E34 (1989 - 1995)
Old 02-09-2013, 05:41 PM
NAVYMAN NAVYMAN is offline
Mein Auto: 1994 525i
94 525i coolant air bleed valve
Ok guys, I'm a littled puzzled. No, I'm a lot puzzled. Added a little coolant (distilled water), & just for grins, I decided to go ahead and bleed the air just in case. I want to state at this point that the car is running very well. The temp gauge is solid on the middle mark and does not ever overheat. However, when I went to bleed it, no air, no water no anything came out of the bleed valve. WTF is going on?
Old 02-09-2013, 10:02 PM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
You have no air in to your system. Imagine opening the expansion tank. And then closing it. No added air.
Sent from Joe's Galaxy SIII via BimmerApp
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 02-10-2013, 03:16 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
This ^ +1
Sent from my Desire HD using Bimmer App
Old 02-10-2013, 05:05 AM
Mamij Mamij is offline
Mein Auto: BMW 320i M52 1996
Were you adding water all the way to the top? ? Air bubbles and then water MUST come out. There is not enough coolant to full capacity. Turn your cabin heat to high, idle the cold engine until it reaches hot. Then pour water until it comes out of the bleed valve, while the engine is on. Then bleed as per normal.
You may need many litres. Repeat tomorrow. Then repeat 1 week later. Drive in between. If you still need alot of water at the last bled, something is wrong.
Old 02-10-2013, 08:53 AM
Let me add little something. I had the water pump replaced & the system flushed & bled by a very competent BMW technician about 6 mos. ago. The amount of water I added was less than a quart & I followed all the above mentioned procedures just as the Bentley manual indicated. All other vehicles I have ever bled the air from had solid water spewing after all the air was evacuated. It seems to me that the cooling system pressure should push hot water out of the bleed valve even if there is no air in the system. Is it possible the bleed valve is clogged, & will I damage anything if I push a thin wire down the bleed valve orifice to check it?
Old 02-10-2013, 06:06 PM
BMWFatherFigure's Avatar
Old School
Thin wire fine to unblock. Do it cold - you don't want a face full of by-products.
Current:
Previous:
Old 02-14-2013, 01:40 PM
I pushed a thin piece of wire thru the orifice and just as I suspected, it was clogged. It is now opened & working correctly.
Old 02-14-2013, 01:54 PM
Monsignor's Avatar
excellent. thanks for the update, glad you got it working!
2006 325i/6 48k mi
Garden State Euros
Old 02-17-2013, 07:37 PM
padgettba padgettba is offline
where is the bleeder valve located
Old 02-17-2013, 07:39 PM
Old 02-17-2013, 08:13 PM
Monsignor's Avatar
Depends on what engine you have...
2006 325i/6 48k mi
Garden State Euros
Old 02-17-2013, 10:22 PM
Mein Auto: 1989 525i M20B25
For future reference:
That should have been the first red flag for a blocked bleeder.
