Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - Current)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 02-10-2013, 05:07 PM
Par4 Par4 is offline
Mein Auto: '09 SL550
Just had my car coded- something you should consider.
Ok, so I've had my car for a month now, and have put about 2k miles on it. I figured it was about time to get rid of the minor annoyances that come with the 6. So I met up with Steven (CN555IC) in Brooklyn today and in 1/2 hour he hooked me up with:
-start stop set to last setting
-electronics off when car is turned off and door is opened.
-passenger side view mirror tilts down better in reverse.
-Turn signals show in HUD.
-Mirrors flip up when doors locked with key.
- No more seat belt bell.
- No more I drive warning.
- heat/ac set to last setting on restart.
- DVD works when moving.
- tire pressure sensors show temp of tires and individual pressure.
-rear drl
- Also the top goes down quicker.
Individually not one is a big deal, but all in all a Sunday well spent.
David
'13 650xi 'vert.
Old 02-10-2013, 05:14 PM
ShakeDaddy's Avatar
ShakeDaddy ShakeDaddy is offline
Mein Auto: 2013 650i Coupe
Congrats on your coding, a day well spent. I would like to do those types of coding upgrades as well.
2013 650i Coupe N63TU
Original Owner-Delivered 10/2012
M Sport/Imola Red
Individual Full Leather/Opal Merino
20” 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
//RFT No Mas\\ HP Summers Only
Hankook Ventus V12 Evo2
Old 02-10-2013, 05:55 PM
mrjoed2 mrjoed2 is offline
Mein Auto: 650 M coupe, Infiniti Q50
Par4,
I am guessing you mean the the mirrors fold when the doors are locked? And what does the climate control default to without coding on a restart? I would think it would be last used settings.
Old 02-10-2013, 06:20 PM
It always defaults to air conditioning on
And yes. Mirrors fold when doors locked with key.
Old 02-11-2013, 08:59 AM
djsaad1 djsaad1 is offline
Mein Auto: range rover
Did he code entertainment/phone list in HUD? I really like having that in the hud, never have to look down.
BTW if anyone is in Texas and wants to stop by Austin, I would be more than happy to help you code.
Old 02-11-2013, 09:58 AM
krischapel krischapel is offline
Mein Auto: 2012 640i Alpine White
That is pretty sweet. Where can I get that done at? Will the dealership do that? If not does anyone in SoCal know how?
2012 640i Alpine White, M Sport, LED Headlights, Premium Sound, Ceramic Controls, HUD, Lane Departure, Contour Seats, Blind Spot
Old 02-11-2013, 10:14 AM
ShakeDaddy's Avatar
Got to head over to the 3'er and 5"er board and find some local coders.
M Sport/Imola Red
20” 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 02-11-2013, 10:28 AM
dunderhi's Avatar
dunderhi dunderhi is offline
Next: '18 AMG GT Roadster
Mein Auto: 15 M6 vert, 15 328dxt
A fellow fester, DreamCar, coded my 550 with many of the same options. I have the software and the cable, so I'll take a crack at it after my car is redelivered. I was really hoping to remove the speed limiter while in Germany, but none of the fest's coders have had any luck thus far.
BMWs
2015 M6 Drophead Coupé
2015 328xd Estate
2013 X5M Sport Utility Vehicle
2013 650xi 2 Door Fastback Saloon
2011 Dinan 5 Saloon
2011 335d Saloon
Old 02-11-2013, 04:03 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
-rear drl
David
'13 650xi 'vert.
I used Alex from AlpineMSS for both my 7 & 6 and he did a great job! You can email him;
alex@alpinemss.com or check out his website at www.alpinemss.com
Here's a list of what he can do for you and the best thing is you just have to have a WiFi connection, PC computer, and some files as well as connecting cable to car that are included in his price... He's located in California but can code your car in your driveway:
-Removal Of Seat Belt Chimes
-Removal Of Seat Belt Warnings
-Windows up/down with key
-Windows up/down with comfort access (Comfort Access Required)
-Folding Mirrors with key
-Folding Mirrors with comfort access
-Unlock doors when engine is turned off (Single pull on door handle)
-Removal of CIC Accept Warning (faster boot up after removal)
-Activate DVDinMotion (Play Videos on the go and stopped)
-Removal of camera warnings (requires cameras)
-Add Fuel Stop Proposals
-Remove window safety feature (windows will not stop rolling if door is opened)
-Remove Amber Side Marker Lights in headlights (Euro look)
-Fogs on with High Beams (Fog Lights will not turn off when high beams or used)
-Fog Lights on when car is unlocked
-Open and "close" trunk with key and inside trunk release button (requires power lift-gate)
-Add Digital Speed in Center Cluster
-Auto stop feature off when car is turned on
-Auto Climate Control off when car is turned on
-Digital Number Display For Tire Pressure Monitor with Temperature
-Remove speed limitation on camera's so they can be turned on at any time
Some of the features are dependent on the car options and type... obviously you can't open/close trunk unless it's motorized! Also the tire Pressure/Temp is hit or miss depending on the manufacture date of the vehicle (Doesn't work on my 7 built 11/11 but does on the 6 built 2/12)
Good luck!!!
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 02-12-2013, 11:51 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
what are rear drl?
Daytime Running Lamps? So, your tail lights are always on?
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 02-12-2013, 04:52 PM
Houston Bimmer Houston Bimmer is offline
Mein Auto: 2015 M5
Do you ever come to Houston? I would love to get my car coded.
Old 02-12-2013, 07:38 PM
Yeah I should be there in March for a wedding. I can bring the laptop and code your car real quick.
Old 02-13-2013, 02:00 PM
Rear DRLClick image for larger version
Old 02-17-2013, 10:33 PM
lighty150 lighty150 is offline
150
Mein Auto: 2015 i8
def have to do this, is his price reasonable
Old 02-18-2013, 10:16 AM
Mein Auto: 2015 M5
Left you a PM
Old 02-18-2013, 07:55 PM
6kat 6kat is offline
Mein Auto: 6 series convertible
Anyone know anyone in Florida?
Old 02-20-2013, 03:55 AM
jlkaufman jlkaufman is offline
Mein Auto: 2014 650xi Gran Coupe
Does anyone know any references that explain how to do this yourself or know anyone near Baltimore, MD that does this? Also, is the the same between the coupe and gran coupe? Thanks.
Old 02-20-2013, 03:03 PM
octopump's Avatar
octopump octopump is offline
Brevity = soul of wit
Mein Auto: F10
It's all here:
http://www.bimmerfest.com/forums/forumdisplay.php?f=175
Old 02-20-2013, 03:25 PM
BMWZ4RIDER BMWZ4RIDER is offline
Z4 35i Rider
Mein Auto: 2009 Z4 35i
Anyone coding for my E89 2009 Z4 in the Boston market.?
The Z seems more obscure for the coding community. Any help is appreciated.
2009 BMW Z4 35i/Space Gray Metallic/7 Speed DCT/Premium,Cold Weather & Premium Sound Packages/Nav/Comfort Access/Ash Grain Interior & Dash Kit/AntiTheft/SportWheel/PDC/WindDeflector/Black Kansas Leather/Smoked Reflectors, Side Markers & 3rd Brake Light/Ferrari Red Brake Calipers/Clear Front Mask/Gloss Black Grill Inserts/6000K LED Lighting/De-Badged/Aluminum Pedal Set/Real Carbon Fiber BMW Door Sills/CF Wrapped Engine Compartment Roundels,F Lower Grills & Center Wheel Caps.
Old 02-20-2013, 06:21 PM
Thanks.
Old 02-21-2013, 06:44 AM
eyeatl eyeatl is offline
Mein Auto: 2013 650i GC 2010 Maserat
Good luck!!!
This is a great list of features that can be coded. I would add a couple more that can be coded:
1. Decrease sensitivity of the auto headlight function so that you don't drive with headlights on during the day when the sun is low (winter months). Stock setting keeps the headlights on too often during the day.
2. Activate sport gauges showing real time horsepower and torque.
3. Add telephone, turn signals and infotainment features to heads up display (if your car has HUD).
2013 650i GC, prev 2010 550GT
Old 02-21-2013, 03:31 PM
Or this one bmwcoding.com
Old 04-11-2014, 05:57 AM
lovbav lovbav is offline
Mein Auto: 640ix
Just had my F12 640ix coded last night by Octopump in NJ. Added most of the features that are left out including my favs, such as the tire pressure readout, remote mirror fold, //M splash screen on start up. Octo did a great seamless and careful job. Absolutey recommend him if you are in the NY/NJ area. He can even do it remotely. having fun with the car so far but being gentle with only 400 miles on it.
Old 04-11-2014, 06:57 AM
Just our of curiosity, what is the going rate to get coding done? Thanks,
