Old 05-02-2012, 11:18 AM
jeffmikolai jeffmikolai is offline
Mein Auto: 2005 BMW 645CI
05 645CI Shaking/Rough Idle At Stop
Ok I have been through the search and dont really see any other posts that are like mine so here goes.
When I am at a stop the car shakes.
The RPMs DO NOT fluctuate enough to see on the gauge.
This happens when the car is cold or warm, hot.
No error codes or messages on the dash.
I ONLY use high octane Mobile gas.
The car does hesitate a tiny bit SOMETIMES when taking off from a stand still.
Any help would be appreciated.
-Jeff
Old 05-02-2012, 11:59 AM
ammobmw ammobmw is offline
Mein Auto: 2005 BMW 645ci
does it also shake after u start it after being off?
Sent from my DROIDX using Bimmer App
Semper Fi
Old 05-02-2012, 12:06 PM
Yes it does.
Sent from my DROID RAZR using Bimmer App
Old 05-02-2012, 02:27 PM
amanra's Avatar
amanra amanra is offline
Mein Auto: 2012 BMW 650i
I've experienced the same issue, over time it will progress and you'll notice the hesitation increases when you accelerate from a stand still. The issue I had was a vacuum leak.
Old 05-02-2012, 06:04 PM
HerbP HerbP is offline
Mine did that yesterday, I filled it up with gas before the problem started. Mine surges more often since I changed my thermostat. I know this should not make a difference, but these cars are strange! Put in a bottle of Techron to see if it will help!
Good Luck!
Old 05-03-2012, 06:59 AM
Did the TechRon already. Taking it to the dealer in 2 weeks and will update this post.
Old 07-11-2012, 11:08 AM
bmw645england bmw645england is offline
Mein Auto: bmw 645ci
Hi all, I have the same problem..virtually identical including the fact the rough idle doesnt really affect the revs. Diagnostics say thermostat is stuck but judging by what was said above replacing that could make it worse?
Any help would be greatly appreciated.
A.j
Old 07-11-2012, 02:24 PM
If the diagnostics say thermostat stuck, replace the thermostat. This is a very common problem.
Good Luck!
Old 07-12-2012, 02:00 AM
Hi HerbP
Thanks for the reply - is that likely to solve the problem of unmask it and make it worse as you suggest in your previous replies?
Old 07-12-2012, 10:03 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
As stated earlier, these cars are a bit strange when they start to have problems, too much electronics. The best bet is to be able to read the codes. I've seen post on here that the replacement of the thermostat solved the problem. Also a bad coil could be causig the issue as well but you wont know for sure until you get the fault codes read.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 07-12-2012, 05:54 PM
The strangest thing about the thermostat is, that it can cause the motor to swing up & down. A rough engine idle would most likely be from a vacuum leak. From chasing a very small o-ring leak, it can drive you crazy. DIS will give you the codes to point you in a certain direction, after you that you are on your own!
For a rough idle I would 1st inspect the 2 front vent hoses, these become very brittle over time. 2nd I would change the 2 crank case vent valves, better known to most as a PCV valve.
Hope this might help!
Old 07-14-2012, 02:36 PM
thanks for your help. getting the diagnostics done next week so will keep you posted. my engine management light just came on-not sure if this is related but whatever it is should come up next week in the diagnostics....
a.j.
Old 01-11-2013, 05:52 PM
BadboyzTn's Avatar
BadboyzTn BadboyzTn is offline
It's the Principle
Mein Auto: 2011 740i M Sport
What was the issue?
2011 740i ///M-Sport|Black Sapphire Metallic|Saddle|20" 303M-Sport
Old 02-15-2013, 05:45 AM
blodi blodi is offline
Mein Auto: 2005 645ci Sport
Originally Posted by BadboyzTn View Post
What was the issue?
+1.
I have similar issues. Rough idle and hesitation sometimes. I keep getting the thermostat error code too. I replaced the thermostat, but still getting the same "increased emissions" message after I reset the SES light. I've also now run techron in it and replaced the CCV valves with the newer ones that eliminate the vent hoses too. No change.
Frustrating. I'm thinking maybe I got a bad new thermostat too? Long shot, but thinking of replacing it again.
Old 02-15-2013, 11:22 AM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645 / 14 435I
I too have same issues. I really want to buy a code reader is there one that is user friendly? Or one easy to learn. I've done everything but replace thermostat is that a difficult task?
Old 02-15-2013, 07:38 PM
It takes around 30 to 45 minutes to change the thermostat. It would also be a good time to install fresh antifreeze, since you are going to loose some. A basic code reader is not going to do much on a BMW. You could purchase the one of the Bavarian Tech readers, that will allow you to do some troubleshooting & rests. Another option would be to purchase an OBD2 cable that works with DIS or INPA. There is much discussion here on the boards that go into detail.
Good Luck!
Old 02-16-2013, 04:42 AM
amennrahh's Avatar
amennrahh amennrahh is offline
BM6er
Originally Posted by herbp View Post
it takes around 30 to 45 minutes to change the thermostat. It would also be a good time to install fresh antifreeze, since you are going to loose some. A basic code reader is not going to do much on a bmw. You could purchase the one of the bavarian tech readers, that will allow you to do some troubleshooting & rests. Another option would be to purchase an obd2 cable that works with dis or inpa. There is much discussion here on the boards that go into detail.
Good luck!
+1
SEMPER FIDELIS
Old 02-18-2013, 01:46 PM
I just scanned the car with a bmw specific tool and it came up with the 2ef4 code which looks like it is the thermostat. I guess I'll replace it again.
Old 02-18-2013, 06:50 PM
Skarv Skarv is offline
Mein Auto: '05 645i convert
I'm usually skeptical of thermostats making it run rough but you never know with these cars. Anyway, if this doesn't fix it for you, I found that in my case, the cure for an occasional spat of rough idle... to the point that it would throw a 'cylinder misfire' code for some cylinders... was: Spark plugs.
Highly recommend if your car has more than 50k miles. They say 100 k interval, but I found that for my car, this was waay too long.
2
Old 02-19-2013, 05:36 AM
I did just change my plugs as well a couple weeks ago trying to rule them out. No change.
I ordered a new thermostat again, we'll see if that helps anything. I've also read that sometimes part of the wiring harness that goes to the thermostat goes bad on these motors, but I think its earlier builds than mine which is a 5/05.
Old 05-04-2013, 05:49 PM
reachpx reachpx is offline
Mein Auto: 645CI, 330CI
Same exact problem
I have the same exact problem. I have done the following and still the problem persists .
1. New Thermostat
2. New Spark Plugs
3. New Coils
4. New CCVV (PCV) installed
5. New Battery
6. Coolant flush done and no leaks
Its getting worse now and it has rough idling. No error codes at all .
Did your problem get solved - if so, what was the solution?
Thank You!
Old 05-05-2013, 05:38 AM
I did change my thermostat again and made sure I got the OEM brand, that got rid of the light and it has been off now for a couple months now at least.
Idle is still rough. I changed the plugs, thermostat (obviously), and CCVV's. I did have one coil go bad a couple weeks ago and replaced it. The car was really running like crap and the light came on when it went out. I just ordered 7 more that should be here this week so I can replace the rest since I figure its only a matter of time for them. We'll see if that does anything. But you mentioned you've changed them with no effect. I've also cleaned the crap out of the throttle body and MAF sensor, with no change.
The other thing I have read somewhere was that the valvetronic programming can be updated and help. I pulled mine up on my scanner and it looks like it was last updated in 2009, not sure if that is still the latest programming for it though. If anyone knows, I'd really like to know so I don't waste time/$ at the dealer to have them look into it.
Old 05-05-2013, 09:10 AM
ferny ferny is offline
Mein Auto: 06' BMW 650i
I wonder what the rough idling might be ... I hope it gets figured out. Let us know about the valvetronic programming!
Old 05-05-2013, 10:53 AM
five liter five liter is offline
Mein Auto: 645ci
Have you checked for vacuum leaks? Check hoses and spray some starting fluid around places that are known to have leak issues. If there is a leak the idle will smooth out or stall all together.
Old 05-06-2013, 08:11 AM
Yeah, I've hosed everything down in there pretty good and no changes. When I replaced the CCVV's I used the new style that don't have the hoses. I capped off the nipple on the intake hose. So those hoses won't ever be an issue.
My coils get here Wed, so I'll see if they make any difference.
