Old 04-26-2012, 03:08 PM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
F30 BMW 328i 335i Front Kidney Grill / Grille removal and replacement DIY
F30 BMW 320 328 335 Front Kidney Grill / Grille removal and replacement DIY<br />
Replacing the front grills on your F30 BMW 320, 328 or 335 is an easy and quick project, taking 15-20 minutes going slow and carefully. Adding black front grills dramatically changes the look of the F30 3 series and is a great first modification.
Tools needed
  • T20 torx bit
  • T30 torx bit
  • Pick or small screwdriver
1) Pop the hood and removed the front hood seal by pulling up. It is a friction fit and pulls off easily.
Click image for larger version<br />
<br />
Views:	0<br />
Size:	166.2 KB<br />
2) With the seal removed you'll see the 6 T30 torx screws. Remove these and set aside.
<br />
Views:	0<br />
Size:	145.9 KB<br />
3) Remove the two T20 screws, one on each side that screw into the top of the headlights.
<br />
Views:	0<br />
Size:	159.4 KB<br />
4) Gently pry the top of the bumper up and forward so you get access to the back of the grills. Wedging a flash light into the gap will give you room to work and light to see the clips on the back of the grills.
<br />
Views:	0<br />
Size:	182.1 KB<br />
5) The grills are held in with three clips across the top, one on each side and three on the bottom. Use a screw driver or pick tool to push in the release tabs on the grills while gently pulling out on the grills. Go slow and work your way from inside to out one clip at a time.
<br />
Views:	0<br />
Size:	172.7 KB<br />
You can see the clips clearly with the grill removed
<br />
Views:	0<br />
Size:	132.5 KB<br />
6) With the first grill removed you can remove the second one by working through the grill opening. This is considerably easier then working from the top. Again work one clip at a time while pulling lightly on the grill from the front. Work your way around until the grill pops out.
<br />
Views:	0<br />
Size:	166.1 KB<br />
7) With the grills removed the hard part is over! Unpack your new F30 M Performance Parts black out grills from TMS and pop them in. They snap right in.
<br />
Views:	0<br />
Size:	181.7 KB<br />
ID:	322599 Click image for larger version<br />
<br />
Views:	0<br />
Size:	169.0 KB<br />
8) With your grills snapped in place we need to reconnect the top of the bumper. In addition to the torx screws removed above there are four metal clips that hold the bumper in place and two tabs on the headlights. Make sure you slid the top of the bumper under these clips and tabs.
<br />
Views:	0<br />
Size:	150.1 KB<br />
ID:	322597 Click image for larger version<br />
<br />
Views:	0<br />
Size:	153.3 KB<br />
9) The hood seal has a U groove on the back that snaps onto a ridge on the bumper. Work your way across snapping the grove onto the ridge. The seal also snaps on the headlights.
<br />
Views:	0<br />
Size:	95.7 KB<br />
10) You're done. Stand back and enjoy the new look of your F30!
Thanks to Turner Motorsport for the parts and Jay and Derek for the installation help.
ID:	322596   Click image for larger version
ID:	322598   Click image for larger version
ID:	322601   Click image for larger version
ID:	322602   Click image for larger version
ID:	322603   Click image for larger version
ID:	322604   Click image for larger version
ID:	322606   Click image for larger version
Old 04-26-2012, 03:44 PM
justinnum1's Avatar
justinnum1 justinnum1 is offline
Mein Auto: F30 335i mSport
Nice write up!
looks like a lot of work tho, and some of those tools, i dont have lol
maybe i can get the dealer to do it for me
Old 04-26-2012, 05:00 PM
utnuc utnuc is offline
Mein Auto: 2013 MG 328i Sport 6MT
Looks awesome. Are they plastic like the originals, or metal? I have to say I was surprised when I went to touch the 328i sport grill and it was plastic. Do you have a before/after pic?
Old 11-11-2012, 05:59 PM
Cbinc Cbinc is offline
Mein Auto: What I can steal
Made the Change
I received my F30 a few weeks ago. For those that think this is a bit difficult or involved; it absolutely is not. It's actually very easy if you follow the great instructions provided by Tim330i. It may seem like a lot but it's only because he's spelled out every little step in detail. It took me 15 minutes to complete and I was taking my time so I wouldn't scratch the paint. I'm sure someone with more experience could do it even faster. My before and after pictures below.
Old 11-11-2012, 06:00 PM
justinnum1's Avatar
they looks so great in person
F30 328i Alpine White/coral red Msport 6MT, HK, Xenons, Msport brakes, black grills and side sills, performance exhaust
Old 11-11-2012, 07:52 PM
LarryboysUDM's Avatar
LarryboysUDM LarryboysUDM is offline
Apay Kapoy
Mein Auto: 1335i 02RSX5MT 06ML350
Nice before and after.
I would say the front end would look better if the tag was in the middle and just below the grill instead of being off to the left side.
My 1st BMW-bought fr inbound inventory: Munich '13 F30 335i, RWD, Alpine White, Black Leather, M-Sport, DHP, Prem Pkg, Tech Pkg, 403M (Potenza S001 RFT 225/40, 255/35 R19), Sport Auto w/paddle shifters, Heated front seats, Harman Kardon, Aluminum Hex Trim/EB accent, Anthracite headliner
Std: Xenon Adaptive Headlights, Sunroof, Alarm
Mods: Tint 35%, DIY lower intake grill guard, BA Standard Coding
56K mi Apr'17
Hergestellt in Deutschland
Old 11-11-2012, 08:42 PM
I was back and forth about this myself. I decided on the tow hook hole because I just couldn't bring myself to drill holes into the bumper.
Old 02-15-2013, 06:36 AM
F30 MSPORT 335i F30 MSPORT 335i is offline
Mein Auto: 2013 F30 335i XDrive
Very easy as per instructions and photos - Took me 35 minutes. thanks
Old 02-15-2013, 06:46 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
ive seen the bimmerfest f30 around the boston area, arent you afraid you're going to get pulled over for not having the front license plate. cops around here are ruthless about that.
also has anyone done this on both an e92 and the f30. The e92 was a real pain and I couldnt get the damn thing off myself, i tried a screwdriver, poker ting, even a butter knife. The tabs just wouldn't budge. have they made it easier at all?
Old 02-15-2013, 07:36 AM
everettpa1 everettpa1 is offline
Mein Auto: 15 335xi EB2, 14 F150
How would the blacked out grille look on a black car?
Old 02-15-2013, 08:20 AM
chris328's Avatar
unbekannt
some people love it but i think it basically camoflauges the entire front end
Old 02-15-2013, 09:50 AM
IndyMike's Avatar
IndyMike IndyMike is offline
Elected by grace
Mein Auto: 1 Series M Coupe
Seriously, pull the bumper up and forward?
Since there are merely clips holding it (which is similar to the E82 grill), you just put both hands into the grill slots on the left and right edges and yank it towards you to remove.
Then to insert the new grill with your hands in the same location push it in until you hear it seat.
Zero tools needed, 30 seconds elapsed time.
At one time I actually had 3 separate grill sets; the stock one; one with painted surrounds; and a black matte one. I was constantly swapping them out once I got tired of the look.
Like a female trying to decide what hairstyle looked better, I was always changing my mind after a while.
If I had to do this DIY instruction each time it would be a one time deal.
The path to God is clear, and it takes us to the cross.
Old 02-15-2013, 10:23 AM
chris328's Avatar
unbekannt
did you ever do an E92? Mine was so damn difficult. Just gave up after trying like 5 times. Maybe I was just being too cautious and didnt want to break anything.
Old 02-15-2013, 11:36 AM
IndyMike's Avatar
Elected by grace
No. My wife has an E91 and I want to swap her's out with shadowline one's, but she gave me that look that basically said "don't even think about it", so even though it's reversible I never pursued it.
I think underlying is that she knows once I get started I find it hard to stop tinkering with it.
Unless you have plans to sell the old stocker grills or reuse them later it's worth a shot to use the old yank 'em out method after you tried the finesse approach.
Old 02-15-2013, 11:56 AM
Dingers 335i Dingers 335i is offline
Mein Auto: F30 335i
Thank you for taking the time to post this. I had the dealer install my grilles. I knew it was an easy install but, didn't want to mess up my car knowing my past experience! I will return here when I decide to reinstall my OEM grilles.!
F30 335i
Old 09-12-2013, 12:21 PM
Hsaldain Hsaldain is offline
Mein Auto: 2014 BMW 328 M Sport
Great DIY!! it took me 10 miutes to change it on my alpine white 328!!
Thanks!!
Old 03-17-2014, 10:12 PM
Astronomy Astronomy is offline
Mein Auto: 2013 F30 328xi
Hey guys just installed my new grill, then i noticed that the hood is now misaligned by about 1 or 2 millimeters. I also noticed that while i was gently getting my hand through the gap to get to the grill clips, the whole bumper and light assembly was also flexing. The BMW dealership said that i may have voided my warranty by simply replacing my grill... Should i worry about water leakage or electrical water leakage? Any advice guys? it was a simple job and i was very careful and i didnt break anything. I tried literally 30 times to try to realign the hood with the emblem scoop
Old 03-17-2014, 10:24 PM
rodmexico rodmexico is offline
Mein Auto: 428i
waths the diference i got mi 428i sport line ones tinted in glos black and mate and it seem the same.
are they the same as the sport line but black?
Old 03-18-2014, 07:38 AM
tim330i's Avatar
That is really strange that you can't get it to line back up, it sounds like it might be sitting over a clip or something. I would take everything apart and start again.
There is no single 'vehicle warranty'. Lets say down the road you have trouble with your suspension, changing your grills had nothing to do with that so it will not void your suspension warranty. Now if you had changed your springs that would be reasonable. Make sense? That is a really bold and annoying claim from your dealer.
Old 05-19-2014, 09:36 AM
shinsverk shinsverk is offline
Mein Auto: 328i xDrive 2013
It looks like the grill can be removed from the front by working thru the hole after getting one of the grilles off. Is this correct? If so could you not just destroy and cut out the 8 slots on the old sport grille and put your hand thru it to do the removal.
325i/06,Arctic,Black,Aluminum,Premium,Sport,Cold,Step,X ,CA,SunShd, At Dealer Center(Pick up Feb 15).
Old 05-19-2014, 10:04 AM
tim330i's Avatar
Yes, but why?
Old 05-19-2014, 10:31 AM
pflau pflau is offline
Mein Auto: BMW 328i xDrive
Yeah but after you cut out all the slates you might find it hard to remove the grill frame because you have nothing to hold on to.
Old 05-19-2014, 10:33 AM
I am still looking for a easy, sure fire way to remove my grills within touching the bumper. I got a pair of replacement ready.
Old 05-19-2014, 11:35 AM
I looked at it closer over lunch and I can reach thru the grille and touch the clips. If I cut just two of the eight slots I could get my hand behind the grille and I would only damage the one grille I cut. This just seems so much easier then pulling my bumper off on top.
Old 07-14-2014, 09:37 PM
pickupjason pickupjason is offline
Mein Auto: Mazda3 Hatchback
No need to remove the bumper. I just loose the tabs and pulled it out from the front. Look at the tab of the replacement grill and you will be able to tell "where" and "how" the loose the tabs. Got first one out in 5 min while wife is watching. the 2nd one is easy since I have access from the back of the grill.
Jason
black out grills, bmw f30, f30 3 series, f30 black out grill diy, f30 diy, f30 mods, m performance parts
