Old 02-14-2013, 09:29 AM
stanggt stanggt is offline
Mein Auto: 98528i
low compression?
Hi guys, I have a 2007 535i with 283k miles. was running good and then started gradually running rough. was going to go through and replace all ccv and disa and 02 sensor and it got to where it wont start. here is my compression, 50-150-105-50-8-75. could this be due to the vanos going bad and clocking the cams wrong or something? or should I just part this thing out it out, the car is still very nice. thanks
Old 02-14-2013, 09:34 AM
rdorman rdorman is offline
Mein Auto: 2000 imola red 740i Sport
50-150-105-50-8-75, Really? Not a typo? Motor is toast. Figure what is bad, if not multiple things and decide where to go from there.
Old 02-14-2013, 10:07 AM
HPIA4v2 HPIA4v2 is online now
Mein Auto: E60, E71, E92
Are you sure it's 535i, cause BMW don't make 2007 535i.
I thought compression test is done when engine is off, no? so it's hard to say if vanos is bad.
Old 02-14-2013, 11:24 AM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
I was thinking the same thing. Also wondering how you managed to put 283k miles on an 07 or 08 car, I had my 2005 530 for 5.5 years and only managed 60k miles - and I live in L.A.
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 02-14-2013, 11:27 AM
JoeFromPA JoeFromPA is offline
Mein Auto: 01 M5, 08 535xit
Plenty of people drive 50k a year if they work in sales or similar roles.
OP - Inspect for carbon build-up on your valves. If your valves aren't seating, a compression test won't hold much water. Assuming you actually own a twin turbo series BMW, carbon build-up is well known. After that amount of mileage, you could be experiencing severe carbon build-up issues.
Old 02-14-2013, 11:38 AM
Stephen Max Stephen Max is offline
Mein Auto: 1998 M3, 2004 545i
If it was a cam timing problem, then you would get low compression across the board, not just a couple of cylinders.
Old 02-14-2013, 12:37 PM
Mac Hadley Mac Hadley is offline
Nac
Mein Auto: 535XI, 328I
Correct that there were no 535i 2007 models. Maybe he bought the 535i in 2007, as the 08s were available in 2007...
Old 02-15-2013, 06:41 AM
Mein Auto: 98528i
sorry,its a 525i and no its not a typo lol. I drive all over the country. made the trip back to mid-michigan from toledo ohio with it the night I shut it off then the next morning went to start it and it ran real rough and then quit. would not start after that.
Old 02-15-2013, 07:04 AM
Did you ever have an overheating problems, prolong drive in that condition (maybe due to bad water-pump/thermostat)? Just a wild guess.
Old 02-15-2013, 08:18 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
With that many miles, it's time for a rebuild - rings are probably worn out as are the rod and crankshaft bearings. There is a big difference in a 525i and a 535i but either one would need a rebuild with those miles.
Old 02-15-2013, 09:00 AM
Any smoke? If there is a rough idle, and what seems to be misfiring in some cylinders, then there must be other symptoms that can help in a diagnosis.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 03-23-2013, 04:33 PM
Mein Auto: 98528i
I put a good used motor in the car and everything went together very nicely but it does not crank over like the starter is not getting the key signal. triple cked evrything and its all hooked up properly. What I did notice was that the digital idicator on dash for PND 54321 says S and 4 is high lited like its in 4th gear. shifter linkage is working fine and all but woundering if that is why it wont crank over. any thoughts.
