7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#76
![]() If so, I would like to do this. I dont need details on running the Aux to the front. I know about shielding and using a relay/switch to switch between the Aux and Radio. Simple crap like that I can figure out on my own. ![]() What I need are pictures to show where to cut the traces and where the signals are. If you have them, will you share? |
#77
bmw e65 aux in
hello paper, thanks for sharing this great work with every one here, my question here is did you have the aux already showing on your screen even before putting the retrofit? in my bmw i have got ( fm.am.cd.cdc.tone) would that cable work for my car? i mean once i connect the cable into the back of my head unit will that aux sign starts to show up automataically on the screen?
greetings all the way from london |
#79
You would need the correct cable & NCS Expert for the coding .
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
#80
BMW e65 aux in
Thanks paper for the speedy reply, so is this what you had to do to your car? I mean did you do it yourself ? If so can you please send me the link where to buy the cable and software? Thanks again
#81
PAPER, I have been trying to find a way to install a AUX port in the car ever since I got it. The only option was to remove the 6 CD Changer and install an iPOD adaptor. And this cost $1200…so I stayed away. But I found your post and WOW great JOB!!!
I have since bought the AUX mod and changed the sequence to 2,7,8 and installed it in my car. The AUX category didn’t come up so I guess I have to use NCS expert and do some programming. Thanks again!!! |
#82
I installed everything as instructed and programed the MMI to show the AUX on the menu screen but when I click on it with my phone plugged into the AUX cord the FM stations just turn grey and now volume control or sound comes out. Can anyone help me with this?
#83
#84
No music come out and the radio stations stay on the screen but are greyed out
#85
ok let me try to be clearer for you . When you push the I-drive knob & select Aux , what shows up on the screen ? Does the Aux volume control show up & can you adjust it ? Also take a pic of the screen with your phone & post it up so I can see what is on your screen .
#86
![]() When I select AUX it stays like that with no music. |
#87
Ok what happens when you push the I-drive
Knob down ? & the only thing I see gray is the cd player & that is probably cause you don't have a Cd in it Sent from my GT-N7000 using Bimmer App
#88
When you use the auxiliary it should change to
The auxiliary volume control . Watch my video & you can see what is supposed to be on the MMI screen after you select Aux Sent from my GT-N7000 using Bimmer App
#89
![]() Sorry I was driving down the road trying to take that picture and must have pulled the cord out a little. Here is a picture with it plugged in, the stations grey out and no music plays and no volume control shows up. I tried pushing the idrive down several times and nothing happens. Last edited by bimmer750ok; 02-27-2013 at 07:14 PM. |
#90
Only thing I can think of is your car is
Not coded correctly or your ask unit Is not the right ask unit for auxiliary . Not muxh I can do without having the car here so I can look at it . Sent from my GT-N7000 using Bimmer App
#91
To me it just looks like your listening to the fm radio & you have the dial on aux before you actually select aux as the item to be used .
#92
ya your right, but either way I try to select AUX and it wont select it or play music.
#93
Correctly or you have the wrong Ask Unit Sent from my GT-N7000 using Bimmer App
#94
Paper is right. i had the same thing and as soon as i replaced the ASK unit to a newer version it worked like a charm.
this project has two sections. one is the coding to enable the AUX in the MMIGT (or whatever that section of the coding is named). it looks like you got that part. as soon as you code it the AUX becomes available and selectable. the other part is the ASK unit. it has to be 06/06 or newer. mine was 01/06 and it wouldn't work. as soon as i put there a newer unit it works great. Paper, the sound quality though (playing through my iphone) is not the same as radio or cd. it is lacking the bass and deep sounds like a true cd quality. is there something i can do to improve the sound quality? don't get me wrong. i love the fact that i can play music through my iphone but i wish the sound quality was better/deeper. Last edited by tamir15; 03-02-2013 at 06:58 AM. |
#95
Have you tried to adjust the settings yet ?
#96
what settings?
if you are referring to the sound settings of the car audio then yes i have adjusted them |
#97
Hey Paper,
Not sure if you got my PM or not, but do you repair logic 7 amps or ask units? I have been researching AUX input and NCS Expect and playing around with it, but don't want to mess up the MMI unit. Anyways my car was built 01/06 so I think I have to buy a 06/06 ask unit or newer. Do you have one for sale? I found a few on ebay but thought I might try the forum first. Thanks |
#98
As for Ask & L7 repairs , I posted a topic In the DIY section so you can do it yourself . All the chips are easily available on Ebay . Now for your Ask unit , I would buy the auxiliary plug 1st before replacing your ASK unit . It may or may not work , I have Had both good & bad luck with Ask units With 01/06 & 02/06 dates . A couple have Worked fine & a couple didn't . But I do have 1 for sale if tou need it ... Sent from my GT-N7000 using Bimmer App
#99
hey paper, i have a 2005 745i it was built in nov.2004 and not alot of ipod/video interface modules for mine will this aux connection work on my ride? you can email me better will like to ask you a couple of other stuuf from your ride
#100
I would need your email address to email you .
