E34 (1989 - 1995)
Old 06-22-2012, 12:45 PM
PFCTTZ PFCTTZ is offline
PFCTTZ/SirBoostAl0t
Mein Auto: 89 535i
can someone show me a picture of their functional temp switch harness, photo inside
So im outside trouble shooting my over heating issue, and I find this harness and man...it looks like six pounds of sh*t in a 5 pound bag, its taped together and falls apart in my hand, the brass on the temp switch looks to new to be broken but there is a change the ASE master tech (joke)who owned my car before me could have mixed up the wires on the temp switch
so can someone please reply a picture of their temp switch harness so I can compare against mine,
Old 06-22-2012, 01:10 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Is this what you're looking for?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-22-2012, 01:17 PM
PFCTTZ/SirBoostAl0t
Mein Auto: 89 535i
thanks a million man, looks like my temp switch is busted, but i just hot wired it until I can order a new one
Old 06-22-2012, 01:35 PM
BMR_LVR's Avatar
Humble E34 lover
My pleasure.
Does the aux fan run when hot wired?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-22-2012, 01:46 PM
PFCTTZ/SirBoostAl0t
Mein Auto: 89 535i
Originally Posted by BMR_LVR View Post
My pleasure.
yea, it runs fine,
Old 06-22-2012, 01:48 PM
Mein Auto: 1989 525i M20B25
Pinout from 1989 535i ETM.
colors:
Connector X87, 3-pin connector.
1=Brown (Ground)
2=Violet/Gray
3=Black/Gray/Yellow
Pin locations:
In your photo it looks like you are missing the plastic cover on the back of the connector. That is why I drew the pin locations for you, use the notch in the plug as a reference point.
Good luck man. Hope it helped.
EDIT:
Darn beat by a few minutes. Oh well, good for reference.
Old 06-22-2012, 01:51 PM
PFCTTZ/SirBoostAl0t
Mein Auto: 89 535i
colors:
1=Brown (Ground)
2=Violet/Gray
3=Black/Gray/Yellow
Pin locations:
EDIT:
so the wires are mixed up, but its still busted
thanks man
Old 06-22-2012, 01:53 PM
Actually in your first photo they are fine, look again.
Old 06-22-2012, 01:58 PM
PFCTTZ/SirBoostAl0t
Mein Auto: 89 535i
your right, good eye, do they even sell that part in auto parts stores
Old 06-22-2012, 02:17 PM
BMR_LVR's Avatar
Humble E34 lover
yea, it runs fine,
Wonderful
Glad you didn't have to replace the aux fan
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-22-2012, 02:24 PM
PFCTTZ/SirBoostAl0t
Mein Auto: 89 535i
Wonderful
ya about that, I saw in the manual that they say remove the radiator and bend back the a/c condenser, when u bend it back the fan will come with it, so then you don't have to remove the bumper
Old 06-22-2012, 02:31 PM
BMR_LVR's Avatar
Humble E34 lover
After doing the job, I can tell you that I would rather remove the bumper and go from the front any day, especially because of how hard it was to get the old rubber grommets to let go of the brackets that they were in.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-22-2012, 02:50 PM
PFCTTZ/SirBoostAl0t
Mein Auto: 89 535i
I havn't done either way yet, I think I would prefer to remove the bumper than drain the radiator and risk losing my freon
Old 06-22-2012, 10:10 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
nvrmnd
Old 02-18-2013, 09:21 PM
DanM5's Avatar
DanM5 DanM5 is offline
My other ride is ur wife
Mein Auto: 535is-m
BMR_LVR your a legend, have been scouring for a while for the pin positions, cheers
Get in, sit down, hang on, shut up!!
Old 11-09-2015, 09:18 PM
Vinnie D's Avatar
Vinnie D Vinnie D is offline
Mein Auto: 1990 E34 535i Automatic
Hello there,
would you have a link to where I can find this temperature plug harness by any chance?
I switched my radiator a few days ago, and when I was disconnecting these plugs, the plastic cover cracked in pieces, and the plugs themselves are now damaged. I have looked up the part, but there's nothing that looks like the actual piece you have in the picture.
I followed the wire and it seems like it is a long one. How difficult is that to install a new one?
I would immensely appreciate any advice so I can take care of this and not jeopardize my system.
Thank you much in advance.
Old 11-09-2015, 10:44 PM
capricornbmw capricornbmw is offline
Banned
Mein Auto: E36
The double temp switch is on the right side of the radiator, near the top. The double temp switch's harness connector would also be hanging around there. There should be no other loose wires there - everything else would be connected to something (headlights, foglamps, a/c switch, wiper fluid reservoir motor.)
It should be damn easy to find this.
The double temp switch can be removed from your old radiator and fixed to the new one. Use a wire brush and clean the threads and tip of rust before installing it into the new radiator.
Old 11-10-2015, 05:11 AM
Vinnie D's Avatar
The switch itself (what screws in the right side of radiator) is good, but what is damaged is the plug the connects to the switch. Mine is a triple switch, so I would like to know where to find it (if possible at all, please provide a link to the plug harness, I can't find it online)
I'll try take a picture when I have a chance.
Thanks fellows!
Old 11-10-2015, 06:51 AM
Vinnie D's Avatar
This is what is damaged in my case, folks...(see attachment)
Name:	fan switch wire.jpg
Old 11-10-2015, 03:46 PM
paul1733 paul1733 is offline
Mein Auto: 2 x 1988 bmw 525i's
You will come across more than that eventually. You have 3 choices:
1. Live with it
2. Go to a junk yard & cut off one, same plug is used everywhere on the car just different colors for identification. Think the window motor plug is the same, which is what i would use because it will be less brittle than the ones in the engine compartment.
3. (See attachment) found this the other day comes in different colors. Cant remember what its called.
Old 11-10-2015, 04:25 PM
Vinnie D's Avatar
1. Live with it
Thanks, Paul!
So, would I basically be able to use this here: http://www.bavauto.com/assets/imglib500/61130007441.jpg to replace any of the three if not all three wires?
Old 11-10-2015, 08:59 PM
Banned
Mein Auto: E36
Paul is right. Goto a junkyard and cut off that piece and use it on your car. There is no other way.
Anyway this is not a mission critical component (the plastic connector housing itself). Just tape it up when it is on the double temp switch and you are good to go. Whenever you get to a jy for car stuff (maf, ecu, original ceramic fuses, late model gm, switches, instrument cluster, m wheel (good luck), ignition coils, a/c switch, wiper motor, fog lamps, front and rear bumpers ) you can also pick this up.
No the link you posted is not right.
The front of the connector is crescent moon shaped so nothing else will fit. What you've now got is ugly but perfectly fine on a permanent basis as long as you tape it up or wrap that in some cling wrap to protect it from dirt, dust, water, and accidental impact damage.
Old 11-11-2015, 04:04 AM
2nd that, they have a 90 elbow. Also I'll correct because I've just realized there are 3 wires, I was thinking 2 wires (there everywhere). So go to my second option, the junkyard. Here's a pick of my 27yr old one, so I'm sure you will find a half decent one. If you do find one cut as far as you can from the plug in the junkyard one & as close as you can to the plug as you can to yours. Makes it easier to remove the plastc liner off the wires & to solder + the extra length is always helpful. BMW made it to close of an exact length.
Also I will be in the same boat if i ever have to disconnect mine.
Old 11-11-2015, 08:07 AM
Tri-Polar Tri-Polar is offline
Mein Auto: E34
I wonder if you could mod one of these to plug into it :/
Custom vinyl stickers. Sunshine coast, Queensland, Australia.
www.vinylimpressions.com.au
