Old 02-25-2013, 09:45 AM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
OFH Leak Repair Cost
Ok, I need the OFH gasket done. I do all my own work but having to tear back into the front of the engine doesn't look appealing.
Dealer # 1 $435 OTD
Dealer # 2 $600+++
Euro Indy ?? Waiting to hear back.
I know I can do the job, CCV was cake walk. done the entire cooling system, belts etc. That was the time to do the OFH gasket!!!! What is a fair price to have the OFH Leak done? If I do it myself looks like I need to take the belt off, remove the alternator and bunch of other crap right. Hate to part with $435 over a $20 gasket. If I decide to do it myself, it will be done the same day I do the P/S hoses.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 02-25-2013, 09:54 AM
cn90 cn90 is offline
You are a DIYer, so what is the purpose of this thread?
The OFH Gasket is $6. Info in forum.
Just be careful with M54 to avoid stripping the block hole, even with the correct torque on the 6 bolts.
Old 02-25-2013, 10:06 AM
Purpose? Uh, I've got a lazy bone thinking about this damn problem. I don't know.... Just figured I could at least pay to have one task done and save me a saturday. Probably going to do it myself... See what the indy comes back with.
Old 02-25-2013, 10:08 AM
Anyway, info on M52 engine is below. About 2-3h job:
http://www.bimmerfest.com/forums/sho...d.php?t=414315
Old 02-25-2013, 10:29 AM
vatoman vatoman is offline
Mein Auto: E39 I6
If you were able to handle the ccv you will have no problem with this job. Its simple I did it while I did ccv and vanos. The money spent on labor for a six dollar part makes no sense to me. take the money you save and blow it on the next Saturday. You don't have to remove alternator, just swing it back.
Sent from my EVO using Bimmer App
Old 02-25-2013, 10:36 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Your not going to leak a lot of oil out of this anyway--why don't you just wait until the weather changes and you can do it on a calm Saturday and just call it a chore
Old 02-25-2013, 10:37 AM
tmvE39/E53/Z32's Avatar
I have some oil dripping on the driveway. It's either the OFH gasket or the oil pan gasket. As noted by cn90, most of the leak is from the OFH. So I decide to do that first and see what happens.
I had it done the past Sat, in less than 4 hrs. I managed without removing the fan. The old hasket feels like plastic, not rubber gasket. There's evident of oil leak from it for sure, on the engine block.
The feeling of saving over $400 is great. I followed cn90's write-up.
FS E39 Hella Celis Euro taillights WITH ballasts, for pre-facelift update.
FS OEM E53 X5 Tow Hitch http://www.bimmerfest.com/forums/sho...49#post9981849
Old 02-25-2013, 11:04 AM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
Mine is leaking as well, will tackle it when spring arrives. If you have done the other DIY projects mentioned this should be a breeze. I see no point in paying someone to do this job, because they will leak again anyways.
"And if you no longer go for a gap that exists, you are no longer a racing driver because we are competing, we are competing to win."-Senna
Old 02-25-2013, 11:22 AM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
I'll do it for $100 worth of London Broil.
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 02-25-2013, 01:09 PM
damn it... ok, i'm gonna do it. Now the shifter bushings is another issue. Every DIY says it's a PITA.
Old 02-25-2013, 02:58 PM
daytradeoil daytradeoil is offline
Mein Auto: 2001 bmw 525i
Just tackled mine this weekend. It was pretty easy just time consuming.
My started as a drip but got worse and rained oil all over. My advice is tackle it asap rather then wait. Avoid oil getting all over. I wish i did it sooner. Theres tiny amounts leaking today but i think its residual. Purple powering all the oil off today.
Only pita part for me was i bolted my ofh back on first and couldnt get the banjo bolt back on for like 20 mins. Not sure if the diy said to bolt that up first or not. But if i was to do it again id probably loosely bolt that back on first then do the ofh.
Old 02-25-2013, 05:10 PM
^ 10-4 fellers. yeah I know when I'm done I'll feel good about it. Gasket should be coming with this weeks's online order. From what I searched around there are two camps when it comes to the RTV Sealant. The BMW doesn't call for it crowd and the it's extra insurance crowd. IMO, it's obvoius BMW's design sucks. Leaks at 50K? I'm using a BMW gasket/O-ring and what I'll do is swing by the Toyota dealer and get a tube of blk RTV. That stuff is phenominal. I'll put a thin thin coat on each mating surface and then coat the gasket with a thin coat of it. Basically put on my gloves and smear a thin coat all over the gasket. I'm betting that will fix that sucker up for life. Toyota knew how to make some HD stuff back in it's day. And no the permatex blk is not the same. I've used both extensively. the toyota blk will eat permatex' lunch.
Edit: Toyota 103 FIPG is what I am going to use. $9/tube on Ebay. I'll see what the local toyoter stealer wants. Might just pick it up on the way home tomorrow.
Old 02-25-2013, 06:29 PM
SmartSolution's Avatar
SmartSolution SmartSolution is offline
Mein Auto: BMW E39
Cost me $3.74 for the gasket from autohausaz with free shipping since I bought other parts too. I did it in 4hrs(1st time taking my time) with replacement of belts and tensioners along the way. Just do it!
Sent from my PC36100 using Bimmer App
Old 02-25-2013, 06:52 PM
Originally Posted by daytradeoil View Post
...Not sure if the diy said to bolt that up first or not. But if i was to do it again id probably loosely bolt that back on first then do the ofh.
I was lucky, when I did the OFH gasket, just prior to install, I paused for a minute and look at the whole OFH assembly and said to myself: "how the heck can I tighten the banjo bolt in the back of the OFH once it is in the car". Only then I realized that I needed to tighten banjo bolt before re-installing the OFH back in the car. Just make sure the orientation of the oil line is correct when you tighten the banjo bolt.
Old 02-25-2013, 07:02 PM
^or disconnect the banjo bolt on the front of the engine so you don't mess with the one on the OFH. What is the torque values for the oil line banjo bolts?
Old 02-26-2013, 10:51 AM
^ From Beisan Procedure to replace Vanos seals.
"32 Nm (24 ft-lb) (19mm combo wrench / by feel)"
Old 02-26-2013, 02:13 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
WOW! a Saturday worth $600! Hope you're getting laid several times!
Time = money.
Old 02-27-2013, 10:42 AM
^exactly. Hence why I bought the $6 BMW seal.
Old 02-27-2013, 04:36 PM
Damn bay area prices!! I paid 13 for the ofh gasket which was the same price they sell the gasket for my power steering cap. Fml
Old 02-27-2013, 08:15 PM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
Do this job on your next oil change. The filter housing has to be drained otherwise oil will leak everywhere(ask how I know) there's enough room to not remove the fan and the job is very straight forward. If you can do the CCV then this job by comparison is a cake walk
Old 02-27-2013, 08:35 PM
^ good point.
