E30 Cabrio Wheels - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 02-10-2013, 05:58 PM
Stormint Stormint is offline
Mein Auto: e30 convertible
Cool E30 Cabrio Wheels
OK guys, give me a hand. Will the 5 spoke, 4 bolt Mini Cooper wheels fit on my E30 and moreover will they be the right diameter and look good or? What wheels can you recommend? thanks all!
Old 02-11-2013, 05:00 AM
BMWFatherFigure's Avatar
Old School
Dunno. Measure them.
Current:
E38 Parts Car
Previous:
Old 02-11-2013, 08:50 AM
hornhospital's Avatar
D'oh, You Kids!
Mini's are 4 x 100 same as the 4-lug E30, but offset varies. Also, the center hole may not match (too big/small)
Quotes to live by:
BMW-CCA #441426
Old 02-15-2013, 12:31 AM
fporro fporro is offline
Send a message via MSN to fporro Send a message via Yahoo to fporro
Mein Auto: 87 325iC
our centerbore is 57.1, think minis are 66, so you'll want centering rings.
as far as width, you'll want fronts as 7" et25 or 8" et 13, rears can go as wide as 9" et 0
cheers,
Frank
e30 parts
Old 03-02-2013, 10:01 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is online now
Mein Auto: 1989 E30; 2000 E38; GS350
Mini cooper rims have a hub bore of 56.1mm and will have to be modified to fit the E30's 57.1mm hub. Also the mini cooper rims have high offsets (40mm), so you will also need four15-20mm hub centric spacers with longer lug bolts.
Big Boyz with Bad Toyz.
