Old 02-27-2013, 09:34 AM
FLE39 FLE39 is online now
Mein Auto: 2003 530i 5spd Manual
Lost my Speedo during a rain storm
Yesterday I was driving through a hell-ish rain storm on the highway in FL. Rain was so bad that my speedo died and I got the ABS trifecta. I pulled over at the nearest rest stop shut the car down for a few minutes. It was cleared then by the time I hit 2nd gear everything lit back up. I drove about 1hr like this out of the rain and then pulled over when the weather was clear. Re-started and back to normal. Speedo worked, no lights.... back in business. But I basically drove for bout 1hr in no rain then restarted. It was raining so bad that even my co-worker behind me in a 2010 GMC 1500 Pickup lost all of his gauges. Including gas and tach. his reset with just a quick restart. didn't take 1hr like mine. What the heck causes this? This is a problem for me.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 02-27-2013, 09:36 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Wheel sensor (rear wheel).
Old 02-27-2013, 09:44 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Ditto cn90...the IKE (instrument cluster electronics) receives a distance signal from the rear wheel sensor):
Q {BMW CCA Member #191509}
(SOLD)
Old 02-27-2013, 10:42 AM
jygesq jygesq is online now
Mein Auto: 2000 528 MT
if it is clear no do not worry
sensor got shorted out by water. If problem persists try a cold reboot. Open trunk, with key not in ignition . wait for trunk light to go out. Disconnect brown ground battery cable, then disconnect red battery cable.
leave disconnected for a few minutes, SHORT the battery cables together. Reattach
red cable , then brown ground cable to battery,
Old 02-27-2013, 11:50 AM
Damn. So I'm assuming the LR wheel sensor needs replaced b/c the water was able to short it out rigth? Maybe the boot is going bad?
Old 02-27-2013, 04:23 PM
mcsimon mcsimon is offline
Mein Auto: 528i e39
Wheel speed sensors especially the cables get brittle and crack overtime start by replacing them if problem persist next guess would b ABS control mod. There is an aluminum wire connection that gets to hot due to poor placement of the mod. To close to the engine and heating up. Try to have it rebuilt if u can't u will need to replace and have recoding. Done by a dealership
Old 02-27-2013, 05:00 PM
I had BBA or whatever rebuild it a few months ago. It's been flawless. I think it's a wheel sensor issue.
Old 02-28-2013, 09:41 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
It could just be water in the sensor ring, so the sensor couldn't correctly detect the teeth correctly. Therefore couldn't generate a good signal. I'd only worry if it happens again.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 02-28-2013, 04:30 PM
if it happened once, it will happen again. I'm going to inspect the wheel sensor and see if it's got any boot or insulation problems. go from there.
Old 02-28-2013, 05:34 PM
L0F L0F is offline
Mein Auto: 3/98 528i
I lost abs and traction control in a rainstorm a year ago due to a wheel speed sensor. Replace it with a real oe sensor, eBay and Chinese sensors are made with poor tolerances and a crap shoot if they will even work or not.
Old 03-01-2013, 06:09 AM
^ Good to know. Yeah... probably going to replace the LR sensor to be on the safe side. I don't need that sheit storm again.
