Old 03-03-2013, 01:39 PM
k8nalli k8nalli is online now
Mein Auto: 2005 X3
Battery is dead...I can't get in
Is there a manual method of gaining entry when the battery is dead???
Old 03-03-2013, 01:47 PM
Kamdog's Avatar
Kamdog Kamdog is offline
-- Robert S. Johnson 56FG
Mein Auto: 2008 535i
The metal key.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 03-03-2013, 01:55 PM
911 911 is offline
Mein Auto: 2005 X3, 2004 911 Cabrio
Insert key, turn left.
Which reminds me the new comfort access "proximity" fobs - are a problem in this case - happened to a friend last week.
Old 03-03-2013, 03:53 PM
UncleJ UncleJ is offline
Mein Auto: '06 X3
+1 for all of the above! The new fangled "proximity fobs" -- aside from costing a mint when you lose one (or go swimming with it in your pocket) could be problems here. Perhaps an outside mechanical hood release (to reach the "jump terminals") would be prudent to have as these batteries and cars age. Of course that means anyone could get under the hood too.
Old 03-04-2013, 12:49 PM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
New FOBs have key inside
The new FOB's have a removable metal key like thingy to open drivers door with.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 03-04-2013, 12:56 PM
StLMO StLMO is offline
Mein Auto: 535i
Also on the comfort keys, I dont think the remote battery is rechargeable. There's a back panel that can be removed when you pull out the metal key.
Old 03-05-2013, 10:58 AM
madurodave's Avatar
BMW Enthusiast!
Originally Posted by Kamdog View Post
The metal key.
Or "Rock meets glass"! Expensive option though!
Madurodave
My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi
Retired: 1998 BMW Z3
Member of BMWCCA!
Old 03-05-2013, 08:25 PM
Mein Auto: 2005 X3
Thank you all for your suggestions. I can see the lock button move (slightly) and hear a click when I turn the key, but no entry. A locksmith will be out tomorrow...hopefully they can gain entry without further issues.
Old 03-06-2013, 11:02 AM
X3 Skier's Avatar
X3 Skier X3 Skier is offline
Powder Days
Mein Auto: 2005 X3 2.5i (ED 2004)
Had a couple dead battery episodes on the05 x3. Metal key worked finer both times.
Cheers
Just Some Consultant
"I never understood the dread term "terminal illness" until I saw Heathrow for myself." Dennis Hopper
Old 03-07-2013, 12:03 PM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i
There is another alternative. Underneath the front driver's side of the car, there is a terminal surrounded with red plastic that can be used to jump or charge the car. So if you a charger positive up to this terminal, hook the negative up to the chassis, you can charge the battery & then use the remote.
Old 03-07-2013, 12:58 PM
madurodave's Avatar
BMW Enthusiast!
I never knew that!
Madurodave
Member of BMWCCA!
Old 03-07-2013, 01:43 PM
can0n4 can0n4 is offline
Mein Auto: '04 BMW X3, '04 330xi
What terminal are you talking about? The alternator connection?
Old 03-07-2013, 04:03 PM
dukedkt442 dukedkt442 is offline
Mein Auto: 08 E83; 97 MKIII; 84 GMC
NM... delete post.
Old 03-07-2013, 06:17 PM
TA
Sorry, wrong forum
Sorry about the bad terminal info. I thought I was on the E39 forum. It does have a convenient positive access point, the X83 does not. If you had to, you should be able to get to the back of the alternator and remove the plastic nut to get to the positive side of the battery, but it would be more difficult.
Old 03-07-2013, 07:47 PM
Mein Auto: 2004 X3 2.5i
It would be very unusual to need to do that.
I really think K8's problem is an isolated case where the driver's door lock mechanism somehow seized mechanically while drawing power - draining the battery as a result.
In general for the X3, it's only the rear hatch that would be inoperative with a flat or disconnected battery, because it doesn't have a lock cylinder.
(Many other SUVs do have a key operated hatch.)
There's pros and cons to locking your X3 when it is parked in your garage.
