The X5 SAV Forum
Old 09-18-2012, 04:21 PM
skiss skiss is offline
Mein Auto: X5
Question X5 sometimes crancks but won't start
Hi there,
I have an X5 3.0i (version E53) with M54 engine.
Recently I noticed a strange behavior: sometimes at a cold start in the morning (in summer even) the engine will not start.
The engine cranks and turns over as normally would but will not start. I can keep cranking it for seconds (longest I did 20 seconds) still the same result.
Leaving the car sit for couple of hours and next time will start at the first key.
I had may mechanic check out the car unfortunately nothing wrong came up (no error code, loose connector, etc.).
So far I couldn't find a pattern of this behavior... however I would say it's happening once out of 20 times.
Dear reader, Thank you in advance for any suggestion you may have.
Regards,
Old 10-10-2012, 04:46 PM
Mein Auto: X5
For the benefit of the reader:
Visit to the dealership did not help. After 2 days and over $200 (out of my pocket) for diagnostics the dealer recommended replacing fuel filter ($410) and/or fuel pump ($720) which I declined.
Planning to purchase filter from Amazon.com for $50 and install it myself and fuel pump (if required) for $335.
Will keep u posted
It is very disappointing to see all this human greed and ignorance around us...
Old 10-10-2012, 06:26 PM
DirtyDan's Avatar
DirtyDan DirtyDan is online now
Mein Auto: 2003 X5 3.0i
How many miles - I can see a fuel filter but not sure about a fuel pump. Yes dealers will knock you out of the park for price! BMW's are not difficult to work on as people think.
Old 10-10-2012, 08:23 PM
Mein Auto: X5
Thanks for the replay and thanks for the encouragement
The car has 150K, just bought it about 2 months ago, I am not sure if this a pre-existing issue or not...anyway will try replacing the filter (the pressure regulator is incorporated in it) and will see. Anyway the fuel filter looks old judging from it's exterior appearance (doubt that ever been changed).
Last week noticed a different behavior: while driving, after at a 4-way stop when about to accelerate, the engine stalled not starting anymore. The engine started again 10 - 15 minutes later (while waiting for the tow-truck )
Old 10-10-2012, 09:09 PM
DirtyDan's Avatar
Is the check engine light coming on? Have you had any codes pulled with an OBD-II scan tool under the driver side knee area? I have 127k on my 2003 3.0i and it has completely died on me a few times recently. It started right back up after pulling over. I cleaned the Mass Air Flow sensor and reset the check engine light that was saying PO172 lean bank 1 MAF. It is running fine now but when it dies the gas mileage has decreased. I do think you are changing the right part with the fuel filter. I hear that it is the cause of alot of issues. I have not done mine but I have run alot of STP and SeaFoam cleaner through it.
I know this is dumb but when was the battery last changed? These X5's have to have strong new batteries to run or fire up correctly. You need to check this out in the rear trunk under the spare tire. If older than 5-7 years it is probably another cause of no start.
Old 10-15-2012, 09:02 AM
Mein Auto: X5
No check engine light neither any error code stored. In my opinion the battery should be fine since it cranks the motor for long time with no power loss shown...
Old 02-19-2013, 09:47 AM
kosovoman kosovoman is offline
Mein Auto: 2003 X5 E53 3.0d Mod
I may be wrong but sounds like the seals wen't bad on engine right under the camshaft. Usually if it won't start on the mornings and after the vehicle been sit for a while, it's most likely the seals.
Again i may be wrong. Just trying to help.
Old 02-19-2013, 10:33 AM
DTANDJT DTANDJT is offline
Mein Auto: 2006 X5, 2005 Mini S
Check "spark sensor". Your symptoms happened to me. Battery and alternator and fuel were all good. Spark sensor had to be replaced for about $200. They also checked the wire harness but it was fine. Once they replaced the sensor, it started right up.
Old 02-19-2013, 12:08 PM
Mein Auto: X5
X5 sometimes crancks but won't start - Issue solved
Folks,
thank you all for taking the time and respond my posting with suggestions and ideas.
I am glad to say the issue has been solved. It turned out to be a loose relay in the DME box (located in the engine compartment next to the firewall).
Here are the troubleshooting steps followed that led to fix the issue:
1. measured fuel line pressure (this saved me from a spending approx.$2,000 on replacing fuel pump - recommended by the BMW dealer - LOL such a jokers BTW); this step could be accomplished by hooking up a fuel pressure measure gauge ($40) to the rail.
2. checking the spark signal: for this I've taken an extra spark plug, grounding it slipped the ignition coil on it and cranked the engine - this test showed clearly spark was present.
3. checking the injector pulse: took a long screwdriver, set the tip on the injector body and cranked the engine; when the engine was in mood to run a distinctive clicking noise was present vs. when the engine didn't want to start no clicking sound at all....
the 3rd. step lead me to the conclusion, that when the car is acting up and don't want to start then the injector pulse signal is missing although there is fuel under pressure at the injector. This conclusion made me to open up the DME black box and started thumb pressing connectors, relays and stuff.
Since then I haven't encountered this issue again.
Let me know if anyone has additional questions or concerns.
Old 02-19-2013, 12:26 PM
Get some contact cleaner from Rat Shack and clean all the contacts. If the connectors or relays and other stuff wasn't making good contact chances are that there was some arcing going on and you can have some carbon build up from the arcing.
Old 12-13-2013, 04:54 PM
IbraNafea IbraNafea is offline
Mein Auto: 2002 X5 3.0i
Gentlemen,
I have an E53 engine spins but won't start after parking for 3 days. Previous bad battery was replaced today with a dealer battery. Fuel pump fuse is fine. Car fuel tank is full. still won't start.
Haven't hooked up the computer yet. but I'll definitely let you know what codes I'll get.
BTW, A week ago I pulled out the GM module and got it fixed for a common issue with E53 GM module ( no interior lights and no look/unlock via remote). I Also replaced the final stage unit with an OEM piece. Now both the FSU and the GM module are working just fine but the car won't start. I'm not sure if this is related to the issue but I've never had this problem before even when both the FTU and the GM module were broken. I even unplugged both of them and tried to start up the car with the new battery but it wouldn't start. last time the car started fine was when I put the new FSU to test it and it worked amazing although I smelled some electrical odor but I thought it's the new FTU martial then I got my battery totally dead because it was bad battery.
Thanks you!
Old 12-14-2013, 07:13 AM
Mein Auto: X5
Lightbulb X5 won't start
Dear IbraNafea,
I had a similar issue approximately a year ago that I was to fix applying the following troubleshooting procedure...
Prior starting the troubleshooting there are two things to consider:
1. is the yellow "service engine on" because if it's not than more likely there is no error code logged in the computer that would give you an indication about the problem...
2. in order the engine to start you need two components working: gas and ignition (spark)
So now let's see the troubleshooting steps:
1. measure the fuel pressure at the injectors (e.g. - hence the procedure is similar for E53) - the fuel rail port on my car is located right under the 2 part plastic engine cover. - THIS TEST IS PROVING THE ENGINE IS GETTING GAS (no tinkering with the gas pump, filter or tank required)
2. get a brand new spark plug and plug it into one of the unplugged connectors (leaving the old spark plug in the engine. Ask someone to crank the engine for you while you have a visual on the new spark plug. In case you notice sparks forming on the plug while cranking proves the ignition signal is good.
3. Have a long screwdriver, place the tip of the screwdriver on the top of the injector itself and your ear on the top of the handle of the screwdriver. Ask someone to crank the engine for you...in case you hear a specific tick-ing noise (sewing machine like) your fuel injector signal is good
I found my problem on the 3rd. step above finding there was no injector signal which I tracked back to the injector signal relay (the one in the engine compartment, passenger side, next to the firewall).
I hope all this helps.
have a great day
Old 12-14-2013, 08:33 AM
Thanks for your replay skiss!
Afrer digging in the fuses board located behind the glove box ( dropped down the whole glove box)
I figured that the problem was the K96 relay ( fuel pump relay). I just plugged it out and in again. The car started right away. It didn't sound normal when I started the engine ( all lights were on in the dash) and I felt it was half engine running. Drove it for a lil bit just to charge the battery then turn it off and on again. The car is back and it's awesome and everything reset in the dash to normal!
I attached a pic fro my fuse box. The light green relay on the upper left side is the fuel pump relay.
Thanks: and have a wonderful day!
Old 12-14-2013, 12:17 PM
Mein Auto: X5
Glad to hear that! I bet you just saved a whole lot of money
My problem got solved in the same way... unplugging and plugging the injector relay back in.
It seems like these relays got loose in time from trepidation...
So, lesson learned people! Before going to the dealership and spend thousands of dollars (and still having the problem) try to go through these simple and inexpensive troubleshooting steps.
Bid a great day everyone.
Old 12-17-2013, 07:09 PM
smokimon001 smokimon001 is offline
Mein Auto: 2006 X5 3.0
is the fuel injector relay located behind the glove box too? per E53
pics would be awesome!
thanks.
Old 12-17-2013, 08:48 PM
Mein Auto: X5
The injector relay is located in the E-box - engine compartment, on the passenger side, under the windshield, see pictures and technical reference attached as requested.
Hope this helps.
cheers.
ID:	412886   Click image for larger version
ID:	412887   Click image for larger version
Old 12-18-2013, 06:14 AM
thanks Skiss, very clear instruction!
Old 12-18-2013, 06:29 AM
i am gettting the BMW X5 (E53) Service Manual!!
Old 08-14-2015, 04:59 AM
Guam135i Guam135i is offline
Mein Auto: 08 135i Coupe
I hope this is it problem is so intermittent its hard to diagnose and pisses me off
Old 08-17-2015, 08:53 AM
amberjason8 amberjason8 is offline
Mein Auto: 2011 X5
2011 x5, has been giving problems periodically about a slow start or not start at all......mostly on trips 2 hours or more. when we get out of vehicle and come back it wont start......this morning....wouldnt start at all.....all radio and everything....checking the fuel pump relay today.....lawd we pray this is it
Old 08-17-2015, 09:03 AM
Mein Auto: X5
Dear Guam135i & amberjason8,
Following the troubleshooting procedure (3 steps - given further above) will pinpoint the reason always. Just keep in mind these steps has to be executed WHEN THE PROBLEM IS HAPPENING.
Good luck!
Old 08-17-2015, 11:32 AM
Mein Auto: 2011 X5
We will definitely do that....Question....My husband came home and charged the battery...said it was dead.....Could this be the problem? No one on here has said anything about battery...
Also, my husband found the battery for 175..... but called BMW to see what they would say...battery was 350 and said they had to reprogram car.....is this true?
Old 10-17-2015, 02:31 PM
814Loso 814Loso is offline
Mein Auto: 2003 Bmw x5 4.4
03 x5 4.4
Hi I'm new to this and I'm going through the same problem mines is an 03 x5 4.4 truck stalls while driving out of nowhere took to my Indy now new pump flush gas tank an still cranks but won't start any ideas would be great thanks
Old 10-17-2015, 02:58 PM
Mein Auto: 2011 X5
We took it to our favorite mechanic. It was replace 2 turbos and he changed the spark plugs. The quote he gave was 1200. We researched the parts and got it down to 650. Hope this helps.
Old 10-17-2015, 03:01 PM
Mein Auto: 2011 X5
Wait. Sorry. I thought this was about our other problem we had. We did change the battery at our favorite mechanic. Did not go through BMW
We had our car do the 50% less power thing come up a month later.
If I were you. Research get on eBay. Buy you spark plugs for $67. And find someone who can reset your car
