Old 02-25-2013, 06:54 PM
dravenunix dravenunix is offline
Mein Auto: 1998 750il
98 750il Valve body NO GO
So after doing some reading i decided to go ahead and do a valve body swap on my bmw ( 98 750il 5hp30 transmission). Everything went well accept now the car has perfect reverse. little to now forward drive unless stuck in manual mode then it moves but not by much.
*HISTORY*
My car started having that stupid transmission failsafe error pop up everytime it would be put into gear and if you tried manual/sport mode it would kick into gear then lock you out of those modes. and if that be said everytime it did it would start off in 2nd/3rd gear. but once it got up to about 30 or so miles per-hour she was golden. So after doing a lot of reading came to the conclusion that the VB needed replaced. So order a valve body from REVMAX installed with new fluid and new filter. Got in the car started it put in reverse. Perfect. Put it in drive barely anything put in manual mode and it does twice as good as drive but still not good at all. HOWEVER with all of these i no longer have ANY CODES WHAT SO EVER even though there is something clearly wrong.... Any ideas? did i miss something?
Old 02-26-2013, 09:13 AM
No Ideas Eh?
