Old 02-14-2013, 02:12 PM
albertoxikitin albertoxikitin is offline
Mein Auto: bmw e63
led bulbs for my front turn signals
Hi everybody. I would like to know where can i buy some led bulbs for my front turn signals. Also want to know what model are they and how difficult is to replace the oem bulbs. Thanks.
Old 02-14-2013, 03:35 PM
roseng's Avatar
roseng roseng is online now
Here's where I got mine.
Old 02-15-2013, 05:29 AM
Mein Auto: bmw e63
Thanks Roseng
Old 02-15-2013, 05:32 AM
Mein Auto: bmw e63
Originally Posted by roseng View Post
Very difficult to install.????
Old 02-15-2013, 07:32 AM
roseng's Avatar
Not hard, but it's pretty tight in there. I had my teenage daughter help (small hands) me because it was that tight.
The front turn signals have 3 bulbs each. The 2 small bulbs in the corners parking lights and are tough to get to but you can leave them.
There are 2 turn signal bulbs in each housing. One is towards the front with a small metal clip to help access. The other is easier to get to get to from the wheel well panel.
If you really want to do it right you either have to pull the bumper and the light housing and replace all bulbs, or pull the bumper and upgrade to the LCI all LED oem housing.
That's what I did after trying the LEDs. For the LCI you also have to build a custom wiring harness with the diodes, and code out the errors or use a loading resistor. Expensive but a great upgrade.
BTW, you'll spend $70-100 for the 4 bulbs. The cost for the LCIs is about $525.
Old 02-15-2013, 07:36 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Where did you get the LCI's from? I want to get those too!!
Did you wire it up yourself? Also if I need to code it what code cable system do recommend?
Sent Via iPhone using BimmerApp
Old 02-15-2013, 08:46 PM
roseng's Avatar
I bought the LCIs from Tisher. You also need the connectors and wires, total about $550. Once you have everything you need to build 2 wiring harnesses that includes some 1N4004 diodes.
Not too hard to do, you can do everything in 3-4 hours. Are you handy with a soldering iron?
You'll need to code out the errors for the LEDs. It will work fine without coding but you'll get a bulb out message. Do you have NCS?
Where are you in CA, north or south? I may be able to help.
Old 02-15-2013, 08:54 PM
Nitrogen's Avatar
I am very good at soldering worked on electronics in silicon valley for years.
I don't have the means to code out yet as I want to purchase the correct item.
NCS? I'm northern cali central really in Modesto.
Old 02-15-2013, 08:59 PM
roseng's Avatar
Give me a day or so and I'll get the ordering info, and the wiring diagrams.
You'll need to pull the front bumper for this one too. If you have not done that yet it's not that scary.
Check the BMW coding forum and see if anyone near you does coding. I get north often so I might be able to do it for you.
I think its one of the best upgrades you can do.
Old 02-15-2013, 09:19 PM
Nitrogen's Avatar
Sounds good! Thanks! I'll provide the beer. I have access to a shop and tons of snap on tools if needed and a body shop.
I really need to learn this coding stuff just need the right cable and software.
Old 02-15-2013, 09:25 PM
roseng's Avatar
Sounds good.
You really don't need a body shop at all. Some common sens and reading on these forums and some personal tutoring from Zerocks1 is all I needed.
Read this thread to get a great start on coding
Old 02-16-2013, 08:01 AM
roseng's Avatar
Links to LCI upgrades.
Here's where I learned about how to do this.
And this has the wiring diagrams
Part numbers from Tisher
63137176871
OEM BMW E63/64 LCI Facelifted LED Front Turn Signal Lenses
1
$0.00
$250.00
$250.00
63137176872
1
$0.00
$250.00
$250.00
61130005199
Bushing (These are the actual wires that get inserted into the plug)
8
2.20
$17.60
51718170298
PLUG
2
$0.00
$0.36
$0.72
Have a read and let me know if you have questions.
