Old 02-20-2013, 03:26 PM
mateforrest mateforrest is offline
Mein Auto: BMW F16 3.0D & mini F54
Originally Posted by shawnsheridan View Post
So did you try actually running the kombi87 VIN write job?
yes, but no works, no valid unit message
Old 02-20-2013, 03:27 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
I figured that. Many of the .prg jobs simply do not work on Fxx chassis. I think the ECU addresses are different.
Old 02-21-2013, 04:47 AM
Please if someone has an idea or advice it will be welcome.
i don't know how to continue.
Regards
Old 02-22-2013, 08:00 AM
Regards
I am expecting some information regarding this early next week. Stay tuned...
Old 02-24-2013, 12:42 AM
sure !, thanks Shawn
Old 02-25-2013, 09:17 AM
djsaad1 djsaad1 is offline
Mein Auto: range rover
Have you tried contacting bimmertech? They might not charge much to do it.
Old 02-25-2013, 02:19 PM
Nison's Avatar
Nison Nison is offline
Mein Auto: 2011 535i xdrive
they charge $350 to change the vin on a 6WB Kombi, but you will need to ship the Kombi to poland.
not exactly cheap but for what it is i think it's worth the money.
Old 02-25-2013, 03:15 PM
No i think it should be very expensive
I have a programer for erase the vin
Old 02-25-2013, 04:52 PM
Since you already erased the vin, you shouldn't need to send it to poland they probably could do it over remote.
Old 02-27-2013, 02:01 PM
Any new ?
Regards
Old 02-27-2013, 02:27 PM
Any new ?
Regards
No not yet. As soon as I do though, I will let you know.
Old 02-27-2013, 05:09 PM
This is what I would try.
Under SVT Actual click save and save the svt.
Click edit
Expand the Standard SVT folder
Expand the Kombi folder
Expand the StandardSVK folder
Expand the CAFD folder
Edit ID to 00000069
Edit Mainversion to 009
Edit Subversion to 000
Edit patchversion to 050
Save and let esys reload it.
Download the attached file
rename it from pdf to ncd
Now right click on the CAFD_00000069_009_000_050 in the kombi folder, click new, click fdl. Find the downloaded ncd file and open it.
Now try to fdl code that cafd.
Old 03-05-2013, 06:41 PM
hamfei hamfei is offline
Mein Auto: 2012 E90 CLI
now, i'm working on the exactly same thing in China. Let me post back for any findings...
Old 03-06-2013, 02:51 AM
Thanks Hamfei, im sure you will do.
Old 03-06-2013, 02:52 AM
Thanks djsaad1, i will try.
Regards
Click edit
Edit ID to 00000069
Old 03-07-2013, 09:23 AM
Hello any information?
Shawn don't forgive me please..
Regards
Old 03-07-2013, 08:05 PM
Regards
No. I am hoping to get the right .PRG....but still waiting on a source at BMW to advise.
Old 03-16-2013, 09:34 AM
Hello hamfei, any new?
Old 03-17-2013, 03:54 AM
bmwoesi bmwoesi is offline
bmwoesi
Mein Auto: F10 520D
Hi Guys,
I'll explain my retrofit from a basic KOMBI to 6WA
The 6WA was a used or a new one I don't now however
I put the new one in and it as was no VIN inside only ******* and the CAFD was 00 00 00.
I connect with E-SYS and put in the FA 6WA and change to 0311
Detect CAF for SWE I didn't found CAFD for my I-Level F10-12-11-503
However I'll try to test with CAFD_00000069_008_001_020 for F10-12-03-510
I code the KOMBI with this CAFD and the KOMBI accepted
After reset KOMBI the VIN and the mileage +5km more is written!?
The Speedometer and all works fine, but I have a red point next to the mileage and no Service information in the KOMBI and CID!
I connect with E-SYS and I can coding the KOMBI
So the problems are the red point, no service information in KOMBI/ CID and when I start again the engine the mileage goes always up to 5KM
Thanks in advance to all for any help
Old 03-17-2013, 05:55 AM
Hello please help me with the next questions,
How do you do this?
Because when i have tried to detect CAF, esys always gave me an error.
How can you try the cafd? Where do you select it?
Please take a look to this post:
http://www.bimmerfest.com/forums/sho...7&postcount=94
P.D: As you know the red point is the tamper flag, maybe your KOMBI doesnt match correctly with the CAS.
Regards.
Originally Posted by bmwoesi View Post
Hi Guys,
I put the new one in and it as was no VIN inside only ******* and the CAFD was 00 00 00....
Old 03-17-2013, 08:06 AM
bmwoesi
Mein Auto: F10 520D
Hello mateforrest
I use 48.1 and work's fine.
Old 03-17-2013, 09:31 AM
Hello mateforrest
Hello bmwoesi,
I use 47.5 but , do you think that could it be the problem?
I retrofitted another modules without problem like trailer town hitch (AHM) and rear view camera with same esys.
Could it be corrupt?
Please could you translate for me the error in German I show you in the previous post?
When I try to detect the caf , I obtain this error?
The KOMBI comes from a F01 I'm not sure if it could help.
MFG
Old 03-17-2013, 10:40 AM
bmwoesi
Mein Auto: F10 520D
Did you read in the FA 6WA for KOMBI and Zeitkriterium0311 ? Maybe this is the fault.
Here is the text from the User Manuel
2.1.4 KIS
Target configurations for control units or control unit networks (vehicle) can be calculated on
the basis of the vehicle order (FA) and a target integration step or can be loaded from a file in
section KIS. The result is shown in the SVT tree in both cases (in font colour red unless an
SVTactual was already present). The edit button can be used to edit the SVTtarget with the
SVT Editor, and save can be used to save the SVTtarget to a file.
Alternatively, there is the option of determining the CAF for individual software units of a
basic variant without specifying an integration step directly using the detect CAF for SWE
function. This function can be applied to SWFL entries or basic variants in the SVT tree.
Old 03-25-2013, 11:55 AM
bmwoesi
Mein Auto: F10 520D
Hi mate,
any news from your side?
Old 03-25-2013, 04:53 PM
Hi mate,
Hello bmwoesi, sorry for the big delay.
no advances, i will try this weekend.
Tomorrow till friday i will be in the south germany, im not sure if take the kombi and go to seller and ask for a solution.
I going to answer your PM.
Shawn any new from your side?.
Regards
