Old 06-02-2012, 07:41 AM
AutoBahner AutoBahner is offline
Mein Auto: 2012 BMW X5D
I'm living out of Stuttgart and so I get to check out the european spec X5's, and they all come with the shocks installed. I picked my X5d up last week in Munich, and installed the thing in their delivery room while the BMW rep just stood there with his mouth open! I didn't care, I told him "it should have come with this from the factory, don't you think?" to which he replied, "ya, I zink zo". Then I drove out of the building a happy man.
Old 06-04-2012, 08:51 PM
Pourboire Pourboire is offline
Mein Auto: 2013 X5 35i
Originally Posted by mctavish View Post
My 2011 35d came without the lift shock under the cargo cover. So I have to hold it with my hand every time I open it. It is a common miss from BMW, based on many threads here.
Thanks penguin for providing useful information in an early thread. I took the dive and ordered these two parts from a local dealer:
1. Gas pressurized spring, part number 51476980060, $49.58
2. Spring bracket, part number 51479138212, $8.07
When I picked up these parts at the dealer, I found the bracket came in without the screws. So I asked nicely at the dealership and actually got them to put it on for me. It is so straightforward that they did it for free. It took just a few minutes to mount it on.
I attached a few before and after pictures. Note in the before picture, there are holes pre-drilled on the cargo cover for the bracket (red cycle 1). The spring will hook up with bracket and the other end of the spring goes to the pre-existing hook-up (red cycle 2).
The last picture shows now the cover can stand up by itself! what a relief.
Still can't believe BMW pre-drilled the holes, then choose not to install the parts.
Thanks for the heads-up regarding this item. Just finished the install of the emergency spare tire in my recently acquired 2013 X5.
Old 06-06-2012, 05:02 PM
Freewheeler Freewheeler is offline
Mein Auto: 2012 X5 35d
Hey all,
New to the forums (first post) and thanks for sorting this lift spring out for me. I just picked up a '12 X5 35d and hounded the sales guy for the lift since it was apparently standard on 2011's. He checked with a few people who gave different answers (read: no one knew what was going on) and finally the parts desk said the spring was now only included only with the spare tire kit. Any of you who got the spare without the spring should look into this, or maybe BMW lets the dealers decide how to part with their measly little $50 spring kits.
Again, thanks for the thread (already bought the parts) and I look forward to all you great advice on the boards.
Old 06-06-2012, 05:31 PM
Originally Posted by Freewheeler View Post
Hey all,
Freewheeler thanks for info. Purchased a 2013 X5 35i premium a few weeks back and later purchased a spare tire kit with all the associated gear. The thought
of a tire failure in which the spare would last only 50 miles was unacceptable. Composite cost was about $500.00 which included triangle reflector. Unfortunately the aforementioned
kit to hold up the cover was not included in the price. As mentioned earlier on this forum, BMW expects you to remove the spare while holding up the cover with your head. Its seems
that BMW is becoming like Porsche, where everything is extra. The spare tire kit was a hit in the pocket, but i intend on replacing the run flat tires when their tread ware is below the acceptable
level.
Old 06-06-2012, 06:55 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
My 2010 Diesel came with the spare tire option from the factory and did not have the gas cylinder installed. I ordered the parts and added it myself - very easy to do with the OEM parts.
Old 06-07-2012, 05:11 AM
BenF12400 BenF12400 is online now
Mein Auto: 2006 X3; 2010 528;2013 X5
Question
My 2013 X5 with spare did not come with cargo lift shock so I may pick one up - the shock fits ok with the spare in place?
Old 06-07-2012, 08:26 AM
Yes, but remember you need the bracket as well as the gas cylinder. The bolts are available and cheaper at most hardware stores, but for convenience you can order those from BMW at the same time.
Old 06-07-2012, 08:45 PM
FYI, just installed the gas cylinder and it failed the first time I closed
the panel. Waiting for a replacement part from BMW. Hopefully its not
a lot problem
Old 06-08-2012, 02:47 PM
I just ordered the entire kit - screws included - from Tischer internet for me to pick up. was $51 plus tax
Old 06-14-2012, 08:40 AM
TigerDave TigerDave is offline
Mein Auto: 2011 X5 35d
Finally got mine installed. Definitely a must-have if you ask me. Just lift the latch and the gas spring does the rest.
Old 06-14-2012, 08:49 AM
Does anyone with the spring have a rubber trunk liner and is the spring strong enough to lift it as well?
Old 06-15-2012, 06:40 AM
Picked up kit for $51, installed it last night. Took a few minutes - hardest part was climbing in and out of the cargo space. So far works fine.
Old 06-18-2012, 10:26 AM
To answer my own question, I installed the lift and it's more than strong enough to hold the trunk liner up. VERY nice to have the lift; it actually makes the underfloor space useful on a day-to-day basis.
Old 06-18-2012, 06:50 PM
Ben_XI Ben_XI is offline
Mein Auto: 2011 X5 50i
Originally Posted by freewheeler View Post
to answer my own question, i installed the lift and it's more than strong enough to hold the trunk liner up. Very nice to have the lift; it actually makes the underfloor space useful on a day-to-day basis.
+1
Old 11-12-2012, 04:56 AM
YuCrew YuCrew is offline
Mein Auto: 2012 X5 Premium
One Spring
One spring but it obviously has to be the correct amount of strength/force for the application. Too strong is as bad as too weak.
Originally Posted by Kzang View Post
I'm going to have to ask my CA to add this to mine when I take delivery, if it isn't already isntalled.
Shouldn't there be two springs? one on each side?? Having only one in the middle just doesn't seem to be sturdy enough.
Old 11-12-2012, 05:00 AM
Installation
Sorry to hear you climbed in and out of the vehicle. I had no difficulty installing mine without climbing in. You got a very good price for sure.
For those who don't have this installed yet or can't get to Tischer BMW to pick up, I presently have my last 13 lift support kits for sale here:
http://cgi.ebay.com/ws/eBayISAPI.dll...EOISSA:US:1123
Old 02-15-2013, 04:12 PM
Kzang Kzang is offline
Mein Auto: 2015 X5 ///Msport 35i
Anyone getting any better prices on this kit?? I've checked all local BMW dealer and getting quotes of $100 and up now.
I put this off in the beginning and totally forgot about it. Now I want to have it installed and the prices on the Gas pressurized spring, bracket and screws are very overpriced..
2015 X5 Msport Space Grey
Old 02-17-2013, 07:15 AM
Best pricing I've found so far. Just ordered from getbmwparts.com
Order Status Details Order Date: 2/16/13 5:26 PM
Description Qty Price Core Price Total Price
OEM Catalog
GAS PRESSURIZED SPRI 1 $41.92 $0.00 $41.92
Status: Ordered
OEM Catalog
Damper Bracket 1 $12.47 $0.00 $12.47
Status: Ordered
OEM Catalog
SCREW 4 $1.23 $0.00 $4.92
Status: Ordered
Sub Total $59.31
Tax $0.00
Standard Ground - US Only - Shipping $12.95
Handling Fee $3.95
Total $76.21
Old 02-17-2013, 11:43 AM
Total $76.21
I paid $57.22 + $10 shipping from Circle BMW last year.
Old 02-17-2013, 12:02 PM
Sean's Avatar
Sean Sean is offline
Mein Auto: '01 Z3
OEM Catalog
Status: Ordered
OEM Catalog
Status: Ordered
OEM Catalog
Status: Ordered
Sub Total $59.31
Tax $0.00
Handling Fee $3.95
Total $76.21
I ordered from Tischer (wwwgetbmwparts.com) as well. I had it installed in two minutes. Easiest retrofit ever!
Name:	Screen shot 2013-02-17 at 3.00.45 PM.png
Old 02-17-2013, 05:18 PM
Right.. I should have ordered it last year but I totally put it off.
Old 02-17-2013, 07:38 PM
gresch's Avatar
gresch gresch is offline
Don't be a hammer
Mein Auto: '12 X5 35d
I can't find that on getbmwparts.com by searching on PKE70SHOCK, do you have a link?
Old 02-18-2013, 04:01 AM
51479149120 - Gas pressurized spring
51479138212 - Gas pressurized spring bracket / Damper
07129903027 - Screw
Old 02-18-2013, 06:32 AM
vetaldj vetaldj is offline
Mein Auto: 2015 VW eGolf
My 2010 X5 35d doesn't have it as well.
I did quick check and found spring at ebay for $25 shipped (OEM), will get screws in Lowes and bracket from dealer.
Commuter: 2015 VW eGolf SEL Pacific Blue, 23K
Pleasure: 2016 X1 xDrive Tech/Driver Assist/Cold Weather, 13k
Pleasure: 2010 X5 35d Monaco Blue/Saddle Brown with Premium/Technology/Sport/Climat, 90K
SOLD - 2003 525i Green M Susp/M St Wheel, 202K
SOLD - 1997 528i Silver, 116.5K
BMWCCA Member # 447308
Old 02-21-2013, 07:52 AM
TischerBMW's Avatar
TischerBMW TischerBMW is offline
Your #1 BMW Part Source
Send a message via AIM to TischerBMW
Mein Auto: BMW
Looks like GetBMWparts is the best.
Originally Posted by 1HOT BMR View Post
They are also sponsors of this site and they provide you with great and prompt service. Why would you buy anywhere else?
Thanks for the kind words! We're here to help!
We have this on special as a kit available here.
Evan Winstead
Internet Parts Manager, getBMWparts.com
Email: getHelp@getBMWparts.com AIM: Evan at Tischer Follow: FaceBook | Twitter
