E36 (1991 - 1999)
Old 02-18-2013, 04:05 PM
Ken328i Ken328i is offline
Mein Auto: E36 328i coupe
328i manual starting issue
hey guys its been over a month since my last starting issue which i have now sorted with a new ews system (chip, module and dws) and now my engine turns over where before it wouldnt but it still wont start. i believe i have fuel in the rail as i can push the bleed nipple and get fuel at the front of the rail.
now i checked the coil plugs loom plug and i get voltage in 1 pin constant but nothing at all when cranking the engine from the signal wires which makes me think crank sensors dead but i checked that and its fine, does the cam sensor also need checking (i not checked it yet not got a spare, had a spare crank sensor), i have fitted new spark plugs as the old ones looked burnt out and a set of coils that i no are good off another engine.
reason for these issues is a accidently wired a earth to the ignition wire on the starter which melted the ews module hence the new one, the new dws box matches my old one numbers wise but can these b different? really getting to the limit now with this car and getting tempted to strip it but i really want it fixed as i enjoy it so much so any ideas would be gratefully recieved, thanks Ken
Old 02-19-2013, 10:43 AM
just to update if anyone can help me out i checked all fuses were good and had correct power supplies and all were good.
i fitted a new crank and cam sensor and still nothing.
also did the ignition test as stated in the bently book and i have power at terminal 15 (just over 12 volts, battery was fully charged).
thinking tomorrow i will buy a new relay and try that, im getting very concerned now that i was sold a duff ecu so need to find someone who can test it or get a scanner on the car but any input would be great
Old 02-19-2013, 10:52 AM
B1MM3R's Avatar
B1MM3R B1MM3R is online now
Jesse Moon Bayne
Mein Auto: '93 ///S50 powr'd 318is
Sounds dumb, but are you pushing the clutch all the way to the floor when trying to start it?
Jesse
Part out.
http://bimmerfest.com/forums/showthr...67#post7418867
"Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI
Stock 2004 X5 3.0i (Wifes)
E30 87 325e
Old 02-19-2013, 11:02 AM
not a dumb question but the uk cars dont have a clutch switch, well i never had to put it in before i changed the engine and i have tried pushing it down having noticed he US spec cars have this switch
Old 02-19-2013, 01:04 PM
petriej's Avatar
petriej petriej is online now
Cruising 280 Top Down
Send a message via Skype™ to petriej
Are you related to Bob328i?
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by SCJon View Post
Jared is king of ambiguous comments.
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 02-19-2013, 02:44 PM
B1MM3R's Avatar
Jesse Moon Bayne
Jesse
Part out.
E30 87 325e
