Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 02-24-2013, 11:22 AM
mr-g mr-g is offline
Mein Auto: BMW 530i
Homelink programming problems with Genie
Looks like I found the problem programming my homelink for the Genie opener. It does not work with the small keychain remote. You have to use the larger remote and it probably is an indication that it needs a stronger signal to capture the code in the first step, so fresh batteries may also be a solution. For the actual programming, follow the two step process and it works fine. G
Old 02-24-2013, 11:38 PM
Ace535i's Avatar
Ace535i Ace535i is offline
Mein Auto: Xe
Wow a Genie garage door opener....I haven't heard that name in 20 years!
