E90/E91/E92/E93 (2006 - 2013)
pls advise DD on 15mm rear spacers
I am planning to get new wheels/tires (non rft) and while i am at it I thought I might as well get spacers (15mm) to get a nice crouching tiger look. (no spacers in front). I read many posts here and on e90post regarding spacers and there is no clear verdict for daily drivers. Let me summarize all these spacer related threads
1) They improve handling and are not just for looks. 2) You should always use hub centric (which I was planning to use anyway) to avoid vibrations 3) Most people with issues had lowered their car with after market springs. The most suspension related mod I will ever do in future is get Koni FSD's installed. 4) If you plan to track your car, remove spacers first. 5) They will wear out wheel bearings prematurely. I am a DD and do drive aggressively at times, fast cornering, high speed (max maybe 110 mph). I do not track. Any potential issues if I went rear spacers only ? (as long as there is no rubbing) What do you people who track do extra that you dont do on the street that warrants spacer removal ? I will be glad if the answer is burn outs and drifting since I dont plan on doing that anyway. There is lot of conflicting info on the forums on spacers and Iam hoping some wheel/suspension guru will clear the dust for me and other members with this predicament. Thanks |
The size of spacer will depend on the offset of the wheels you use. If they are OEM wheels, 15mm will be fine. And IMHO aggravated bearing wear would only occur if you used some really wide spacers (30mm+).
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; BMS clutch stop; BMS CDV; RE g/box mounts; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; LED Angels; BMW Perf black grille; SSDD carbon diffuser; Monster Wrap black roof |
I'm no "wheel/suspension guru" but I doubt that a 30mm increase in your rear track would make a noticeable difference in handling.
Also putting a non factory designed spacer between your wheels and the hub is introducing a foreign object in a system that was computer designed by BMW engineers with out it. I know people that have lost a wheel when these spacers have worked loose. It would be better to buy some wheels with that offset and eliminate the spacers. |
You cant do it just by wheel size alone you need to factor in the exact size of the tire. The exact size is not the 255X19X30 its the physical measurement of an inflated loaded tire with a ruler. Tire Rack has this info for all the tires it sells. Somebody on the site might already have the combo & you are golden if not take a lot of measurements at the wheel opening to see how much clearance you have.
Just for a point of info the stock 313 19" wheels will take 245X35X19 & 275X30X19 with out rubbing with no spacers. BTW if you have a warranty & they see wheel spacers you will have trouble from the dealer.
Kevin 2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO 2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star 2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash Last edited by bear-avhistory; 02-19-2013 at 10:25 AM. |
For those without Google-fu, it's a resized clone of the 19" E90M3 OEM selection (multispoke Style 220M).
e90m / ssii / foxred / wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer / no chrome WHEELS FOR SALE
The width of the tire that you can fit on the 18" wheel you are considering is a function of the wheel width and the space under the wheel well. To determine if you need a spacer/what size spacer, you first need to decide what tire size (not just diameter) you want to run. The Tire Rack can help you with this. Once a tire is picked, they can tell you how wide it is. Then by using the offset of the wheel (spec also available from tire Rack) along with 1/2 the width of the tire, you can calculate how much space you have left. This will tell you what size spacers to consider.
All of that said, you would be well advised to follow BashedBarrique's and Bear AV's advice on the spacers. I'd go as wide as the wheels allow, and acll it a day.
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB |
Also note that the elbrus wheels require spacer rings already. I do not know what (if any) effect this will have on your idea for spacers - or if you would be better off with another wheel. See the reviews for this wheel.
Spacers do accept centering rings but, from my personal experience, wheels that require centering rings are generally extremely poor quality. I would recommend avoiding them entirely.
I am more confused now. reading reviews for this wheel , one review mentions that this wheel is heavier than the oem M3 wheel of same design and the weight of the car is supported just by the bolts instead of bolts and hub. Does this logic apply to any wheel with a spacer ? I have a feeling i will be spending thru my nose and end up buying oem BMW wheels but unfortunately many of the cool M3 style wheels do not come in 18" diameter.
Most people won't even notice the difference in handling or appearance. You would probably have to tell them.
I now understand why a centering ring is needed for aftermarket wheels. Explained nicely here. Before I get further confused with tapered lug nuts and what not, I will check to see if I find 18" M3 style wheels made specifically for the stock e92/18" wheel offset which can be used without any centering ring. Then I will worry about the spacer..
Better idea is to find (if you can) 18" wheels that you like that incorporate the desired offset. Then you won't need spacers.
The quest for the perfect offset has started. Soon I will be talking "et34". (guessing this is same as offset but not sure...).
Anecdotal evidence: I ran 265/30R19s in back on 19x9.5 ET30 for awhile with no scrubbing issues but it definitely was not flush. ET22 or so might've worked but I never experimented. Coupe / sport suspension.
I currently have stock Style 189 Rear: 18x8.5 offset 37 and tire size 255/35 18. If I add a 15mm spacer I get the exact flush look like I need. So if I want to avoid using a spacer should I be looking for wheels with offset 52 (37 + 15) ?
If you are not doing so already, read the really excellent info about wheel offset at the Turner Motorsports website and learn how to use an offset calculator.
Positive offset is a measure, in millimeters, of how far outboard the wheel mounting face is from the wheel centerline. Adding a spacer moves the mating face farther inboard so you subtract the thickness of the spacer from the wheel's manufactured offset to determine the new offset.
thanks guys. iam almost there. I now know why they say et22 is a really aggressive fitment. Meanwhile I have also learned that our bore size is 72.56 (sometimes referred to as 72.6). I am closer to my goal of getting a flush rear wheel look without spacers and hub centric rings. I will read the links posted above.
'14 M6 vert- montreal blue over amaro brown • 6 speed manual • Münich delivery this summer '13 X5M - carbon black over black • BBS SV • "it's our truck" '12 650 vert - alpine white over cinnamon • 6 speed manual • Münich delivery '11 Z4 - mojave over beige • 6 speed manual • Münich delivery ...and a bunch of old English motorcycles |
I still wouldn't run even a BBS wheel with centering rings, though. Would rather just get the proper wheel face. OP: You may find more info on what you seek here. Bimmerfest can only help so much in this arena - e90post is a whole different world.
I have one last question. I am having a hard time finding some csl style wheels that will give me a flush rear wheel look. Partly cause I want 18" and no spacers/center rings. Lots of choices if I go 19" but I live in Chicago and 18" provide nice balance of comfort/handling. I have stock 18" right now. The only one I found was
18" VMR VB3. Front 18x8.5 et35 and rear 18x9.5 et 22 pcd 5x120, bore 72.6 If the rear was 18x8.5 et 22 I know it will give me perfect flush look, but this is 18x9.5 and I am worried it will give me MexiFlush as shown in below pic. Do you think I will get flush or mexi flush ? thanks
You'd need nearly negative offset levels to achieve mexiflush tier. 9.5 on ET22, if you run 255s, should get you to a little less than flush. Look around on the wheel/tires section of the e90post forums - I'm certain someone over there has thrown up some images of their car using that combination.
#25
About to pull the trigger on below. Need opinions and feedback (good , bad, ugly). Does anyone know what the gap in mm is between the back of the wheel and the strut (stock front and back) and how close you can go to the strut safely.
hyper silver avant m359 pcd 5x120, bore 72.6 FRONT 18x8.5 et 35 7mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 5mm REAR 18x9.5 et 33 9mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 17mm I currently have stock Style 189 -- 18" wheels
