E36 M3 (1995-1999)
Hey guys, so lately with my steering in my 98 e36 m3 there's been some feel of "floating" at higher speeds. I was wondering if you guys knew what that could be or if you guys have ever experiences that before!! Thanks
Could you be more descriptive? It might just be normal.
Does the steering system make weird noises? Might be low on fluid (and you might have a leak). I'd try flushing it.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
No it does t make noises or anything. It just feels like your floating at high speeds..like the tired startup float off the floor
Somewhat like when you hydroplane
That is very odd. Like maybe your aerodynamics are changing? It could be normal... How fast are we talking? 100+?
No I'm going only like 70
What are your tire pressures and does it happen on all road conditions?
Check your front control arms, bushings, and RTABs.
Yea it happens on all roads and I just changed my bushings...the car just got aligned so I'm not sure
I've had the car for 3 years and now accidents one owner and the tired are brand new...they just did alignment for me
Bad alignment then, have them recheck it.
Power steering rack moving about might make the entire front end feel like it is washing out at once?
Tie rods, ball joints, and so on unless both sides suddenly went out at once, not likely would do other things. But the rack is what centrally ties those tie rods together. Also the rear trailing arm bushings or even the rear subframe to body rubber mounts would let the rear end track a little off center from the front, causing a similar feeling. Get it going straight and at neutral throttle on flat ground, see if the car shifts left or right when you apply throttle or let off all at once. That is likely something in the rear suspension IMO. |
Shocks/struts are another thing to check. How many miles on them?
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
