E36 (1991 - 1999)
Old 02-12-2013, 12:48 AM
B1mm3rB B1mm3rB is offline
Mein Auto: 93 318i
Help 318i owners Cooling System Refresh
Hi im looking up the parts to do the cooling system on my 318i. I noticed the radiator on the 4 cylinder & 6 cylinder e36 are different. The four cylinder has the expansion tank attached to the radiator and the 6 doesnt. Id rather get an all aluminum radiator and mount the expansion tank separate like on the 6 cylinder. Would i be ok doing this.
Here is the kit i was thinking about getting it doesnt come with radiator. Anyone have any experience with this kit or recommend a different one?
http://www.ecstuning.com/BMW-E36-318...ing/ES2083267/
Old 02-12-2013, 09:33 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I don't think any of the hoses will fit, nor am I sure that the fan will be in the correct location. Probably will, though, but you'll have to also buy a fan shroud for the 6-cylinder radiator, since the 4-cyl shroud won't work on the 6-cyl radiator.
So basically, you'll have to custom rig it. Not the hardest thing in the world to do, but that kit you linked to would be not be very helpful, since you won't be able to use the expansion tank or hoses that come with it. You'll also have to buy the smaller hose which connects to the 6-cyl expansion tank (along the top).
Honestly, in your case I'd just stick with a stock 4-cyl radiator setup. It's just not worth the extra effort.
1998 BMW 328is
1966 Pontiac GTO
Old 02-12-2013, 09:39 AM
Mein Auto: 93 318i
If i got the four cylinder radiator would that kit work. I got confused because the kit comes with an expansion but i thought that comes attached to the radiator & i also didnt like that the water pump with that kit looks to have plastic propeller and not metal. Any suggestions for sites with cooling system kit?
Sent from my SCH-I535 using Bimmer App
Old 02-12-2013, 09:48 AM
ZeGerman's Avatar
Warm Leatherette
Of course the kit will work if you use a 4-cyl radiator, but you were asking about using a 6-cyl radiator and then linked to a 4-cyl cooling system kit...
Anyway, I'd certainly recommend getting a water pump with a metal impeller, and not the one included in that kit.
1998 BMW 328is
1966 Pontiac GTO
Old 02-12-2013, 09:59 AM
Mein Auto: 93 318i
I think i'll jus make it easier on myself & jus stick with the 4 cylinder radiator. Now jus hav to find radiator & metal water pump. Is there anything not included in that kit that you think i should change?
Old 02-12-2013, 10:19 AM
ZeGerman's Avatar
Warm Leatherette
Yes, belts and the fan.
1998 BMW 328is
1966 Pontiac GTO
Old 02-12-2013, 10:25 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
If you put in 6 cylinder radiator you will need, as follows:
Standard replacement radiator 17111469179
New upper radiator hose 11531708499
New lower radiator hose 11531726344
hose from expansion tank to heater 11531730351
Expansion tank 17111723520
Expansion tank overflow hose 17111723521
also 6 cylinder fan shroud and 6 cylinder radiator cover
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 02-12-2013, 01:31 PM
Mein Auto: 93 318i
Thanx Yea i think i'll just stick with the 4 cylinder stuff unless the 6 cylinder stuff will be better for it...wanna get this done before i drive it had it for about 3-4 weeks
Old 02-12-2013, 01:49 PM
B1MM3R's Avatar
Jesse Moon Bayne
You will be fine with the 4 cylinder rad, theres no need to upgrade unless you are going to an aluminum radiator for track use. Way cheaper to stick with the 318 radiator. I had to replace all that stuff with mine because put in the m3 drivetrain.
Jesse
2001 330i DD
Old 02-13-2013, 07:54 PM
Mein Auto: 93 318i
Thanx for the help. Just finished ordering everything for the cooling system. Next will be suspension.
Old 02-19-2013, 01:02 AM
Frosty93 Frosty93 is offline
Mein Auto: 1994 E36 318is
I just bought a 318is and am looking for a good coolant system. Did you end up buying the link provided above, or a different one?
Old 02-19-2013, 04:05 AM
Mein Auto: 93 318i
No I ended up getting the kit from pelican parts the kit from that link came with some stuff you didnt need and also the water pump in that kit didnt have a metal propeller. Heres a link for the kits on pelican.
http://www.pelicanparts.com/cgi-bin/...FILTER_TOOL=ON
Old 02-19-2013, 12:16 PM
Thank you. Do you know if the waterpump kit for the 1996-1999 318is will work on a 1994 318is?
