Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 02-25-2013, 01:08 PM
HneDog HneDog is offline
Mein Auto: 1998 740il & 2010 750li
replace facotry amp or add another amp?
my 1998 bmw e38 rear sub deck is completely blown and i am removing them and replacing them with one 12 ich kicker that is rated at 150 watt rms. should i replace the oem amp with a new one or just add a second amp for just the subwoffer?
Old 02-25-2013, 03:00 PM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Factory amp is a must, if not your audio system will not work at all. This includes your radio unit. Speakers might work but depends on impedance of the speakers.
JOY = BMW
Old 02-25-2013, 06:49 PM
speedkingrc speedkingrc is offline
Mein Auto: 88 BMW 735i
no you can change you factory amp out.. just look up wiring codes on e38.org they will show and tell you how to change it out... im doing it to mine soon... im changing the head unit to a pioneer appradio.. and either keepin factory amp or ungrading that.. hit me up if u need some help
Old 02-25-2013, 08:50 PM
Espresso Espresso is offline
Coffee Extraordinaire
Mein Auto: 2001 740i Sport
use an OEM integrator like the PPI ENT-5B it has high level inputs for speakers & 3 RCA outs for front, mid & SUB. No need to mess with anything. Hook that up, run RCA's to amp hook up amp as normal.
DONE.
google "OEM integrator" & you will see what I mean. Installed many & have one in my Suburban,
-Tom
Old 02-26-2013, 11:33 AM
DONE.
you can do it that way too.. Its really up to what way you wanna go with it.. stock or aftermaket. most ppl say aftermarket cause more power and you can get newer nav system and better speakers
Old 02-27-2013, 10:27 AM
DONE.
So what ur saying is keep everything the same but just wire the new sub ( 12" 150wattrms) to the oem amplifier? Im completely reomving the OEM sub deck so they wont be in use anymore but i dont kno if the stock amp is strong enough to power my sub.
and i might eventually use the stock enclosure in the rear window for the sub but for now its in a separate box in the back of the trunk. ill post a pic prob this weekend when its all in.
Old 02-28-2013, 08:07 PM
Depends on wht u are going for
HTML code is Off
