Can belts be noisy ? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-14-2013, 05:25 AM
Bimmer1995318ti's Avatar
Bimmer1995318ti Bimmer1995318ti is offline
Mein Auto: 1995 bimmer 318ti
Hey guys.! I have a loud engine, it's a 4 cylinder so it should be calm and quiet. I'm not sure hats causing my engine bay to be so noisy, it sounds like maybe my belts are loud.? They are old and need replaced anyway but could this be anything else ? Loose pulley ? Or something needs lubricated ? Not sure ! Would appreciate your input. ! Btw it sounds like it's coming from the front of my engine around the belts. Thanks !
Old 02-14-2013, 05:43 AM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
Could you post a vid? There is a lot going on in there.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 02-14-2013, 06:05 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
^this would be a huge help.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 02-14-2013, 08:09 AM
Sure I will do so after school !
Old 02-14-2013, 05:02 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
Yes, belts can be noisy. If you have a cheap (Harber Freight) mechanics stethoscope you can check bearings on pulleys (Cautiously) and different points of the engine to localize the noise. i.e. if you had a bad lifter, you would hear the difference between them.
Old 02-15-2013, 05:08 AM
So what is a lifter exactly ? And sorry about, the video guys ill try to get it in today!
Old 02-15-2013, 07:44 AM
The lifter is an assembly that positions between pushrods and camshaft absorbing the mechanical abuse of opening and closing the valves. Most now days are hydraulic and over time (or due to poor oil maintenance) can begin ti fail to "remain pumped-up". If you maintain oil and filter changes it is not usually a concern.
Old 02-16-2013, 08:44 PM
I usually change my oil ever 3-4k miles so I can't imagine that being it ! What's the difficulty level of replacing belts yourself ? I've never done it but I do all my own work so I have the aptitude to do it ! Anything special I new like a loan a tool from auto zone or anything ?
Old 02-17-2013, 12:24 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Replacing the belts is easy. The only special tool you will need is the fan clutch removal tool. For instructions refer to the video below and this manual.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 02-17-2013, 09:06 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yeah, replacing belts on these cars is extremely easy. No special tools needed, except for the 32mm wrench (you can buy 32mm fan removal tool kits on eBay for pretty cheap, or buy locally). I've even done it without removing the fan, thus making the huge 32mm wrench for fan removal unnecessary. It wasn't that hard to do, but it's definitely considerably easier with the fan removed.
1998 BMW 328is
1966 Pontiac GTO
Old 02-17-2013, 11:57 AM
Oh wow that looks incredibly easy according to that video ! Anything I should pay the toon to through your guys' own personal experience.? Like anything extra I should Inspect, or do while I'm replacing them ?
Old 02-17-2013, 01:46 PM
While you have the belt off it is a good idea to check the pulleys. Just spin them with your hand and make sure that they do not sound like the video below. If one of the pulleys does sound like the video, replace all the pulleys.
Old 02-17-2013, 06:12 PM
Great! How much do pulleys usually cost ?
Old 02-17-2013, 06:17 PM
Or any special tensioner/ pulley I should buy ?
Old 02-17-2013, 09:40 PM
The pulleys do not cost too much. Some like $15 each for the top two and $30 for the A/C one. There is no special aftermarket pulley you need to buy. Just make sure you get the right one for your car. BMW made a few different types. But before you go replacing all the pulleys listen to them. If they all sound good then do not replace any of the pulleys.
Old 02-18-2013, 08:09 AM
Thank you South Park ! Your the best man !
