Old 02-21-2013, 11:11 AM
Euro_Hobbs's Avatar
Euro_Hobbs Euro_Hobbs is offline
Euro Convert
Mein Auto: '02 525iT, '93 325is
Temp gauge - 525iT
Hey guys, I just picked up a new (to me) '02 525iT. Have one big question about it, everywhere I have read it says that the temp gauge should be directly at 12 o'clock but mine isn't. It is a smidge to the right of 12, now a buddy of mine has a 540 and it sits right at 12 and never moves. Should I be worried I am running too hot? Most of the cooling system was just replaced and it never moves any further to the right.
Here's a pic for reference. I tried to be as dead on as possible.
Old 02-21-2013, 11:52 AM
esilvas esilvas is offline
Mein Auto: 2001 540i
That looks exactly like my 540. I have not had problems. If there is a problem, I hope someone else chimes in.
Just looking to have some fun while enjoying the ride.
'01 540i 6-Speed
Old 02-21-2013, 12:12 PM
jygesq jygesq is offline
Mein Auto: 2000 528 MT
needle is buffered to be straight up . Anything else is not normal. Just watch it carefully to make sure it never goes any higher.
Old 02-21-2013, 12:26 PM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
That's about were my 540 sits. If your concerned unlock the cluster and get it to display the actual engine temp in degrees (test 7 I believe)
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 02-21-2013, 12:29 PM
mbell, thanks for the info. I have not unlocked the cluster yet. I have only had the car a few months and am learning every day about it. The last thing I want is get stranded.
Looks like I will be busy this weekend unlocking my cluster.
'01 540i 6-Speed
Old 02-25-2013, 03:18 PM
Euro_Hobbs's Avatar
Euro Convert
Do you have a link to unlock the cluster? I have found a few threads but they all seem to be for the low cluster. I have the high.
Isaiah 4:12-13
Old 02-25-2013, 03:32 PM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
Here you go:
http://forums.bimmerforums.com/forum....php?t=1138110
Old 02-25-2013, 05:13 PM
mcsimon mcsimon is offline
Mein Auto: 528i e39
Could b tstat as well, cheap aftermarket, or just not the correct one. Opening at lets say 104c instead of 94c
Old 02-27-2013, 12:50 AM
After unlocking my cluster, the temp is 106-108F. That was fun to read through my dead pixels.
'01 540i 6-Speed
Old 02-27-2013, 07:21 AM
How the temperature gauge works, in detail, is listed in this thread (found by typing /temperature F3 in the best links):
- What is the temperature of the coolant & when the thermostat opens under normal conditions (1)
Also, how the temperature gauge gets it's readings is found by typing /dts F3 in the bestlinks:
- How to replace the dual temperature sensor DTS, aka double temperature switch (1) (2) (3) (4) & how to make your own short DTS removal tool out of a 22mm or 7/8" box wrench (1)
Old 02-27-2013, 09:04 AM
dtadrian dtadrian is offline
Mein Auto: 1999 BMW 528i T Wagon
On my 528iT I have never been over 98C. Usually hangs out at 96 in city and 94 hwy. but then again you have a 525 which might have a different operating temp. Driving it in city and hwy try to see the fluctuations in temp and report back to us. You may have a small issue
Old 02-27-2013, 01:56 PM
Euro_Hobbs's Avatar
Euro Convert
Finally unlocked my cluster and I was reading 90C - 93C (with LOTS of dead pixels)
Isaiah 4:12-13
Old 02-27-2013, 03:57 PM
HTK12 HTK12 is offline
Mein Auto: E39 540i
That is correct running temperature for 525. Since the needle isn't at 12 o'clock there is an issue with the cluster. Maybe someone has opened the cluster and twisted bumped that needle. There are quite many reasons to open the cluster like fixing dead pixels, blocking warning lights due to some fault in the car etc. Simplest way to fix that would be send the cluster to get those pixels repaired, or repair those pixels yourself. While fixing those pixels it is easy to fix that needle. I fixed the pixels on my e39 and it wasn't as bad as some let you believe, but it's not easy either.
