E36 (1991 - 1999)
Old 02-20-2013, 02:01 PM
NW E36 NW E36 is offline
Mein Auto: 93 325i
Bleeding the cooling system question
So I bought my 93' 325i sedan 3 days ago and saw that the temp gauge was always up and down and then realized that my car never blows truly hot air. So i decided to try and bleed the cooling system by watching a DIY on these forums.
It seemed easy enough after watching the video so I went out and gave it a try. It seems no matter what I do I can never get all of the air bubbles out. I tried for 35 minutes last night squeezing the hoses and just kept on getting air bubbles out of the bleeder.
Thanks for the help in advanced, this is my first BMW I have ever owned in my 7 years of driving so I am new to these car, but love turning wrenches and working on cars.
Any light on why this could be? Thermostat possibly? and is it safe to drive this way?
Old 02-20-2013, 02:02 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
You have to build the pressure back up after releasing the bubbles.
How I do it is drive car for few minutes till at operating temperature and then bleed. Drive car more then bleed. Drive car more then bleed. So on and so forth untill all bubbles gone.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
Old 02-20-2013, 02:04 PM
Mein Auto: 93 325i
OK thank you for the input, very much appreciated.
Is it safe to drive this way? Because i got work in about an hour and don't want to risk overheating it.
Old 02-20-2013, 02:05 PM
B1MM3R's Avatar
Jesse Moon Bayne
Dont let it get past 12 oclock operating temp. Do you have enough coolant in car?
Jesse
2007 328i DD
Old 02-20-2013, 02:06 PM
Mein Auto: 93 325i
Yes I made sure of that last night. It is all topped off
Old 02-20-2013, 02:16 PM
B1MM3R's Avatar
Jesse Moon Bayne
Is the needle going past 12 oclock?
Jesse
2007 328i DD
Old 02-20-2013, 02:20 PM
Mein Auto: 93 325i
Nope doesn't even get to 12 oclock, get to just a sliver under. i know the guy put a new radiator in it in December of 2012 still have the receipts int he glovebox
Old 02-20-2013, 02:21 PM
B1MM3R's Avatar
Jesse Moon Bayne
SOunds like you got a bad thermostat. Seems like its stuck open not allowing to get to operating temperature.
Jesse
2007 328i DD
Old 02-20-2013, 02:24 PM
Mein Auto: 93 325i
Ok, so should I not drive it to work until i put in a new thermostat?
Old 02-20-2013, 02:27 PM
B1MM3R's Avatar
Jesse Moon Bayne
I mean its kind of hard on the engine to not get to operating temperature b/c the moisture in the engine never gets burnt off. Id not drive it untill I put one in it if was my car. Also get the aluminum one, the plastic ones stink.
Jesse
2007 328i DD
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Agreed, it does sound like a stuck thermostat. Keep bleeding the system until no more air comes out. If you keep bleeding it for days and days, and air stills gets in/comes out, you won't want to hear what we have to say...
1998 BMW 328is
1966 Pontiac GTO
Old 02-20-2013, 02:32 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
Follow this video if you haven't already.
Mein Auto: 93 325i
Uh Oh! well hopefully the thermostat will fix the problem haha. Luckily one of my buddies runs a Euro Specialization shop so if I run into any problems I should be alright in that sense as long as I got the money to afford parts and some beer haha.
Old 02-20-2013, 02:33 PM
Mein Auto: 93 325i
and yes this is the exact video I went off of
Old 02-20-2013, 03:41 PM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
Its ok to run with an open thermostat, better than a stuck closed thermostat. Engine won't run optimally, you may get O2 sensor CELs, but its not the end of the world.
Old 02-23-2013, 01:37 PM
evoroadster evoroadster is offline
Mein Auto: 1997 328i
I believe you mean for him to replace his thermostat housing (plastic) with an aluminum one when he changes the thermostat itself.
