1998 Z3 suspension recommendations please
Hey folks, I've been trying to solve a problem with the ride of my 1998 2.8 roadster. Initially it seemed to be getting kid of sloppy and the steering wheel was vibrating at 58 mph, so based on recommendation of a mechanic I replaced the lower control arms and bushings. This made some improvement but still not what it should be. Steering wheel still vibrated. Next I replaced my tires, nothing great but very affordable. They balanced everything but I still have pretty much the same issue, shaking steering wheel and just an uncomfortable ride over all. Had a local mechanic who has had some experience with the same car as mine, take it for a drive. His recommendation now is struts and shocks based on handling and roll of the car in turns.
First off does this sound like it could solve the problems I'm having? If so, with out breaking my bank, can someone recommend an affordable strut and shock? And with the struts i see on the web, is that all I need to replace or are there other associated components required? Sorry for the long post but this is my situation. My budget is very tight and I'll have a friend help me in replacement. Thanks in advance, MCDz3 |
my 97 2.8 has bitstein shocks/struts & b/G lowering springs and handles like its on rails
if you look around online you cant get the parts for 800-1000$ easy! def not bad for a sick suspension that will last 100k
Like Justin mentioned, surf around, there are many options to do. When i got my 99, it was still on original struts/shocks at almost 100K miles. Changed front struts for little over mid 200s with Bilstein touring and changed the rears for under 200 with Bilstein touring and Ireland mounts. put a couple rubber spring spacers in the rear and it drives really nice as a daily driver. If I need a little more in the front, i'll add the blocks there. Just a cheap way of getting more out of the stock springs vs. new. Good luck on quest.
S. Maykowski, Columbus MS. ![]() My '99 Z3 Alpine White 2.8L Speed Buggy |
It all depends on your budget and needs.
Many people on this forum like the TC Kline SA and DA coilovers. For larger budgets, ASTs can be a good choice (especially if you track your car). For smaller budgets, Konis, Bilsteins, and KYB replacement shocks (and, IMHO, basically in that order) are good. See http://www.tcklineracing.com/index.c...y&Category=285 and http://www.tirerack.com for prices and options. |
First thing I would check is if you have a bent wheel.
For high end, TC Kline makes VERY nice suspensions. For more stock like and less expensive, Bilstein HD or Koni single adjustables will do the job. Always replace the rear upper shock mounts with better ones. Rogue Engineering are one of the best these day.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
I had a steering wheel shake/vibration in my e36 cabrio, it was solved with new struts/mounts.
You might take a look at the prices on the bilsteins that we have at eaceuroparts.
So I want to thank every one for their suggestions, but before I invest in struts and shocks, is it really feasible bad struts and shocks can be causing the shakiness and vibration i feel at 58 mph and higher? Are there other things that can cause this problem? t's really taking a lot of the fun out of driving this car... Oh and one more question are their struts only on the from or on the back too, or shocks on the back? I seem to hear conflicting descriptions..
Last edited by dmytroa@telus.n; 09-11-2012 at 10:40 PM. Reason: didn't read post carefully |
Also, the suspension is a system. When one part has a problem, the other parts are worked harder and can prematurely fail - bad shocks cause the bushing to wear more quickly or an out of balance tire causes more work for the shocks. I.E., delaying on replacing the shocks will cost you more money. Technically, struts are on the front, shocks are on the back. But as you have noticed, these terms are used rather loosely. If you check the links I previously posted, the fronts are MOSTLY described as struts, and the rears MOSTLY described as shocks. Last edited by dougmcintyre; 09-12-2012 at 06:43 AM. |
Struts front, shocks rear.
Thanks those who have responder so quickly. I am going to have the place that installed the new ires check the balancing again. And go from there to struts and shocks. Someone asked If I had changed the lower control arm bushings when I changed the control arms, the answer is yes.
Thanks! |
OK, I can't remember the tire sizes on all the different models. But, assuming the same size is used front and rear, have the tire place exchange the front and rear wheel/tires. If the problem is a single bad tire or single bent wheel, the problem should move to the rear.
Does anyone else hate the phrase "it handles like it is on rails?". To answer your question, your problem could be bad dampers, a wheel with tire weights that have come off, bad LCAB's, but if your car has more than 50,000 miles, it can't hurt to upgrade your suspension. If you were nearby, I'd be more than willing to diagnose by elimination.
SS braces, AST 4200's coilovers, Vorshlag camber plates, GC RSM, H&R Front sway, Conforti CAI, Magnaflow exhaust, Recaro seats, and Apex ARC-8 with RS3's and Style 32's with Pilot SS for autocross |
Ok folks thanks again for the input. I finally have the struts in hand! Are there any other part required in order to change the struts out?
Mcdz3 |
Not required, but do this:
Thanks, got it. Rears will come shortly. More specifically nothing required on the front struts, just the struts right?
You should probably replace the strut mounts as well. I'm going to be doing this job late next month. Already have the parts in the garage.
To help prevent shock tower cracking, I would add strut tower reinforcement plates - http://www.turnermotorsport.com/p-19...ates-pair.aspx
http://i49.photobucket.com/albums/f2...umpercover.jpg |
All Bisteins EXCEPT Touring. They are similar to OEM.
Replaced my OEM shocks with Bilstein Sport. VERY hard riding; so for street use, I would consider Touring.
Might be too late for the OP since he has already bought his, but for a daily driver on a budget, I put Monroe shocks and struts on the 2.5 convertable. It was about $350 for all 4 corners and has a great ride. The M Coupe has the H&R/Bilstein combo and definitely rides FIRM.
1999 Boston Green M Coupe 2002 Z3 2.5 Automatic Roadster 2006 Inferno Red Ram 3500 MegaCab 3500 2010 Rescue Green 2 door Wrangler Mountain Edition |
#25
Find someone that has a road force wheel balancer and that would defiantly point to or away from wheels or shocks
