Old 02-03-2013, 06:53 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
I got it from eBay seller
Oem_parts_only
I can try and get you one if you need let me know. I saw a few just look up the part number.
Sent Via iPhone using BimmerApp
Old 02-04-2013, 10:39 AM
645/333's Avatar
645/333 645/333 is offline
Michael
That certainly looks like corroded terminals and hopefully is the cause, worth checking gaskets as it must have failed somehow, good diagnosis !!!! Well done!!
Old 02-04-2013, 11:45 AM
Nitrogen's Avatar
We will see after I install the new one. Hope it solves the problem.
I'll let you all know soon.......
Old 02-06-2013, 05:48 PM
HerbP HerbP is offline
Oem_parts_only
I appreciate the info on the part seller. It is hard to find used parts for a BMW. Most junk yard sellers don't like selling off the smaller less expensive parts. There are quite a few failures for this particular part on the heater system, making me lean towards a new one. It is interesting that the coil is shorting out, not allowing a on vehicle repair.
Old 02-06-2013, 07:42 PM
Nitrogen's Avatar
Herb I got a used one because I don't know 100% if this part is the culprit.
I say this because when I first push the defrost button I here the blend doors moving and for a few seconds I feel lots of heat then it just blows cold air. So I could have multiple issues or maybe keep my fingers crossed this part will fix it. Got the part today in the mail I'll install it soon.
Old 02-09-2013, 06:14 PM
Nitrogen's Avatar
You know what this means? I got heat flowing again!!!!! Yahoooo!!!!!!
Now it's Click image for larger version
ID:	361591 Time!!!!!!
I replaced the heater control valve that I had ordered after finding the shorted solenoid and it worked like a charm.
Thanks to all that helped I love this forum!!!!!!!!!!!
Old 02-09-2013, 06:18 PM
Glad you got it working!
Old 02-09-2013, 06:20 PM
Nitrogen's Avatar
Glad you helped me fix it !!!!!! Cheers!!!!
I owe you a brew!!!
Old 02-10-2013, 03:23 AM
645/333's Avatar
Michael
Good work, and for the benefit of others good diy and diagnosis!!! You can drive upto the North East now and be toasty warm lol
Old 02-10-2013, 07:19 AM
I wonder if my heat works? Wait, never mind, I don't need it!
Very nice diagnosis and fix Nitrogen.
Old 02-10-2013, 12:45 PM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
Nice fix Nitro! The power of bimmerfest and some good DIY talent.
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 02-17-2013, 11:58 PM
Nitrogen's Avatar
Ok well thanks to all that helped get my heat back.
Don't laugh but as I first stated I had a small coolant leak toward the back of my engine. I thought the dreaded curse of the coolant pipe had hit. But after I fixed the heater control valve no more leak.
Can it be? Could the valve cause the pressures in certain areas to go high and leak? Very interesting? I looked at the hoses while doing the replacement and one hose was bone dry. What do you guys think???
Old 02-18-2013, 12:04 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Good job on the fix Nitrogen. I will buy you a beer if we ever meet!
Once a 6'er, always a 6'er.
Old 02-18-2013, 11:28 AM
645/333's Avatar
Michael
Hi I do not know how to do it but you should consider putting this in the DIY section, as it is an excellent bit of fault-finding to benefit others!!!
Old 02-18-2013, 03:46 PM
Nitrogen's Avatar
Thanks 645/333 I don't know how to transfer it to DIY maybe someone else can help with that.
I just can't believe that the leak is gone now to after repairing the valve. It was in 2 different locations. bizarre!!!
Old 05-14-2014, 06:36 AM
bismarck bismarck is offline
Mein Auto: BMW 645ci
I know this thread goes way back now guys but it's been super-informative and based on the symptoms it seems very likely that I have this same issue. So I've bought a replacement heater valve one from eBay (guaranteed working) only 35 so can't complain. Anyway got a quick question: I was jut looking at the TIS instructions for it and the instructions for the preliminary tasks - namely disconnecting the water hose from heater and it seems like there's a special 'hose clip' that you need in order to do this. Do I need this special tool and am I right in thinking if I just disconnect the hoses from the valve coolant will simply gush everywhere?
If so could someone explain to me where it is under the bonnet that I need to disconnect the hoses from and how to clip the hose (if that does indeed need doing)??
Many thanks
Old 05-14-2014, 06:06 PM
You simply need to only unhook the attached hoses, & reconnect them. Remove the wiring connectors, then the mounting bolts. Hold the valve as high as possible, to prevent coolant loss. I can not remember any special hose clamps, but any screw clamp can be used to tighten the hose fittings. It is a pretty simple job!
Good Luck!
Old 05-16-2014, 04:12 AM
Good Luck!
Okay gonna give this a go today / tomorrow and hope I don't pull out something I'm not supposed to ha.
Cheers for the help Herb!
Old 05-16-2014, 06:50 PM
Here is a pdf for the job.
Good Luck!
File Type: pdf RA Replacing water valve for heater.pdf (56.6 KB, 91 views)
Old 09-18-2014, 12:33 AM
Bargain Bucket Bargain Bucket is offline
Mein Auto: E64 650i
SOmething mentioned in this thread - the aux water pump. Is this pump required in order to get heat into the cockpit during normal use? Or it is only required for "rest" mode? I've only just got my 650 and this pump does not work (fault code logged).
Old 01-06-2016, 04:04 PM
mgfranz mgfranz is offline
"You chose wisely..."
Mein Auto: E64, E38, Boxster, A4
Originally Posted by Bargain Bucket View Post
Something mentioned in this thread - the aux water pump. Is this pump required in order to get heat into the cockpit during normal use? Or it is only required for "rest" mode? I've only just got my 650 and this pump does not work (fault code logged).
I know this is an old thread but yes, the aux pump, (so I have been told), is to circulate water only in REST mode and if it has failed it will throw a fault code, which is somewhat of a blessing if you are trying to isolate a heating issue. If you do not get a fault code then most often the culprit is the water valve.
'07 650i E64 with mods
'99 740i E38 M-Sport
'95 530i E34 [SOLD!]
'08 Audi A4
'01 Porsche Boxster (For Sale)
'03 Ford F250
