E36 (1991 - 1999)
Old 02-19-2013, 09:48 AM
mykgarren mykgarren is offline
Mein Auto: 96 328iC
reengaged vert motors and reset. now what?
After figuring out my newly purchased 96 vert did NOT need a new motor (like I claimed to the used car guy who sold it cheap thinking it did. I reset both vert motors. Held the "up" switch, cut on my car, and the top reset. The lid popped up, my top came out the lid slammed shut and I locked my top. Now release the top, roll .down the windows. And hit "down" and I get nothing. Short of the button only working in one direction. What else could I be missing? - bummer bummer
Old 02-19-2013, 09:51 AM
hornhospital's Avatar
D'oh, You Kids!
This should help:
http://www.bimmerfest.com/forums/sho...d.php?t=639047
Quotes to live by:
BMW-CCA #441426
Old 02-19-2013, 10:26 AM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Did you actually trick someone into thinking his motor was bad or did the guy advertise the car with a bad motor and you just did not correct him?
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
dc_wright's Avatar
dc_wright dc_wright is online now
It's not synched. To perform the actual synch the top must be in the down position and you hold the switch in the "down" or "open" position. Go to the link Ken provided and download the file resettingconvertibletop.pdf and look at page 5. It will state this too. What has likely happened is you put the top up with it unsynched and the position circuits in the motor and the microswitches in the top mechanism are out of synch. When there is any mismatch of inputs the top freezes where it is to prevent any damage.
I would try a complete resynch (correctly) and then see what happens. To do this you will have to release the motors again and manually put the top down. Then reengage the motors and resynch. Then try closing and opening the top and see if it still freezes in the down position.
Also assuming that it's the semi auto top (there's a handle in the front to lock it down to the windshield) to get the top to go down you have to release the handle and push the front part of the top up past the tension point (12'-18") manually before the motors take over and do the rest of the lowering.....
Old 02-19-2013, 10:37 AM
Mein Auto: 96 328iC
Thanks, that sounds like exactly what I did. (Guy on YouTube was full of sh@5). And yes I , I knew when he said the top woukdnt got down and the trunk wouldnt open that they were related. He dropped the price 100$ for it.
Old 02-19-2013, 10:57 AM
dc_wright's Avatar
If you pushed the top button to the "close" position as you stated in your original post you didn't do the resynch. The top only resynchs when it's down and you hold the button in the "Open" position for 10 seconds after the ignition is turned on. The synch location is with the top fully opened, not fully closed because fully opened is the only end of the travel under control of the motor and the top controller.
Old 02-19-2013, 01:52 PM
Mein Auto: 96 328iC
So by resetting the motors, then holding the switch to the "down" position. Will sync my motors, correct. Then I can close and open with the toggle afterwards?
Old 02-19-2013, 03:40 PM
dc_wright's Avatar
Correct. Just download the file and follow the directions.
Old 02-20-2013, 11:44 PM
Mein Auto: 96 328iC
Ok., I'm.getting frustrated. Reset motors. Lowered top manually,Pushed the trigger to the "lowering" position. And turned the key to the."O" ,held for 10 seconds them turned to the nonstarting but radio playing postion and hit "close" which it did. But "down" didn't lower the roof. Im obviously am not synced but the diagram I downloaded and followed to a "T" any other steps I'm missing or should I start looking for wiring shorts?
