Making sense of INPA, EDIABAS, NCSExpert, NCS Dummies, DIS/GT1, EasyDIS, & Progman - Page 10 - Bimmerfest - BMW Forums
Old 02-14-2013, 07:25 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
bluebee That DIY you cross referenced isn't too great... EDIBAS, DIS etc work just fine with windows 7 so no need to start messing up your computer. Why on earth would you want to install xp to a win7 computer? If one insists on XP one can simply virtualize it. On windows 7 professional you got XP mode, if you don't have win7 pro/ultimate you can always use vmware. A good DIY on EDIBAS, DIS etc. is BMW DIS V57, SSS V32 & TIS V8 Installation Procedure. That cover pretty much everything. Even how to virtualize operating systems with vmware.
Old 02-14-2013, 07:27 AM
Mein Auto: E39 540i
Originally Posted by morganbmw View Post
Thank you so much ...
but I c these programs are for Models until 2003 or its until present models ?
To diagnose E60 you need to have DCAN cable. These programs work just fine with E60.
Old 02-14-2013, 07:33 AM
morganbmw morganbmw is offline
Mein Auto: E60
Thanks HTK12
Old 02-14-2013, 07:55 AM
Mein Auto: E60
Guyz another question please... So with these programs do I still need to own ISTA/P and ISTA/D and the ISSS or these programs do the job for coding and programming all BMW Models ???
Also does the ICOM replace all other cables or still i need to get them ??
Old 02-14-2013, 01:59 PM
Mein Auto: E39 540i
Are we still talking about the E60 in your sig? If we are you only need the DCAN cable and EDIBAS package. In that package there is a program NCS Expert than can do all the coding/programming.
Old 02-14-2013, 02:07 PM
Mein Auto: E60
Thanks alot ...
Old 02-14-2013, 11:23 PM
I just ran into this document - and wonder WHERE I should archive it?
Does it belong here? Or elsewhere?
Old 02-27-2013, 08:26 PM
Based on this note today from another thread, and, noting that the cable recommendations in the first post of this thread are about 18 months old, I wonder if anyone has an update on the cable situation lately for USB cables on modern PCs?
Originally Posted by GabesJH82 View Post
There are so many inpa edibas USB cable and softwares out there but I'm still unsure witch one would be the best one to buy as I'm looking into coding modules, read and clear codes basically a full functional tool with most features that dealer may have.
Old 02-27-2013, 08:54 PM
BraveHelios BraveHelios is offline
Mein Auto: 545i
OT... but not really. I installed INPA as per your instructions (and the instructional PDF). Thank you. I am using a new USB/OBD II connector.
Opps... almost forgot; I have a 2004 545; 6 sp MT... all stock.
I have seen pictures of the INPA interface with the battery and ignition round indicators either "lit" in black or in clear. How can you tell if you are connected and communicating?
Are there instructions on how and when to connect, when to start the engine, etc...
Also, the instructional PDF on page one of this thread says to start INPA (_.IPO). What about INPA (_.IPS)? What's the difference?
BTW, awesome job here!
Old 03-19-2013, 09:02 PM
e39_525i e39_525i is offline
Mein Auto: 02 525i
looking to run INPA on a e39 and based on the reading available throughout the interwebs and forums it appears I need a K + CAN interface to access it.
question though - will this cable work?
http://www.ebay.com/itm/170798753567
Old 03-19-2013, 10:43 PM
jas1 jas1 is offline
Really Witty Name
Mein Auto: E60-525d-08-Manual
E39 K+DCAN Cable...
Hi, I dont think that will work with Beemers. You need this one. (Decent Quality for price too):
http://www.ecutool.com/BMW-INPA-KCAN_1939.html
Or search Fleabay for: BMW K + DCAN CABLE..
Good luck
Old 03-20-2013, 09:39 PM
IndiansFan's Avatar
IndiansFan IndiansFan is offline
Mein Auto: '99 528iA
Good luck
Is this a similar product?
http://www.ebay.com/itm/330606867879...84.m1438.l2649
I'm still doing my homework and research. I have the Bavarian autosport code reader, but am now looking for a more advanced diagonistic tool. I'm somewhat concerned about buying products from eastern europe or the pacific rim.
Either write something worth reading or do something worth writing.
Benjamin Franklin
2004 X3 2.5 TITANIUM SILVER/Grey - Sport/Premium Package
2001 530iA STEEL BLUE/Sand - Sport/Premium/Cold Package
1999 528iA JET BLACK/Black - Sport/Premium/Heated Seats
1982 Fiat 2000 Spider - BLUE METALLIC/Blue
1999 528iT CASHMERE BEIGE/Sand - Sport/Premium Package - 5 speed SOLD
1989 535i SALMON SILVER/Black SOLD
Old 03-21-2013, 08:56 AM
Really Witty Name
Hi,
Yes thats a similar cable.
Are you hoping to use it on your 1999 car? If so check if it has the round 20 pin connector under the hood.
If yes, then im afraid this cable is not the right one for your car. If you havent got the round connector under the hood, then it'll be ok.
Good luck..
Old 03-21-2013, 09:53 AM
IndiansFan's Avatar
Thanks. I was not thinking about the '99's, rather the '01 530. I probably should find something that will also work on the '99's.
Benjamin Franklin
Old 03-21-2013, 09:57 AM
Mein Auto: E39 540i
'99 model will have the round 20 pin connector. This will work just fine with '99 model, if you just buy the 20 pin to obd2 adapter. That adapter is really cheap ~$5
Old 03-21-2013, 10:14 AM
IndiansFan's Avatar
Thanks. Finding quite a few on fleabay.
Benjamin Franklin
Old 05-06-2013, 07:06 AM
Quick99Si Quick99Si is offline
Mein Auto: 2004 M3 6MT
Couple of updates since I was last around here:
1. INPA 5.02: it works on E39/E46 just fine, but the package replaced the language in INPA from English to German for me. It isn't difficult to use or navigate, but there are no features worth updating for if you're only using it on an E39. INPA 5.02 was beneficial for messing around with Mini Coopers (R50 and on) and some of the later models like R56 aren't supported by the daten files in INPA 3.x. Again, I do not recommend updating for dedicated E39 use.
2. DIS/GT1: it is possible to have both v44 and v57 running as separate installations on one machine. To accomplish this, simply install v44 as noted in the top post, clone that VM (FULL clone, roughly 20GB), run cloned VM, and install v57 as per the guide. It will require DaemonTools and the DIS v57 image file. If my memory serves me right, v57 lost the ability to code new modules, but gained the ability to support newer cars. Like with the point above, for dedicated E39 use, you will be perfectly fine with DIS v44.
3. NCS Dummy continues to be updated, and you're probably better served to check the developer's website and download from him directly rather than using the copy that I'm hosting. Latest update seems to be from just over a month ago: http://forums.bimmerforums.com/forum...-of-NCS-Expert
4. Speaking of hosting, the files my not be on my server for much longer. I've slowly been uploading them to this location: http://www.4shared.com/dir/YzvDi-2F/BMW_Software.html. This will have every single thing you will need for an E39, down to instructions. I will create another mirror on Box.net in the coming days, while handing over the 4shared account to BlueBee.
5. Has anyone tried meddling with the new BMW ISTA software? My buddy and I were looking into it last night and it seems to be the same feature set as DIS/INPA/Progman, but included in one suite and geared toward newer BMW's. Apparently the Chinese hardware connectors alone cost upwards of $1k and the software runs in their cloud? Would love some input on this.
540i - Stock/Sport / 6MT / 13.9@100mph
WS6 - 231/234 / 6MT / 4.10 / 410rwhp
ITR - 262/262 / 5MT / 12.2:1 / 9600rpm
540i/6 Sport, Jet Black, Style 65, LED tail, DICE+GROM USB, !CDV, Redline MT-90, M1 0-40w
Old 05-06-2013, 07:12 AM
As a sidenote, I will probably be selling my complete setup soon with the hopes of recouping some my expenses. It's a turn-key diagnostics + coding/programming solution proven to work reliably on E34, E39, E46, E60, and R50 with all modules on all cars:
a. Dell Latitude laptop: dual-core 1.83GHz, 2GB RAM, 120GB HDD, fresh extended battery
b. $80 cable with the standard K-Line/D-CAN (as well as L-Line that worked with an early E34)
c. 10-ft extension cable
d. INPA 3.01, INPA 5.00, EasyDIS, NCS Expert+Dummy, WinKFP, updated E39/E46/R50 daten files, etc. preloaded
e. Microsoft Office 2010 (Word, Excel), FileZilla FTP, Foxit PDF, etc..
I made the mistake of giving the little 20-pin adapter a while back, but I ordered a new one last night as a replacement. Probably selling for $300/all.
Old 05-08-2013, 09:07 AM
gmprof gmprof is offline
Mein Auto: 750LI,750xi,X5
I am using ICOM Chinese clone about four month and have no problem.
It was purchased for $650 but it came with malfunction hard drive for IBM T61
And I bought VM version software ISID and ISSS on EBAY.
For programming procedure it require 50 amp power supply and can take on some cars up to 4 hours for complete programming, and it not allows you program modules separate.
Old 05-08-2013, 09:28 AM
This is operating manual for Snap-on diagnostic tester.
Old 05-09-2013, 03:56 AM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
Do we have a consensus on which cable is the best for the cabin obdii port and usb?
Old 05-09-2013, 06:21 AM
Mein Auto: E39 540i
This depends on what cars your going to use the cable with, how fast you want it and how much you want to pay for it.
Old 05-09-2013, 11:29 AM
One of my old friends recently got his station set up with Windows 8 64-bit + USB + unknown cable on a Lenovo Thinkpad. He says that everything works fine aside from NCS, and I'll be meeting him this weekend to program his car and so how well his setup runs. It seems that we're no longer bound by XP or 32-bit operating systems in general.
I have a spare Lenovo T420 that I would love to put to use in case I'm ever in a BMW again.
Old 05-14-2013, 10:42 AM
Manny G. Manny G. is offline
Mein Auto: 2003 540i/6 M-sport
I'm planning to only use it on my E39...but also considering flashing the DME with data from an E53 4.6
I tried accessing that link you posted but it requires a password.
Old 05-14-2013, 11:18 AM
Try password: bimmer
acronyms, carsoft, diagnostic tools, glossary, inpa, ncs
