Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 02-20-2013, 12:38 PM
manny380sl manny380sl is offline
Mein Auto: 2005 bmw z4
vanos valve repair
hello im new to this forum i would like to ask a few questions regarding the vanos valve. i have a 2005 z4 with approx 79,000 miles. i have noticed that the car is not as quick as when i first purchased it 3years ago. i was thinking about repairing the vanos o-rings as precautionary now my main question is on this perticular model do i have to set the timing? and do i have to lock down the cams? i have noticed on you tube that they just pull the valve out. is it this straight forward ? thanks
best regards Manuel
Old 02-23-2013, 11:24 AM
skier's Avatar
skier skier is offline
Mein Auto: '15 M3
There is a section dedicated to your car, move your question there. This section is for E89 Z4, starting with MY 2009.
Old 02-24-2013, 09:49 AM
HerrK's Avatar
HerrK HerrK is offline
Mein Auto: 2011 Z4 35i
best regards Manuel
Rebuilding the Vanos (O rings) requires removal of the valve cover. If you replace the seals and all associated geaskets yourself it is about a 4-6 hour job @ about $120 in parts or you can buy a rebuild Vanos assy & associated gaskets @ $1500. I've done this on my wifes' & son's 3 series E46 with M54 powerplants. Here's a couple of links that have some great infor. Might as well replace the plugs while you have the top end opened up and upper the O2 sensors as well.
http://www.beisansystems.com/index.html
http://drvanos.com/index.php?option=...&id=5&Itemid=6
HerrK - Keine Eifelfahrt ohne eine Runde über den Nürburgring
May 2010 ED l 2011 35i l Crimson over Ext'd Coral Red w/brushed Alum l 6sp MT l Prem Sound l Sport Pack l 296's l Comfort Access l Alarm l Power Heated Seats l & Nav.
FrauK - 2014 Q5 TDI - May 2014 ED | Cuvée Silver over Pistachio beige | Premim Plus | MMI | Nav | B&O
