E30 (1982 - 1993)
Transmission mounting problem
Hi all,
I recently replaced the guibo and center support bearing on my girlfriend's e30 ('89 convertible, 5 speed). After putting it back together, the transmission sits high on one side, and it makes a scraping sound when it's in any of the 2nd and 4th gear (the rear gears). I had a jack under the transmission for part of the job to stabilize it. I also raised the engine several inches (by the oil pan) to lift the engine, so I could put the motor mount back on the passenger side (had to remove temporarily it to get some working room to get the exhaust off). See pic below. What is making the transmission sit high, and what can I do to fix it?
Looks like you ripped one of the tranny mounts. The one on the left in the picture looks like it's separated.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
The transmission is supposed to rest on that mount. For some reason it is sitting elevated above it. Any ideas?
Because it's separated. It's junk. Replace it.
go solid mounts
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
Anyone got a parts car, or work-in-progress, they can loosen one mount on? I'd like to confirm for sure that 'a new mount' is going to fix the problem. I have a feeling it won't. Thanks.
Found the rubber mounts, thanks. I was asking about the solid ones.
I wouldn't recommend solids for a daily driver. Too much NVH.
all the places ive seen them dont have them anymore or the website doesnt work. but ive only searched the 2 i can remember
OP, check the right front engine mount (diagonally opposite) hasnt collapsed.
Found the noise coming from gears 2 and 4. There's a circular piece of metal (stabilizing part?) that goes around the driveshaft, it's part of it, you can see it (the circular part in the upper right corner) in the picture. It rubs against the 'arm' that runs between the bottom of the shifter and the transmission.
I think the driveshaft is holding the transmission higher than it normally should be? Is there a specific way to lower the driveshaft. I don't want to drop the exhaust again... Last edited by Bimmer980; 02-26-2013 at 07:03 PM. |
it does automatically shorten unless you bent/was given the wrong CSB when doing the first project. i would really turn your focus at the engine and tranny mounts before you start messing with the driveshaft again
Get brave and admit it went wrong in the re assembly stage. take it to bits and put it back together properly - maybe using a manual this time. No easy way out of this.
It could have (possibly) gone wrong, but the rest of your post is reaching, quite a bit. We'll save our 'other' opinions for later. Thanks. Last edited by Bimmer980; 02-28-2013 at 04:08 PM. |
fixed it
For those wondering,
The transmission mounting bracket is asymmetrical, and I had it turned around backwards |
dont know how i missed that, i was even looking at the picture for a second time now before reading your post above thinking gosh that right side mount looks squished like the marshmellow part of a s'more lol
