Old 04-18-2010, 11:35 AM
knight4825 knight4825 is offline
Mein Auto: 2004 BMW X3
Question Remote key not working
I have a 2004 x3 and the remote key no longer works. It was working on and off for about a few weeks and now, nothing. It won't set the alarm, open trunk,or open doors. So the question is.... will reprogramming work and if so how do I do that? Or is it the battery, and can I replace it? I know that its rechargable every time you drive. Has anyone else had this problem?!?
Old 04-18-2010, 12:57 PM
ducx3 ducx3 is offline
sapper
Mein Auto: 02 WRX, 06 X3
It's the battery and I don't think you can replace it. Do you do any long drives or all of your drives short? Had the same problem and I took it for a 4 hour drive. Charged it right up.
Old 04-18-2010, 01:19 PM
Mein Auto: 2004 X3 2.5i
Sounds like you have mislaid your 2nd. rechargeable key (or bought used, and did not get the full complement).
Having the 2nd. one would allow you confirm whether the problem was with the key, or the car.
If it is a battery problem, some people have successfully done it on a 3 series - but not for the fat-fingered.
See:
http://forum.e46fanatics.com/showthread.php?t=451510
Might be worth trying the reprogramming first.
Old 04-18-2010, 01:49 PM
sapper
Yes, do the reprogramming after the long drive if it still doesn't work.
Old 04-18-2010, 02:50 PM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
All of the above. There has been successful replacement of the battery in the X3 keys as well, with a radio shack battery. The poster (with a very detailed DIY photo sequence) alluded to the fact that (as I recall) getting the key head apart was the hardest part. It was awhile back, I believe. It does need to be soldered in, not just a drop in change.
Old 04-18-2010, 02:53 PM
yeah I have been on many a long drives and it hasn't charged it. Where is the reprogramming sequence that I should follow? thanks for your help.
Old 04-18-2010, 04:35 PM
sapper
Put the working key in the ignition. Turn to position 2 for like 1 second then back and remove the key.
Press and hold the "unlock" button then press the "lock" button 3 times, you should hear all the locks cycle through.
Now take the non working key and press and hold the "unlock" button then press the "lock" button 3 times.
Then turn the ignition on and off again to end the programming....
Old 04-19-2010, 04:41 PM
Wink
Worked perfectly, thank you guys for your help.
Old 04-19-2010, 08:57 PM
sapper
Great to hear.
Old 02-24-2013, 03:39 PM
This, from the E39 bestlinks, can also help others, so I post it here for reference:
- How to replace the old-style BMW square key battery (1) (2) & how to replace the rubber key pads in the square keys (1) (2) & what the red LED indicates on the old square key (1) & what can go wrong with a key and where to send it for repair (1) (2) (3) (4) & what battery to use in the new style 2000+ BMW E39, E46, E53, E85, etc. diamond key (1) (2) (3) (4) (5) (6) (7) & youtube videos of diamond key repairs (1) (2) (3) & a square key to diamond key retrofit and transponder swap (1) (2) (3) (4) & diamond key to square key retrofit questions (1) & how to recharge your key out of your BMW and how long that key will last in the drawer before it needs that off-the-car recharging (1) & the details on swapping the BMW diamond key transponder (1) & the proper diamond key initializing or programming sequence (1) (2) (3) (4) (5) (6) & what to do if your only key is locked inside your bimmer (1) & a description of the various types of BMW Remote, Illuminated, Spare/Wallet, & Valet/Service keys (1) (2) & a list of diamond key EWS, FZV, & DWA functions (1) (2) & all about the 10-key limit to programming your own keys at home (1) & a description of the ignition key ISN (individual serial number) ten-second rule (1) & what to do if you lost your only diamond key (1) or what to do if your BMW key was stolen (1)
Old 04-22-2013, 04:07 PM
onlybimmer onlybimmer is offline
Mein Auto: 525i
guys - hi..
my diamond key will not sync.. have misplaced the second key. what options do i have..
the dealer wants to charge me $220 for a replacement key.. that is way too expensive...
any options.. BTW cant solder anything so replacing the battery myself is out of question here.. if i try i am +ve i will mess it up.
any help in getting a cheap solution will be greatly appreciated...
