Old 02-15-2013, 04:22 AM
ssollars ssollars is offline
Mein Auto: 1996 z3
New top installation
My new top is a robbins top with all of the oem upgrades. Robbins cannot tell me what the proper installation of the straps for quarter panel relief pockets is.
I have searched this forum and the internet to no avail. Would appreciate some help with this. Early 1996 z3
Old 02-15-2013, 05:55 AM
ashevillez3 ashevillez3 is offline
Mein Auto: 2000 Z3 2.8 Roadster
Sorry I can't provide an answer. I'll be interested to read the replies to your question as I'm having a debate in my head about if I should attempt to install myself or pay someone.
Old 02-15-2013, 06:22 AM
Monolith Monolith is offline
Mein Auto: 1997 Z3 1.9L DASC Auto
Does Vinci's diy instructions for the OE top give any clues? Is Robbins that different?
Old 02-15-2013, 07:09 AM
Mein Auto: 1996 z3
Top install
I probably have seen them,but could you direct me to them to make sure.
Old 02-15-2013, 08:13 AM
Mein Auto: 1996 z3
Old 02-15-2013, 09:48 AM
http://webspace.ringling.edu/~dplassma/str/str.html
Old 02-15-2013, 10:17 AM
Mein Auto: 1996 z3
It was one of the sets of instructions i researched and followed. I do not think that top had the relief pockets with the additional strap on each side.
I have a couple of ideas about how they could be attached, but would rather not guess.
By the way, i have used this site extensively. This is my first bmw and the people who contribute to this site have made a huge difference with their info.
Thanks to all.
Old 02-15-2013, 10:35 AM
Just from some general searching, BMW did not have relief pockets until 1997. I'm wondering if that might be part of the problem since you have a 1996. I'd look at my factory top but it's down and covered with a hardtop until spring. Robbins seems to sell a version of their top with and without the relief pockets.
http://www.convertibletop.com/blog/b...tible-top.html
Old 02-15-2013, 11:51 AM
vintage42's Avatar
BMW CCA 1405
Are not relief pockets just watertight side vents to allow flow-through ventilation, and also release cabin pressure at speed? How do they affect installation of the top?
Old 02-15-2013, 12:26 PM
Mein Auto: 1996 z3
There are several upgrades that bmw did to the top itself and then some others that are year specific. If you look at several of the top manufacturers, they all reference the top upgrades. I think the relief pockets and several other items have to do with how the top folds into the well and affect window creasing
and other problems. The quarter panel relief pockets have an elastic strap attached which would apply tension when the top is up and be relieved when stowed. This is the only question i have left with this top install. It was all straight forward except for this one problem. By the way, the robbins top without the upgrades is their economy top. My top is a model r-2750cblb.
Old 08-20-2015, 01:21 PM
wozt wozt is offline
Mein Auto: 2000 BMW Z3
Did you ever get an answer to your question about the relief pocket straps? I just put the same Robbins top on my 2000 Z3 and I don't know if the straps gets glued to the support bracket or clamped under the window weather stripping frame.
Old 08-20-2015, 03:28 PM
Mein Auto: 1996 z3
Robbins top
No. What I did was wrapped the strap around the frame support just ahead of the strap. Used double sided tape to keep it in place. Folded the top just a bit to put some tension on the strap. I had misgivings about putting it under the frame because of the thickness of the strap.Seems to be working well. Talked to Robbins and others and never got an answer. Hope this helps.
Old 08-21-2015, 07:13 AM
vintage42's Avatar
BMW CCA 1405
... I think the relief pockets and several other items have to do with how the top folds into the well and affect window creasing and other problems...
I think the "relief" feature of the pockets refers to air pressure. The vertical slits on each side of the top are for relief of air pressure.
The early tops such as mine do not allow air to easily escape the cabin. There is poor air flow in the ventilation system because of cabin pressure. The addition of the vent openings relieves the pressure and provides better flow-through ventilation.
