The X5 SAV Forum
Old 10-29-2012, 10:43 AM
X5CLUB X5CLUB is offline
Mein Auto: 2005 BMW X5
DSC 4x4 Inactive light
I've got a 2005 X5 4.4 and the DSC Inactive light recently came on (no other lights). When it comes on, it just pops up and stays on for the remainder of the ride. When I restart the car again the light is off. There are no noises and nothing feels unusual about the drive. After reading about wheel speed sensors I thought that maybe one was off because of tire pressure. I filled the tires and didnt see the light for about a week or so. It popped back up today. I took it to the shop and they say they are getting a Transfer Case code when running a diagnostic. I'm a little skeptical. I want to make sure it's not just the sensors or alignment throwing a false code or something like that before I drop $3200. Any ideas or suggestions?
Old 10-30-2012, 02:06 PM
Mudnyrey Mudnyrey is offline
Mein Auto: X5 3.0i
Not too familiar with this problem yet, but found this ling for you.
I know there are four sensors, maybe one of them is bad and needs to be replaced?
http://www.xoutpost.com/bmw-sav-foru...ing-light.html
~Mud
Old 11-02-2012, 03:40 PM
88keys4u 88keys4u is offline
Mein Auto: 2006 BMW X5
Sounds like the way my alternator problem started....
Old 11-07-2012, 06:43 AM
TL555 TL555 is offline
Mein Auto: BMW X5 4.4i
DSC 4X4 Light on
i experienced that problem on the 2006 X5 4.4i. The light would come on and off on its own, then there was the Trans Failsafe Programme warning light after a couple of months. After replacing two batteries in two months (second one for free), it turned out my problem was the alternator. Since replacing that baby, i havent had that problem....
Old 11-14-2012, 08:13 PM
Turo37765's Avatar
Turo37765 Turo37765 is offline
GO GET IT $
Mein Auto: F10 550I
Mine just turned on. Hope it's off in the morning. Battery was dead after just a few days. Had to boost it. That's when 4x4 light came on.
Old 02-14-2013, 06:08 PM
JNMNL52 JNMNL52 is offline
Mein Auto: 2006 X-5 / 2002 330i
I had the same problem and it turned out to be an early warning sign of a faulty alternator.
JNMNL52
2002 BMW 330i
2006 BMW X-5, 4.4
Old 02-21-2013, 10:20 AM
SIMONSKI SIMONSKI is offline
Mein Auto: E53 02 X5
I have an E53 3.0d and have the same warning but with some very real symptoms like as if the brakes are on whilst trying to drive ,i recently renewed my front end bushes could it just need recalibrating ??????
Old 02-21-2013, 10:28 AM
In my situation the brushes were fine upon disassembly. The voltage regulator itself was the problem. At first I just had the 4x4 dsc light on; then other lights would come on periodically in the brake system.
JNMNL52
2002 BMW 330i
2006 BMW X-5, 4.4
Old 02-21-2013, 12:40 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
If you had a bad wheel sensor, the DSC, ABS and brake lights would be on. Most likely a battery or alternator that is not charging the battery.
Old 02-21-2013, 01:34 PM
But would this give the juddering symptom ?
Old 02-21-2013, 03:03 PM
In your case, the ABS is kicking in because it sense a wheel that is not rotating (probably due to a bad wheel sensor). Some time it's not good to hi-jack another person thread because most of the answer is directed toward the original poster.
If you have a problem, just start your own thread.
Old 02-23-2013, 07:02 AM
point taken ! btw it was my front right abs sensor!
Old 02-23-2013, 09:28 AM
Thanks for posting the solution to your problem. Many time people come on this forum posting about their problems but when they fix their problem they fail to provide the solution or cause, so the thread is worthless to anyone else with a similar problem.
4.4, 4x4 light, dsc light, e53
