E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
#601
And some people HATE that headlight washer feature so much that they desperately have the dealer deactivate it. I just hit the windshield washer stalk in short bursts to clean the glass without activating the headlight washers.
Check your mirrors as often as it takes for you to know where everyone is around you! |
#602
The headlight washers on come on when the headlights are on... Soo if you don't want the headlights washed make sure your headlights are turned off... Turn off of auto... Your lights are on more then you think...
Sent from my LG-LS840 using Bimmer App |
#603
![]() Thanks |
#604
Put your finger near the keyhole on your drivers door handle. The doors should lock immediately. If you leave your finger there, the windows and sunroof will close. This assumes you have comfort access.
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod |
#605
Yes, I meant the door handle outside. The same procedure as locking the door with comfort access but you just leave your finger there a little longer to start the windows.
Mike Swing |
#606
I'm pretty sure it works the same as described with the clutch. Happens to me by "accident" every once in a while and I never remember to try it on purpose. Sometimes I get in, push the button - nothing happens - then it starts. I think it starts after I press the brake pedal.
2008 535xi: Sport, Night Vision, NAV, PDC, HUD Mods Rear Seat Heat Retrofit, Passport 9500ci, HD Radio Retrofit Shock Sensor Alarm, Sport Automatic Retrofit , Active Backrest Retrofit, Fire Extinguisher, PROcede with Meth Injection |
#607
I DO have an oil dipstick. This is after 3 years of reading that on the earliest models had one. I was replacing my enigne air filter and saw something coming from the back of the engine bay and started pulling on it because it looked like a dipstick and it was!! BTW my car is an 06 550, so maybe they removed it in 07 and later models.
eBay Stuff http://myworld.ebay.com/etnav382 Sport Steering Wheel w/Paddles, M5 cluster |
#608
That sh*ts hilarious
#611
Just bought 545i
![]() Realized rear sun shade is jammed (stealer wanted $1200 to fix and previous owner declined) and slight slip going from 1st to 2nd that I detailed in this thread: http://www.bimmerfest.com/forums/sho...d.php?t=676902 |
#612
I hope to god they added one--it's a royal pain trying to check transmission fluid level without one (i.e. engine on, under the car, taking bolts out to see if oil drains out or not..) |
#613
If you have the four way flashers on and you activate the left turn signal, the right side flasher turns off and vice versa.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats. |
#614
This is awesome during a caravan. It lets the other bimmer drivers know your intentions (lane changes) without having to deactivate the hazards momentarily by hand.
#615
I just noticed the driver side make up mirror and how the ceiling light just above it is activated when you slide open the mirror cover.
#616
How bout this one guys,,,, when ur driving along loving your car... Then out of nowhere that dreadfull sound.... the chime goes "DING !! " Idrive says MALFUNCTION !! .... makes ur heart drop and ur like.. OH **** !! What the HELL ! .. and can practically feel ur wallet open up ... lol!....
I found out you could reset the State Inspection and the Emission Inspection service indicators in the iDrive menus.
- Robert A Current: '07 530i, White/Black, MT Retired: '01 530i, '94 325is, '84 325e, '83 318is |
#618
Sent from my GT-N8013 using Bimmer App
85 Honda Accord(Sold), 93 Lexus GS 300(Gave to lil Bro), 96 Lexus LS 400(Sold) 03 BMW 525i(Traded/Sold), 06 BMW 750Li(daily driver), 07 BMW 530i(My Baby's daily dirver) |
#619
Went to use navigation in my '05 545i and the street address was too new to come up. So, I put the address in my iPhone using Google Maps. To my surprise, all of the voice directions from Google Maps on my phone came through the car's speakers! I tried it with Apple's Map app and the Mapquest app and neither of them utilize the Bluetooth connectivity to provide turn-by-turn directions through the car itself.
2005 545i, Jet Black, Black Leather, Cold Weather pkg, Logic7, 6 disk changer, Sport Package, Automatic, moonroof, electric rear sun shade, dark wood trim, PDC, Xenon Adaptive lights, Nav, Sat radio, 245/40 ZR18 - 275/35 ZR18 tires, Progman 30.02 |
#620
Actually, it happened to me last week unexpectedly ( but one time only) while using the Apple app, and took me fully by surprise. I tried to duplicate it, but it never happened again. Did not try any of the other nav apps on my iPhone. Should work great with the map showing on the iDrive screen. Will try that later.
2008 535i Monaco Blue PP, SP, SAT w/paddles, AS, CA, L7, NAV, PDC, Heated F Seats, SIRIUS, iPod+Aux, Bamboo Anthracite Wood Trim, Gray Dakota Leather |
#621
Re bluetooth map voice, I found out the Google Maps will work, but not Apple or Waze. I actually find it a little annoying, because Google keeps cutting into my music. In my old G35 with Nav, the music would be turned down while she told me where to go. In my 550 with no Nav, Google just interrupts the music! Is there a way to turn off the bluetooth map voice?
#622
If it ever stops doing it (happens to me if I force the phone to use the built in speaker/mic sometimes), you need to hold the home button to get siri to pop up, then change the output source via the button to the right side of the screen to switch it back to using bluetooth/your car speakers. |
#623
Awesome thread! wow at the things I would stumble across most likely months after purchasing! Thanks everyone!
LMFAO. |
#624
![]() Schwarz | Premium | Sport | Nav | Sat | Paddles | PDC | Lead Foot | Hardwired Passport 9500ix w/ Escort Live | Convenience | Matte Grill | JB4 | DCI | LI Jammers | smoked side markers | Specdock | rear spoiler | AutoWerke BOV | BMS Oil Catch Can | R1 Cross Drilled Rotors w/ Hawk HPS pads | BMWCCA Peachtree Chapter Member 444107 |
