Old 02-17-2013, 06:46 PM
aiwapro aiwapro is offline
Mein Auto: 2013 X5 35d
Originally Posted by toviasart View Post
Took mine to dealership drove around with technician but does not know what is the cause? Been having the issue for the last 3 years! Disappointed with BMW service care at this point, starting to think trade in.
I feel exactly the same way.
Old 02-17-2013, 08:50 PM
DIY'er
Mein Auto: 2004 545i
Originally Posted by SFbay View Post
Over and over same thing:
Mechatronik adapter, once you replace it you'll thank me a lot
Do you mean sleeve or mechatronics as a whole?
Obviously one should check the fluid level first.. aside from that, the sleeve doesn't make any difference. Either it has enough fluid or it doesn't.
Next are solenoids, or a full mechatronics replacement. I haven't seen a case where either didn't fix this issue (although there aren't many who have done solenoids to be honest)
Old 02-19-2013, 07:34 PM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
Dropping my car off next week to get mechatronics replaced under warranty; I can't wait to get rid of the back and forth shifting from 5th -6th!
2014 550i xDrive, Alpine White, Black Merino, Anthracite Wood, M Sport, Premium, Executive, and Cold Weather Packages, HUD, Ceramic Controls, Comfort Access, Sport Automatic Transmission, 4 Zone, Soft Close Doors, Power Trunk, Fully Coded, M Performance Spoiler and Black Grilles, 28% Tint, Charcoal Filter Delete, BMS Stage 1, Dinan Performance Springs, Bavsound Stage 1 Premium Kit w/subs, Beltronics STiR+
Old 02-19-2013, 07:46 PM
DIY'er
That is good news. Let us know the outcome.
Also, I am curious how much you paid for the warranty, if you don't mind me asking
Old 02-19-2013, 08:18 PM
Vapiano's Avatar
$1,895; Credit Union offered several options, I chose the 5 year/100,000 miles new car which ever comes first plan. Car qualified for a new car warranty since it had only 60k miles, warranty is B2B and covers everything including gaskets and seals! It can be extended for another three years if needed; I don't plan on keeping the car that long. It is going to be hard not to upgrade in a few years. It will pay for itself after the mech job.
Old 02-19-2013, 08:21 PM
DIY'er
I was about to say.. that is one of the cheapest I have seen, especially awesome given it covers seals. I'm not big on extended warranties, but for that price and on one of these cars, it's hard to not justify it
Old 02-19-2013, 08:47 PM
Vapiano's Avatar
When I did my initial research; I found out there were common issues that affected the 545 and I wanted to protect myself from large out of pocket expense. I almost went with a 2008 550i instead; but the warranty gave me peace of mind.
Old 02-23-2013, 02:15 PM
Vapiano's Avatar
Tranny fix update; the Indy mechanic I am working with could not pull a code in order to start the process to replace the mechatronics with the warranty company. The dealer, another Indy mechanic and a transmission shop was able to pull the code (4F85). I went back to my friend's shop to have him scan the car afterwards and the code was present. He doesn't do warranty work so he is out of the running. Now I have to find another Indy that does warranty work that I can trust. Obviously the dealer wants to just replace the tranny and the warranty company wants absolute proof this needs to be done. But that involves paying $600 out of pocket to drop the pan to see if any metal fragments are in the pan. I am confident there won't be any; the sealing sleeve does have a slight leak when I checked it.
I paid for the warranty and need to be patient to allow the process to run it's course. I have to force myself not to go out and replace the solenoids and change the oil on my own. Patience is not one of my strong suits.
Old 02-23-2013, 02:24 PM
DIY'er
Warranty company should just let you change the mechatronics yourself at a reduced shop rate
Old 02-23-2013, 07:52 PM
Vapiano's Avatar
LOL! I wish! It would be done by now! The inspector must see a code on the scan in order to allow the tech to move forward. The Indy I was working with seems to have an issue with his software. Patience!
Old 02-27-2013, 06:39 PM
Vapiano's Avatar
I decided to tackle the issue myself and use the warranty when it's a critical issue, plus the process is a PITA!
My solenoid kit is arriving tomorrow from The CTSC; I will also be swapping out the sealing sleeve and mechatronics seal adapter as well. If this takes care of the back & forth shifting issues and going into the limp mode, I will replace the pan and change the oil shortly afterwards. Klaus was extremely helpful, I definitely recommend ordering from him.
I hope to have good news soon.
Old 02-27-2013, 07:22 PM
DIY'er
Cool!
Hopefully we can add another success story, and confirm whether I was just lucky or if it actually fixes these things . I emailed with Klaus a bit and agree he was very helpful.
Speaking of Klaus, don't freak out if the old solenoids are a slightly different color. If I remember correctly my old green ones were replaced with new blue ones. I was freaking out though when the colors didn't match up and sent Klaus about 10 emails in 5 minutes, lol. Ultimately they just changed the color and I realized the part numbers were the same.
Also, just remembered you sent me a PM. Sorry about that, I never did give you a call. It sounds like you already talked to thectsc though, but let me know if you have any other questions and I will try to help
FYI, I think I've said this before but just wanted to make sure--the "sealing sleeve" is quite difficult to get all the way out of the car. I actually couldn't get mine out. You'll need star (female torx) sockets and/or wrenches in order to remove a mount on the back of the transmission to give you enough access to get it out. You can get it out of the transmission fine.. it just gets jammed between the transmission and part of the car body
Old 02-27-2013, 11:33 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
It will be a total success story. But if I were you I'd try mechatronik adapter first, and then solenoid pack
Old 02-28-2013, 04:18 AM
DIY'er
Are you referring to the sleeve or something else?
Old 02-28-2013, 06:19 AM
Vapiano's Avatar
Here is the link to the mechatronics seal adapter MechAdapt. This needs to be replaced if you are removing the mechatronics unit; I have not read where swapping this alone will fix the issues most are having. The sealing sleeve and solenoids; yes.
I read a review from 2004 where Motor Trend experienced the same back and forth shifting issues on a brand spanking new 545i when they tested it. This has always been an issue; I guess not enough R&D from the company they purchased the solenoids from.
schpenxel, give me a buzz later today when you have a chance; I do have a few questions for you.
Thanks.
Old 02-28-2013, 07:33 AM
DIY'er
Yeah everything I read said even the slightest leak at that seal would be really bad, so you should always replace it when pulling the valve body (mechatronics, whatever, lol)
I read an article about that transmission where they went from square 1 to in production on that transmission in a really fast timeline, something in the neighborhood of 2 years I believe it was? I'm sure that didn't help. It blows my mind nobody noticed the issues though when test driving the cars.. especially if car and driver found it that quickly
Old 03-01-2013, 05:50 PM
Vapiano's Avatar
All parts are in! I will be doing the solenoid swap first thing Sunday morning; I hope this does the trick. I will keep you posted.
Old 03-03-2013, 11:35 AM
DIY'er
Let us know how it went!
Inquiring minds want to know
Old 03-03-2013, 07:25 PM
Vapiano's Avatar
Super Success!
Today I replaced the solenoids, sealing sleeve, mechatronic seal adapter, oil pan gasket and drain plug. I decided not to change the pan until I was sure the repair was going to work. The job took 2.5 hours; I used a friendís shop with power tools and a lift, it made all the difference in the world and the task simple.
After completing the job; I let the car run for 5-7 minutes to warm up. I put the car in reverse, removed my foot off the brake and the car immediately started moving backwards. Before the swap there was a significant delay before the car would move. The back and forth cycling between 5th and 6th at 32-40 mph no longer exists, shifting is smooth as butter. The stuttering and jerking when coming to a stop, no longer exists. The car did not go into limp mode during hard acceleration or when manually downshifting as it had before. The shifting was almost unnoticeable.
Anyone having any of the issues below must do this repair; it's not that complicated; just take your time. Total cost for parts and shipping: $527.
After two months of dealing with this; I can say that I am a very happy camper! Itís like having a new car all over again. Night and Day!
List of issues with car before repair:
2-3 second delay before the car would move when selecting reverse
Transmission cycling back and forth between 5th and 6th at 32 - 40 mph
The car would stutter/jerk when coming to a complete stop
Car would go into limp mode occasionally under hard acceleration or when manually down shifting (Code on file: 4F85)
Repair Steps
1. Drain transmission oil
2. Reset transmission adaptation via Snap On scan tool
3. Pull Pan, remove gasket and replace with new one
4. Disconnect sealing sleeve power connector
5. Unlock sealing sleeve lock and remove sleeve
6. Remove mechatronic unit
7. Remove solenoid cover and bracket
8. Pull solenoids and replace with new ones
9. Remove and replace mechatronic sealing sleeve
10. Replace mechatronic back in transmission
11. Replace sealing sleeve and lock bracket
12. Reconnect power connector to sealing sleeve
13. Replace oil pan
14. Add 4 quarts of transmission fluid and reconnect filler plug
15. Start car and let it run until the transmission temps get to 84 degrees, used a Snap On scan tool to determine temperature
16. Turn engine off and add more transmission fluid until it started to run out, reconnect filler plug
17. Check for codes
18. Drive to test
19. Replace heat shields and transmission cover
20. Enjoy issue free, smooth shifting; put a smile on your face transmission in your 5 series!
Old 03-03-2013, 08:08 PM
DIY'er
CONGRATS!! It is awesome to hear I'm not the only person this has worked for.
I had been checking this thread non stop all day waiting for you to respond, haha.
There's someone else over on 5series.net that was waiting on the results too--his mechanic said that the solenoids wouldn't fix his issue..
Old 03-03-2013, 08:21 PM
DIY'er
Super Success!
Today I replaced the solenoids, sealing sleeve, mechatronic seal adapter, oil pan gasket and drain plug. I decided not to change the pan until I was sure the repair was going to work. The job took 2.5 hours; I used a friend's shop with power tools and a lift, it made all the difference in the world and the task simple.
After two months of dealing with this; I can say that I am a very happy camper! It's like having a new car all over again. Night and Day!
Repair Steps
13. Replace oil pan
17. Check for codes
18. Drive to test
Your filling steps are incorrect. You have to do the final fill with the engine running (yes, seriously), with the transmission temp at whatever the manual said (something around 100*F if I remember correctly).
You pull the fill hole and add fluid until it starts to flow out (while still inside the temperature range given & while engine is running). Then plug the hole of course once you get to that level. I have read that doing this at the lower end up the temp range is preferred.
Old 03-03-2013, 09:31 PM
Vapiano's Avatar
My friend (mechanic who let me borrow his shop) who has done this before and monitored the entire process; informed me to measure the fluid we drained out. This gave us a good idea of how much fluid to put back into the transmission. We drained out a little over 5 quarts.
We added 4 quarts of fluid initially, then let the car idle until the transmission temps reached 84 degrees; then we let the car run for about 5 more minutes to allow the pump to pull the fluid into the transmission so we could add the remaining amount. I then pulled the filler plug and put in another 1.75 quarts of transmission oil and sealed her up. Took the car for a nice long test drive; checked for leaks, ran another scan and no codes were present. The sticker on the passenger side of the pan states the temperature range is 84-100 degrees for the fill. I am confident we have enough transmission fluid in the car; the average fill I have read online is 5-6 quarts when you drain the pan. That is exactly in the range I put back in the transmission.
This seems to be the fix everyone has been looking for; it will be great to see the results others are having.
schpenxel, did your car ever go into the limp mode or give you the 4F85 code? Thanks.
Old 03-04-2013, 05:52 AM
DIY'er
I would have to check the exact code for you--That one looks very familiar though, so it is quite possible I did
Good to hear it worked!
Old 03-05-2013, 07:18 AM
Vapiano's Avatar
Thanks for posting your results; this lead me to take on the task. If anyone is on the fence, I highly recommend it. Hard to believe the dealer wanted to swap the tranny; when $500 in parts and 2 hours of labor most likely would cure all issues.
Old 03-06-2013, 12:25 AM
kiwi_chris kiwi_chris is offline
Mein Auto: 2004 BMW 535D
Hi guys... I'm new to this forum and have been keenly following this particular thread for the last few weeks.
I've posted my problems on a UK forum: http://www.bimmerforums.co.uk/forum/...rgggh-t127624/ where there's lots of us experiencing similar issues, and not many of us have found a definite fix.
Basically, I've got the fluctuating revs and a 2-3 second delay in selecting reverse. I've tried almost everything (new trans oil, cleaning sensors etc) and am getting really frustrated. But this thread is really making me think seriously about replacing the solenoids. My question is, do new solenoids somehow need coding to the car? I'm going to get a local independent garage to do the work, but I'm not sure what needs to be done, software-wise, once the new solenoids are in. Do I have to fiddle with the TCU via DIS (or at least INPA)?
I'm capable of resetting the gearbox adaptation values in INPA myself, but not sure about doing much more beyond that...
I've managed to source genuine original ZF parts from a store in China (of all places), and the total for the 7-piece solenoid set, plus mechatronic sealing sleeve, plus seal adapter, is US$444 delivered. Not bad, I think.
http://raymondtech.en.alibaba.com/pr...NOID_PACK.html
So, if I'm to go down this route of replacing the solenoids, what else needs to be done? ie. coding the TCU.
And are there any more parts that I should get replaced while the oil pan's out and the mechatronic unit's exposed?
Thanks in advance for your help! Hopefully this will be another success story! (please god!)...
Chris.
advice, bmw 5 series, issues, tranny problems
