Adjusting camber on my 95 318 ti - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-20-2013, 08:57 PM
black ti black ti is offline
Mein Auto: bmw 318 ti
So I heard the rear end on my ti is an e30 but my car is an e36. Is it true that the only way to adjust the camber (lowered) is to buy a "weld on" kit? Tired of buying tires! Just did the front but I am lost on the rear.
Sent from my SGH-T999 using Bimmer App
Old 02-20-2013, 09:02 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
http://jj100d.blogspot.ca/2011/03/e3...ike-legos.html
This should give you most of the info you need.
Ed
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-20-2013, 09:05 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Talk to the E30 guys about camber adjustment. They'll get you sorted out. You shouldn't have to any welding, though. Just install parts.
1998 BMW 328is
1966 Pontiac GTO
Old 02-20-2013, 09:47 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
here....http://store.bimmerworld.com/rear-ca...18ti-p889.aspx
the ti uses an e30 rear suspension set up, unlike the rest of the e36 lineup. it's also the same as the z3. these do not suffer the ill fate that the rear subframe mounting points do in the rest of the chassis. although i do believe the z's had someting going on, but since i don;t own one i cannot state for certain what or why. but the ti is fine as it is.
unless you drop a small block in it....
akg makes rear sway bar tab reinforcements that weld in, but that is about it.
df
Old 02-20-2013, 11:04 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
df
I've installed their caster and toe kit in an E30 subframe. It is a lot of precise setting up, measuring and welding, then a lot of tedious grinding, opening up the rear trailing arm bushing mounting plates to slots, so that the camber and toe are adjustable using BMW OEM M5 bolts. The bolts have an integral offset washer under the head, and one that is keyed to the bolt shank under the nut. By turning the washer, you can change the camber and/or toe settings, since the offset washer moves the centering of the bushing by bearing against the welded-on plates. Very simple concept, but a lot of work to do.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 02-21-2013, 06:05 AM
atk makes a camber/toe kit?? didn't see it listed. might have ben looking in the wrong section, too....there's only a few things i saw for the ti on their site.
will most likely do something like this on the ti myself. just have to finish off this parts car first before i can start getting into the working on the ti.
soooo many things to get done....no funds...
df
