help with obd1 harness - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-20-2013, 06:19 PM
fickett325 fickett325 is offline
Mein Auto: 325is
I have a 93 325is. the guy before me had put a s50 528 in and a 325 head and a obd2 conversion. im having trouble figuring out what he screwed up can anyone help me with details on how to properly convert a obd1 harness to an obd2 harness so i can fix this hack job. Also possibly how to wire an E-manage into the harness because the e manage should take place of stock computer so it wouldnt throw codes but i dont think its properly installed because my check engine light comes on. if i could find a bentley manual i probably could figure it out mysdelf but no luck on that
Old 02-20-2013, 07:03 PM
hornhospital's Avatar
D'oh, You Kids!
Manual, LARGE .PDF. Right click and "save as":
http://api.viglink.com/api/click?for...13614148271693
This may do you more good with the electricals, the ETM for a '93 325:
http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
S50 was not a 528 engine (2.8 liter). S50 was a 3 liter engine, not 2.8
Why would someone put an M50 (325) head on an S50 (or 2.8)?
Quotes to live by:
BMW-CCA #441426
Old 02-21-2013, 01:44 PM
Mein Auto: 325is
apparently the block is better to turbo and the head i believe has a lower compresssion rate it has a turbo on it. thanks for the suggestions
Old 02-22-2013, 01:38 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Going OBD2 for a turbo project is wrong, though. Bad monkey! Why did you buy this?
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 02-22-2013, 08:03 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
ken, the head for the m50/m52/s50/s52 appears to be the same casting.
the idea that one may be 'better' than another is a bit confusing, since the 323 apparently uses this casting as well as the e34 (525).
there is a 400 designation on some castings that is supposed to (somehow) be 'better', and therefore is a bit more pricey (for some reason...), but i cannot seem to find a consistent answer as to why.
i certainly isn't because it's a "//M" specific head, since it was used on multiple engines...
so op, the head makes no difference. the crank would, but that's a different subject from what was posted here.....
oh, yeah....the llinky...almost forgot
http://www.realoem.com/bmw/partxref.do?part=11121703637
df
Old 02-22-2013, 09:36 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
The M50 and S50 use different heads, and but the M52 and S52 use the same head (but still different than what was used on the M50 and S50).
1998 BMW 328is
1966 Pontiac GTO
Old 02-23-2013, 06:44 AM
i figured that the e36 m50 was a different part number, as it was not listed, but the e34 was. wasn't the e34 using an m50 as well??
also, the 323 is listed as using the same head.
i have not looked at these side by side, but i would figure the difference may be in the combustion chamber cc's?? i do not remember seeing different valves listed for these guys when i was looking that up the other week...
df
