Old 02-15-2013, 07:21 PM
kizz23 kizz23 is offline
Mein Auto: 2008 535xi Sedan Auto
No problem I was a new to it before this great forum and people willing to share info. I went with the legal 35% because I was told it would look dark regardless with black on black. I regret it tho I wish I went with 20% if not at least on all rear windows but I guess I don't have to worry about getting pulled over by police or passing a state inspection.
Old 02-17-2013, 05:56 AM
gurpreet123 gurpreet123 is offline
Mein Auto: 2008 bmw 535xi
also the tpms you have, is it wireless for the 2008 bmw 535xi because oemwheelsplus are going to install them and mount/balance the tires for me. They said all i have to do is take it to a garage shop and have them change the wheels. Is it true are the tmps wirless or do i have to connect something? Also how do you know which rear tpms goes on the left of right rear of the car when i get them or does it even matter which one goes where? please reply thanks
Old 02-17-2013, 08:38 AM
They are wireless sensors, no programming. All you need to do is reset your TPM, there is a setting for it in your heads up display under tires. You have to reset while your stopped and then just drive. Of course after you set the psi to your desired level. The computer automatically knows which one is where. Just make sure your tire with the biggest offset of 9.5 are the rear tires but any time shop should know this.
Old 02-17-2013, 09:01 AM
the setup you have is staggered right? and has it affected the cars torque,speed,mpg,and does it feel heavier or sportier? also the ones you have are 19" right?
Old 02-17-2013, 06:12 PM
Yes 19"staggered, no problems.
Old 11-24-2014, 11:20 AM
LDWG LDWG is offline
I'm looking to do something a bit less radical; just want to know what larger-diameter rims will fit the 535xi sedan without sport package?
Old 04-14-2015, 09:46 AM
WethVento WethVento is offline
****ie
Mein Auto: 1996 Volvo 850
2010 BMW 535xi 6MT MTech stock wheels ... whats the offset???
the pictures are of the markings on the back of every spoke, there are no more markings on these wheels. I know the xi should have high 30s to low 40s offset, but theres no such numbers on these wheels :/ im wicked confused ... and i believe these are the stock wheels that came on the car from the factory.
again, the vehicle in question is 2010 BMW 535xi 6MT mtech package
Can someone please decipher all the numbers on these and maybe which one is offset number. But i know offset is usually with ET ... no?? and theres no such thing :/
Are these 192 style?
Thanks all
Old 07-17-2016, 12:21 PM
dbenson dbenson is offline
Mein Auto: 93 e34 M5. 08 e61 3.5
Chamix,
Where these wheels from an e60 M5 or did you find a set from a non-M e60/61? Thanks for the help.
db
