Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 02-22-2013, 10:07 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
Motometer Odo problems
So I bought the Gargistic Motometer Odo kit. I installed it, and it still doesn't work. I spun the gears as I installed and everything was smooth and spun freely. I installed the cluster back into car drove down the road still with no odometer. I do not have the green plug on the back of the cluster but to my understanding thats only for cruise control anyway. Anybody have any idea why it won't work. I emailed garagistic still waiting for a response.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap, Mustang GT Injectors, Port/Polish
Old 02-22-2013, 02:55 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
does your speedo work?
Old 02-23-2013, 07:16 AM
Newman271's Avatar
That Guy
Mein Auto: 85' 335i
yeah it works. So last night I pulled the cluster back out and checked everything, everything is still good.
I bought another cluster from the junkyard last year. I accidently bought a vdo gear set up from garagistic, and luckily I did. I found out this morning my spare cluster set up is a VDO and so I replaced the gears and put the VDO speedometer in the Motometer gauge assembly. Im installing it before I leave work and hopefully this one works.
1985 335i
Old 02-23-2013, 02:51 PM
yes VDO and moto meter are cross compatible
