Old 01-24-2013, 02:43 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
121k on the ol' 2003 540.
Nearly a turn key car hopefully done by may.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 01-24-2013, 06:39 PM
4dreuropean540i 4dreuropean540i is offline
Mein Auto: 99 540i/6
Ok so I just changed out my stock radiator Sunday after finally finding the "pinhole crack" that has been my demise.... bled the system and took her for a quick ride and parked her for the night. The next morning heading to work as I was traveling over the same bridge I do every day I glance down to check my cluster and as I do i literally witness as it passes 140,000.....all i can say after 6yrs of owning this car is I couldn't be happier!
1999 540i/6
Dinan: intake/exhaust/chip
Bilstein B14 PSS
Old 01-25-2013, 12:53 PM
guberot guberot is offline
Mein Auto: 2002 540i6
2002 540i 6 99K mi.
I'm just shy of 99K mi. 2002 540i 6.
Old 01-25-2013, 05:09 PM
skalomax skalomax is offline
Mein Auto: 2003 530i
Hit 60,500mi today on my '03 530i Spt. I'm glad it still has a few years left since I love it.
Old 01-25-2013, 06:40 PM
Bungcarlo Bungcarlo is offline
Mein Auto: BMW LR Lexus Montero
97 528i. 179,000 miles!
Replaced pads, third brake fuse housing, thermostat, battery, belt and pulley tensioner!
Bought replacement parts whenever I find a good deal in case.....alternator, MAF sensor, brake sensor! water pump!
Land Rover BMW 528i Mitsubishi Montero Lexus IS350
Old 02-01-2013, 02:54 PM
bagodonuts68 bagodonuts68 is offline
Mein Auto: e38 750iL
total work done might take some thought. I've replaced or repaired the following on my 2000 528 iT: just replaced tailgate and glass struts, shock, rear subframe bushings, rear sway arm bushings, ECM rebuilt, tranny rebuilt, driver door gasket, alternator, Oxygen sensors, power steering hoses (need replacing), radiatior, water pump, wheel speed sensors, worked on tailgate wiring, fog lamps, head lamps and other assorted bulbs... all since i've owned the vehicle (purchased with 104k miles)
Still a GREAT car.
Old 02-01-2013, 03:28 PM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
117000 on my 540
Old 02-02-2013, 05:03 PM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
148,000 on my 03 530I. Plan to keep it running another 100K which will be about 5 more years
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 02-02-2013, 05:19 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Name:	20000 miles.jpg
Either you are part of the solution, or you are part of the problem.
Old 02-02-2013, 06:30 PM
Saladdin Saladdin is offline
Mein Auto: 1998 BMW 528I
1998 528i
74,115
Old 02-02-2013, 06:38 PM
wspider666 wspider666 is offline
Mein Auto: 2002 525i wagon
129,000
Old 02-02-2013, 09:24 PM
helpmyfive helpmyfive is offline
Mein Auto: 528i
Just rolled to 262,000 miles. Recently swapped an alternator and 6 coils. The car was running poorly when I decided to replace the plugs. Found 5 loose plugs. Now, with new coils and plugs, it runs like a CHAMP! I don't have enough time or care to fix the leaking rack. I just put ATF in about twice a month. This car is still an amazing ride. I'd replace it but don't want to give up my heated seats, heated steering wheel and rest option. LONG LIVE THE 5ER!
Old 02-03-2013, 04:19 AM
dalyduo dalyduo is offline
Mein Auto: '03 540iT
'03 540iT
'03 540iT Wagon with factory M package. (Rare combination)
Approaching 114,000 miles. I'm 2nd owner.
Bought in '06 with 30,000 miles.
Regular maintenance with one tranny rebuild and two radiators.
Still looks and runs like new.
'03 540 iT
Old 02-03-2013, 10:03 AM
Negaface Negaface is offline
Mein Auto: 2002 530IA
91000
Sent from my SCH-I535 using Bimmer App
Old 02-03-2013, 10:36 AM
s2kpunisher s2kpunisher is offline
Account Under Review
Mein Auto: 540i
56K on my 1999 540i/6 still on the original clutch with Dinan Stage 3
Old 02-03-2013, 10:47 AM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
179,800 on my 2002 540i, runs and looks great.
Old 02-03-2013, 03:21 PM
jamiblack jamiblack is offline
Mein Auto: Bmw 530i E39
131000 km 2002 530i
Old 02-03-2013, 04:06 PM
Makomagnet Makomagnet is offline
Mein Auto: 2001 525
115K mi on my 2001 525
Old 02-03-2013, 09:30 PM
DHoffmeyer's Avatar
DHoffmeyer DHoffmeyer is offline
Mein Auto: 99 528i
227,200 on my 1999 528i
Old 02-04-2013, 07:01 PM
sandwagon sandwagon is offline
Mein Auto: 2000 528iT
169K on my 2000 528iT.
Old 02-04-2013, 07:36 PM
wolf888 wolf888 is offline
Mein Auto: 528i /C240/M35
121K on my 1998 528
Old 02-18-2013, 01:43 AM
Sumotide17 Sumotide17 is offline
Mein Auto: 2001 540I/6 Sport
100500 mi on 2001 540I
Old 06-20-2013, 06:39 AM
awalker301 awalker301 is offline
Mein Auto: 02 530i 00m roadster
Re: How many miles on your E39?
165, 876 2002
Sent from my SPH-L710 using BimmerApp mobile app
If its not broken. Dont fix it. Drive it like you stole it then fix it
Old 06-20-2013, 07:43 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: E39 540, E36 328is, E83x3
Now 183k on my 01 m62tu
Specializing In BMW, Audi, Mercedes Benz ,Volkswagen, Volvo
15486372<-----
Old 06-20-2013, 07:58 AM
YOST YOST is offline
Mein Auto: 2000 540i
how many miles/kilometres
Mine is a 2000 540i.
It has almost 265000 km on it.
I have had it for 3 years and put some money into it!
But it seems to be running well now!
Next will be body work!
