013, 08:48 AM
Trapper Trapper is offline
I'd rather by driving
Mein Auto: 2003 Z4 2.5 Titanium Silv
Do you hear the motors running and a clicking sound? If so you might have broken or stripped the drive pin between the motor and the gearbox. Put you hand under the seat on the motor that drives the up/down mechanism and push the button, you should be able to feel the motor running and if you also feel an abnormal vibration it may help you pin point your problem.
I have a 03 Z4 and just had to do a seat repair. On mine a bull gear in the gearbox was stripped. I could hear the motor running but no seat movement.
Old 02-12-2013, 09:00 AM
moves back and forth fine. just a click in the up and down motion like the pivot points are froze up. not the switch for sure
Old 02-14-2013, 10:45 PM
atopa2002 atopa2002 is offline
Mein Auto: 2009 e90 335i
[QUOTE=nitrydr1600;7376385]moves back and forth fine. just a click in the up and down motion like the pivot points are froze up. not the switch for sure[/QU
You have to check if the motor is working by connecting it to a car battery, if working, then the fault could be with the moving parts, that is the long screw, it can rust and lock it self, so the seat have to come out, clean all the moving parts with a metal brush and 40 wrench liquid and lubricate with lithium grease
Good luck.
Old 02-15-2013, 04:52 AM
thanks guys. this car has been a nightmare from replacing the motor to window,4 way, driving,asc, switches, heatlight bulbs . Starting to think it was a catrina victim as i dont know the history. thanks for the help
