Old 02-06-2013, 09:05 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
NNR I'm interested :-)
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs.
carlova78 carlova78 is online now
Mein Auto: e39 530i 5SP/e60 530i
I should be doing the same. My cars also going through major maintenance/mods but to make it last another 100-150k
Old 02-08-2013, 03:19 PM
Albo's Avatar
Albo Albo is online now
Der ursprünglich....Albo
Mein Auto: OO=[][]=OO
Just picked up on Ebay.... from Circuit Motor Sports, in fact.. BC Racing BR Series Coilovers w/ Free Shipping and Free Rear Extenders for $995.00 :-)
Want to learn about your E39 5 Series?
Click Me
2003 530iA - Mumbo Jumbo *E39 in Sig is Not My Car
Originally Posted by edjack View Post
If you don't want to do nothing, you must want to do something.
Old 02-08-2013, 04:55 PM
Way to go sir. Ordered mine last week but it's going to take a while bc I opted for the swift upgrade.
Pretty exciting
Old 02-08-2013, 05:11 PM
Albo's Avatar
Cool... now I can "Dump" my ride, yo!
Click Me
Old 02-08-2013, 05:17 PM
Functionality for me
Old 02-08-2013, 06:36 PM
Albo's Avatar
Not me yo....I only cizare bout da stance!
Click Me
Old 02-08-2013, 07:47 PM
you need wider rims. I'm thinking 18x10 square
Old 02-08-2013, 08:55 PM
Albo's Avatar
On the way...
Click Me
Old 02-08-2013, 10:52 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A--165K
Originally Posted by Albo View Post
On the way...
Lotta mods. Where are the upgrades?
Old 02-08-2013, 11:02 PM
Albo's Avatar
Your question is a little vague. What would you consider an "upgrade"?
How about the shocks.. The springs... The sway bars... The control arm bushings... The wheels.. ? Please enlighten me on what your comment intends?
Click Me
Old 02-11-2013, 10:40 PM
Albo's Avatar
Got a UPS shipment today:
Click Me
Old 02-11-2013, 11:22 PM
NoWayJose's Avatar
BC coilovers and now this?
I'M DONE!!
00 BMW 528ia Sport
Old 02-11-2013, 11:26 PM
Albo's Avatar
Crime of passion.... much more to come. ;-)
Click Me
Old 02-25-2013, 10:54 AM
Albo's Avatar
Ok. Came down with a bug late last week that precluded me from spending any time in the garage. I plan to finish rearranging the garage during the week and then begining tear down of the Storm Trooper on Saturday morning.
Here's the plan for Day 1:
Drain Oil & Coolant
Remove:
Radiator
Expansion Tank
Hoses
Thermostat
Waterpump
Pullies/Tensioner
Belts
Remove Valve Cover
Remove Spark Plugs
Remove CCV
Remove Oil Filter Housing
Remove Vanos Unit
Day 2:
Rebuild Vanos Unit w/ Beisan System's Vanos Seals
Reinstall Vanos Unit with new oil supply line, O-Rings and gasket
Install new CCV w/ new lines
Reinstall Oil Filter Housing w/ new gasket
Install new Spark Plugs
Reinstall Valve Cover with new gakset
Install EMP Stewart Waterpump
Install new Thermostat Housing
Install Rogue Engineering Underdrive Pullies
Install new Tensioner, Idle Pullies and Belts
Install new Coolant Hoses
Install Zionsville Super Cooling Kit (figure out how to wire this sucker up).
Fill with oil and coolant and look for leaks!
Click Me
Old 02-25-2013, 11:24 AM
Albo's Avatar
Assuming first round of work is gold...
Day 3 (Front)
Disconnect Swarbar Endlinks
Remove Bilstein Sport Shocks and Eibach Springs.
Remove Calipers and Caliper Brackets
Remove Rotors
Remove Front Wheel Bearings
Install new Front Wheel Bearings
Install new Front Rotors
Install new UUC Stainless/Siicone Brake Lines
Reinstall Calipers
Install BC Racing Coilovers
Day 3 (Rear):
Remove Rear Calipers and Brackets
Remove Rear Rotors
Remove Rear Bilsteins and Eibachs
Install new Rear Rotors
Install UUC Stainless/Silicone Brake Lines
Reinstall Calipers
Bleed and Bed Brakes
Switch CK's to RK's & Alignment to M5 specs!!
Click Me
Old 02-27-2013, 11:07 PM
NoWayJose's Avatar
wow good luck with everything, its going to feel like a new car after!
00 BMW 528ia Sport
Old 02-28-2013, 05:25 PM
s2kpunisher s2kpunisher is offline
Send a message via AIM to s2kpunisher
Mein Auto: 540i
Hey Albo, hope you are feeling better. We're having another meet & drive on 03/30/13, hope you can make it:
http://www.bimmerfest.com/forums/sho...d.php?t=664056
Old 02-28-2013, 06:07 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Drain Oil & Coolant
Remove:
Radiator
Expansion Tank
Hoses
Thermostat
Waterpump
Pullies/Tensioner
Belts
Remove Valve Cover
Remove Spark Plugs
Remove CCV
Remove Vanos Unit
Day 2:
Hope you post some pics along the way.
Either you are part of the solution, or you are part of the problem.
Old 02-28-2013, 07:14 PM
Albo's Avatar
That's what I'm aiming for! Maybe I'll start with the suspension so we can do that thing we talked about.
Click Me
Old 02-28-2013, 07:16 PM
Albo's Avatar
I should have the car back together by then!
Click Me
Old 02-28-2013, 07:20 PM
Albo's Avatar
That is absolutely the plan. I may not do a full blown DIY about any of this, but I will document all of it!
Click Me
Old 02-28-2013, 10:52 PM
NoWayJose's Avatar
works for me I'm ready
00 BMW 528ia Sport
Old 03-08-2013, 12:00 AM
Albo's Avatar
Progress!! I opened the box!
Click Me
Old 03-08-2013, 05:41 AM
put them in alreadyyy
