X5 E53 (1999 - 2006)
The X5 SAV Forum |
Airbag light: code 8- firing circuit, side airbag, rear right side
After I changed the regulator on rear right window, the air bag light came on. This was the second regulator I changed. The code from B800 scanner was 8, table 10 which points to firing circuit of the rear right side. After I reset it, it came back the next time the key was turned on. I check the connector and one of the outside legs having locking hook was broken; however, the legs that push the shorting circuit were good. When I put the lock piece down, the resistor measure between 2 wires was 0. When I lifted the locking piece up, the resistance was 2.2 ohm. The connector seems to work fine and I think the outside locking leg did not cause the problem. I exchanged the airbag with a different one from other window (a 3rd regulator broken I changed after this one), it still showed the same code.
What else should I checked. I read forum mentioning about lock spring on other car but i cannot find one for this car even from part diagram. Last edited by samac0202; 02-24-2013 at 11:37 AM. |
Clockspring is for the steering wheel airbag. There are no clocksprings in the curtain airbag or passenger side air bag.
If clocksping is for only one airbag, then I am not sure what's problem is.
Problem is that you didn't disconnect the battery when you played around with the SRS system.
I understood that but I am looking for a way to fix it.
so how do you reset the SRS system if the battery was not disconnected initially ?
If you already reset the SRS but it keeps comping back, you need to find out the code that is triggering the SRS and repair the fault.
