The X5 SAV Forum
Old 02-26-2013, 11:17 AM
Markjo92 Markjo92 is offline
Mein Auto: BMW x5
X5 shuddering when under power!!!!
Hi
I'm hoping somebody has the answer? I have an 2000 x5 4.4 which has started to shudder/wobble once warm from about 30/40 mph when under power, when you take foot off the accelerator it's smooth ride...... I have had new tyres, and balanced all round- still did not solved the problem. Have been to two independent mechanics, both have test drove it, had it on the ramps etc and cannot find why the car wobbles!
I would be grateful for any advise!
Thank you
Old 03-13-2013, 10:43 AM
trfraser trfraser is offline
Mein Auto: 2001 x5 4.4i
Something called the GUIBO . Mine was doing the same thing. I had it replaced now it is smooth.
Old 03-15-2013, 06:00 AM
Mein Auto: BMW x5
Thank you, I will look into that....was it expensive to fix!
Old 03-15-2013, 08:07 AM
No , seems like it was around 280.00 with labor with an indi mechanic .
Old 03-18-2013, 01:51 AM
flyace20 flyace20 is offline
Yippikayaaaay
Mein Auto: 2002 X5 4.4
Could you post your thoughts when you get it fixed?
I have exactly the same problem with mine as well. A couple of mechanics I've asked don't have a clue what it is and the parts guy at BMW service centre had no idea either.
Old 03-18-2013, 01:53 AM
Yippikayaaaay
What is this GUIBO thing. I have the X5 service manual and never came across this acronym...
Old 03-18-2013, 08:04 AM
Have you tryed to google it ? Its also called a flex disc.. Pull up google and type in guibo replacement e53.. or something like that...
Old 03-25-2013, 12:38 AM
Yippikayaaaay
cheers I found it. so you had the same problem and when you changed the guibo, it never happened again?
