E36 (1991 - 1999)
#7751
Sweet Brad!!!!!
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e |
#7752
Today I replaced my brakelight switch and my passenger side now works but my drivers side does not...
97 M3, KW V2 C/O, shark injected, SS Headers, AA Exhaust, Apex Arc8s, Daily Driven, POS, Slammed! |
#7754
The brake circuit switch shouldn't make a difference regarding left & right. Check your connections, and socket & bulb contacts.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
#7755
Yeah well last night I had no brake lights at all. I think my socket on the drivers side just has bad contact points, at least i got 2/3 now I guess better than none haha
Suspension question. I bottom out too often in the rear. I know I need to raise it a little, but is it bad to trim the bump stops. Say I cut them in half so the shock would still never fully compress?
I have never heard about doing this before tonight and have no idea if it's a common thing.
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
#7757
If you're hitting the bump stops on your shocks often, then I think you have another problem that needs to be looked at. What is your shock/spring combo? Also, are your shocks blown or springs cracked?
-CJ
#7758
Struts are AST. Springs I really don't know. I need to change them to something stiffer but that won't be that soon
#7759
Well there's your problem. My guess is that you have shock springs. Look into H&R sport springs... They're cheap.
-CJ
#7760
Well they are the ones with adjusters. And it's not like I'm sitting on the ground either, it's just a moderate drop. Seems like the only option is to just raise it with this suspension.
#7761
Replaced this! World of difference
#7762
#7763
Camshaft position sensor.
#7764
What was she doing Brad? :o
Nice! Overall performance better or just cold starting ?
#7766
Travis. You need a stiffer spring.
Sent from my Desire HD using Bimmer App
nothing.
#7767
Dropped the X5 off and the shop....praying its cheaper than I expect
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e Last edited by B1MM3R; 02-22-2013 at 07:33 AM. |
#7768
well my bump stops are shot. a recommendations other then the stock foam or what ever they are. mine are cracked and separating.
![]() 1993 BMW 325i 1990 VW passat wagon 1987 jeep(AMC) cherokee 1979 VW westy rabbit 4 door |
#7769
Yea that's what I was thinking. 500 was the stiffest available when I bought the set. Would 650 be too much for a somewhat daily car?
#7770
I don't know Travis.
I have stock racelands and I cut a coil off.... And I don't bottom out that much. But keep in mind I always ride on the bumpstop at my summer height. I literally ride on my bumpstops. If your worried about the shocks get some kyb shocks for a e30. Mounts are all the same just different travel heights. Sent from my Desire HD using Bimmer App
nothing.
#7771
I really like these shocks so they're staying. I think I might just raise it anyways to allow for the wider tires.
I'm about 1/4" from my stops right now. I only hit them over big bumps but I'd like to avoid them all the time.
#7772
#7773
http://www.pelicanparts.com/bmw/cata...pg4.htm#item22
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
#7774
Brad valveing won't help his case. It's a case of piston lenghth inside the shock and travel amount.
Only option if bottoming out and worried is e30 shocks Sent from my Desire HD using Bimmer App
nothing.
#7775
Btw people. Those lights we bought are indeed depos. And go buy yourself h1 bulbs now. Haha
nothing.
| Tags |
| :3 |
